주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
OnePlus 6T Battery Replacement
필요한 것
  1. OnePlus 6T Battery Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
    댓글 쓰기
  2. OnePlus 6T Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
    댓글 쓰기
  3. OnePlus 6T Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
    댓글 쓰기
  4. OnePlus 6T Battery Replacement: 4 단계, 이미지 3개 중 1개 OnePlus 6T Battery Replacement: 4 단계, 이미지 3개 중 2개 OnePlus 6T Battery Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
    댓글 쓰기
  5. OnePlus 6T Battery Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Remove the single 3mm Phillips #00 screw from the battery.
    댓글 쓰기
  6. OnePlus 6T Battery Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers, carefully remove the small metal bracket covering the battery connector.
    댓글 쓰기
  7. OnePlus 6T Battery Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Halberd Spudger
    $2.99
    • Using a halberd spudger, gently lift and disconnect the battery connector from the phone.
    • Do not use a metal tool for this step as it may puncture the battery and cause it to leak toxic liquid.
    댓글 쓰기
  8. OnePlus 6T Battery Replacement: 8 단계, 이미지 2개 중 1개 OnePlus 6T Battery Replacement: 8 단계, 이미지 2개 중 2개
    • Grab the red tab on the right hand side and pull until the battery dislodges.
    • It will have some tension as there is tape holding the battery in place. Only remove the battery. Make sure to leave the tape as it will ensure the next battery stays in place.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 34명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Kira D'Agostino
회원 가입일: 10/15/19
1,775 평판
안내서 2개를 작성함
14가이드 댓글
Does the adhesive for the back cover need to be replaced? Should I heat the phone and back glass for re-assembly?
Mark Bugajski - 답글 공유
Good questions. I think “reassembly is the reverse of these instructions" is a bit simplified. I think the heat is only for removal, but perhaps it would cause the adhesive to rebond after reassembly? Can an ifixit tech comment?
Justin Allen - 답글 공유
Just wondering if anyone can clarify the reattachment of the rear panel, as far as whether it is recommended, or necessary, to heat it again, or get a new adhesive gasket. Thanks.
Scott Sparling - 답글 공유
Good question! You should replace the back cover adhesive with either a custom-cut adhesive or double-sided tape such as Tesa tape. You can choose to reheat and reuse the existing adhesive, but there may be a chance that the back cover will fall off. If you’re reusing adhesive, be sure to remove any uneven adhesive chunks.
Arthur Shi - 답글 공유
What width Tesa tape would work for the replacement of the back cover?
Jamie Wright - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 72
지난 30일: 357
전체 시간: 58,358
