주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
OnePlus 8 Daughterboard Replacement
필요한 것
    1. OnePlus 8 Daughterboard Replacement, Heat the rear glass: 1 단계, 이미지 1개 중 1개
      • Power off your phone and unplug any cables.
      • Heat an iOpener and apply it to the rear glass for two minutes.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and internal battery, so proceed with care.
      댓글 쓰기
    2. OnePlus 8 Daughterboard Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 1개 OnePlus 8 Daughterboard Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 2개 OnePlus 8 Daughterboard Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 3개
      • Apply a suction handle to the center of the bottom edge of the rear glass, as close to the edge as possible.
      • If your display is badly cracked, cover it with a layer of clear packing tape to help the suction cup adhere. Alternatively, you can pull using very strong tape instead of a suction cup. If all else fails, try supergluing the suction cup to the broken screen.
      • Pull up on the suction handle with strong, steady force to create a gap between the rear glass and frame.
      • Insert an opening pick into the gap.
      댓글 쓰기
    3. OnePlus 8 Daughterboard Replacement, Slice the bottom edge adhesive: 3 단계, 이미지 3개 중 1개 OnePlus 8 Daughterboard Replacement, Slice the bottom edge adhesive: 3 단계, 이미지 3개 중 2개 OnePlus 8 Daughterboard Replacement, Slice the bottom edge adhesive: 3 단계, 이미지 3개 중 3개
      • Slide the opening pick to the bottom right corner to slice the adhesive securing the rear glass.
      • Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
      댓글 쓰기
    4. OnePlus 8 Daughterboard Replacement: 4 단계, 이미지 3개 중 1개 OnePlus 8 Daughterboard Replacement: 4 단계, 이미지 3개 중 2개 OnePlus 8 Daughterboard Replacement: 4 단계, 이미지 3개 중 3개
      • Insert a second opening pick under the bottom edge of the rear glass, into the gap you just created.
      • Slide the opening pick to the bottom left corner to slice the adhesive.
      • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
      댓글 쓰기
    5. OnePlus 8 Daughterboard Replacement, Slice the left edge adhesive: 5 단계, 이미지 3개 중 1개 OnePlus 8 Daughterboard Replacement, Slice the left edge adhesive: 5 단계, 이미지 3개 중 2개 OnePlus 8 Daughterboard Replacement, Slice the left edge adhesive: 5 단계, 이미지 3개 중 3개
      • If you have trouble slicing, reheat the iOpener and apply it to the edge for two minutes to soften the adhesive.
      • Insert a third opening pick under the bottom left corner of the rear glass.
      • Slide the opening pick up the left edge to slice the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      댓글 쓰기
    6. OnePlus 8 Daughterboard Replacement, Slice the top edge adhesive: 6 단계, 이미지 3개 중 1개 OnePlus 8 Daughterboard Replacement, Slice the top edge adhesive: 6 단계, 이미지 3개 중 2개 OnePlus 8 Daughterboard Replacement, Slice the top edge adhesive: 6 단계, 이미지 3개 중 3개
      • Insert a fourth opening pick under the top left corner of the rear glass.
      • Slide the opening pick along the top edge to slice the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      댓글 쓰기
    7. OnePlus 8 Daughterboard Replacement, Slice the right edge adhesive: 7 단계, 이미지 3개 중 1개 OnePlus 8 Daughterboard Replacement, Slice the right edge adhesive: 7 단계, 이미지 3개 중 2개 OnePlus 8 Daughterboard Replacement, Slice the right edge adhesive: 7 단계, 이미지 3개 중 3개
      • Insert a fifth opening pick under the top right corner of the rear glass.
      • Slide the opening pick down the right edge to slice the remaining adhesive.
      댓글 쓰기
    8. OnePlus 8 Daughterboard Replacement, Remove the rear glass: 8 단계, 이미지 3개 중 1개 OnePlus 8 Daughterboard Replacement, Remove the rear glass: 8 단계, 이미지 3개 중 2개 OnePlus 8 Daughterboard Replacement, Remove the rear glass: 8 단계, 이미지 3개 중 3개
      • Remove the rear glass.
      • If the rear glass still feels stuck to the frame, slide an opening pick around the entire perimeter until the rear glass separates completely.
      • During reassembly:
      • Secure the rear glass with pre-cut adhesive or double-sided adhesive tape.
      • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
      댓글 쓰기
    1. OnePlus 8 Daughterboard Replacement, Unfasten the motherboard cover: 9 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • A white sticker may cover a screw on the right edge of the motherboard cover. Pierce through it with the tip of your screwdriver or use tweezers to remove it.
      • Use a Phillips screwdriver to remove the eleven 3.3 mm-long screws securing the motherboard cover.
      댓글 쓰기
    2. OnePlus 8 Daughterboard Replacement, Pry up the motherboard cover: 10 단계, 이미지 3개 중 1개 OnePlus 8 Daughterboard Replacement, Pry up the motherboard cover: 10 단계, 이미지 3개 중 2개 OnePlus 8 Daughterboard Replacement, Pry up the motherboard cover: 10 단계, 이미지 3개 중 3개
      • The motherboard cover is secured by tight clips.
      • Insert the flat end of a spudger under the center of the motherboard cover's bottom edge.
      • Twist the spudger to release the clips.
      • Lever the motherboard cover up until you can grip it with your fingers.
      댓글 쓰기
    3. OnePlus 8 Daughterboard Replacement, Remove the motherboard cover: 11 단계, 이미지 2개 중 1개 OnePlus 8 Daughterboard Replacement, Remove the motherboard cover: 11 단계, 이미지 2개 중 2개
      • Remove the motherboard cover.
      댓글 쓰기
    4. OnePlus 8 Daughterboard Replacement, Disconnect the battery cable: 12 단계, 이미지 2개 중 1개 OnePlus 8 Daughterboard Replacement, Disconnect the battery cable: 12 단계, 이미지 2개 중 2개
      • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket on the bottom left corner of the motherboard.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      댓글 쓰기
    1. OnePlus 8 Daughterboard Replacement, Unfasten the loudspeaker: 13 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • A white sticker may coversa screw on the top right corner of the loudspeaker. Pierce through it with the tip of your screwdriver or use tweezers to remove it.
      • Use a Phillips driver to remove the seven 3.3 mm-long screws securing the loudspeaker.
      댓글 쓰기
    2. OnePlus 8 Daughterboard Replacement, Pry up the loudspeaker: 14 단계, 이미지 2개 중 1개 OnePlus 8 Daughterboard Replacement, Pry up the loudspeaker: 14 단계, 이미지 2개 중 2개
      • The loudspeaker is secured with plastic clips.
      • Insert an opening pick underneath the center of the loudspeaker's top edge.
      • Pry up to release the clips securing the loudspeaker, levering it up until you can grip it with your fingers.
      댓글 쓰기
    3. OnePlus 8 Daughterboard Replacement, Remove the loudspeaker: 15 단계, 이미지 2개 중 1개 OnePlus 8 Daughterboard Replacement, Remove the loudspeaker: 15 단계, 이미지 2개 중 2개
      • Remove the loudspeaker.
      댓글 쓰기
    1. OnePlus 8 Daughterboard Replacement, Eject the SIM card tray: 16 단계, 이미지 3개 중 1개 OnePlus 8 Daughterboard Replacement, Eject the SIM card tray: 16 단계, 이미지 3개 중 2개 OnePlus 8 Daughterboard Replacement, Eject the SIM card tray: 16 단계, 이미지 3개 중 3개
      • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
      • Press firmly to eject the tray.
      댓글 쓰기
    2. OnePlus 8 Daughterboard Replacement, Remove the SIM card tray: 17 단계, 이미지 2개 중 1개 OnePlus 8 Daughterboard Replacement, Remove the SIM card tray: 17 단계, 이미지 2개 중 2개
      • Remove the SIM card tray from the phone.
      • A thin rubber gasket provides water and dust protection. If this gasket is damaged or missing, replace the gasket (or the entire tray) to maintain water resistance and protect your phone's internal components.
      • When inserting a SIM card into the tray, make sure it's oriented properly within the tray before reinserting the tray into the phone.
      댓글 쓰기
    1. OnePlus 8 Daughterboard Replacement, Disconnect the antenna board cable: 18 단계, 이미지 2개 중 1개 OnePlus 8 Daughterboard Replacement, Disconnect the antenna board cable: 18 단계, 이미지 2개 중 2개
      • Use a spudger to disconnect the antenna board cable from the daughterboard by prying the connector straight up from its socket.
      댓글 쓰기
    2. OnePlus 8 Daughterboard Replacement, Disconnect the fingerprint reader cable: 19 단계, 이미지 2개 중 1개 OnePlus 8 Daughterboard Replacement, Disconnect the fingerprint reader cable: 19 단계, 이미지 2개 중 2개
      • Use a spudger to disconnect the fingerprint reader cable from the daughterboard by prying the connector straight up from its socket.
      댓글 쓰기
    3. OnePlus 8 Daughterboard Replacement, Disconnect the interconnect cable: 20 단계, 이미지 2개 중 1개 OnePlus 8 Daughterboard Replacement, Disconnect the interconnect cable: 20 단계, 이미지 2개 중 2개
      • Use a spudger to disconnect the interconnect cable from the daughterboard by prying the connector straight up from its socket.
      댓글 쓰기
    4. OnePlus 8 Daughterboard Replacement, Disconnect the black antenna cable: 21 단계, 이미지 2개 중 1개 OnePlus 8 Daughterboard Replacement, Disconnect the black antenna cable: 21 단계, 이미지 2개 중 2개
      • Use the pointed end of a spudger to disconnect the black antenna cable by prying the connector straight up from its socket on the motherboard.
      • Pry only on the metal heads of the connectors. Avoid prying on the cables themselves.
      • To reconnect antenna cables, hold each one in place over its socket and press down with the flat end of your spudger. The connector will snap into place.
      댓글 쓰기
    5. OnePlus 8 Daughterboard Replacement, Unclip the black antenna cable: 22 단계, 이미지 2개 중 1개 OnePlus 8 Daughterboard Replacement, Unclip the black antenna cable: 22 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use a pair of tweezers or your fingers to lift the black antenna cable out of its clip on the daughterboard.
      댓글 쓰기
    6. OnePlus 8 Daughterboard Replacement, Disconnect and unclip the white antenna cable: 23 단계, 이미지 3개 중 1개 OnePlus 8 Daughterboard Replacement, Disconnect and unclip the white antenna cable: 23 단계, 이미지 3개 중 2개 OnePlus 8 Daughterboard Replacement, Disconnect and unclip the white antenna cable: 23 단계, 이미지 3개 중 3개
      • Use the pointed end of a spudger to disconnect the white antenna cable by prying the connector straight up from its socket on the motherboard.
      • Use a pair of tweezers or your fingers to lift the white antenna cable out of its clip on the daughterboard.
      • During reassembly, make sure the antenna cables are pushed into their channels on the right edge of the phone before pressing them into their respective clips.
      댓글 쓰기
    7. OnePlus 8 Daughterboard Replacement, Unfasten the daughterboard: 24 단계, 이미지 1개 중 1개
      • Use a Phillips driver to remove the single 3.3 mm-long screw securing the daughterboard.
      댓글 쓰기
    8. OnePlus 8 Daughterboard Replacement, Pry up the daughterboard: 25 단계, 이미지 2개 중 1개 OnePlus 8 Daughterboard Replacement, Pry up the daughterboard: 25 단계, 이미지 2개 중 2개
      • Insert the point of a spudger under the top right corner of the daughterboard.
      • Pry up the daughterboard.
      댓글 쓰기
    9. OnePlus 8 Daughterboard Replacement, Remove the daughterboard: 26 단계, 이미지 3개 중 1개 OnePlus 8 Daughterboard Replacement, Remove the daughterboard: 26 단계, 이미지 3개 중 2개 OnePlus 8 Daughterboard Replacement, Remove the daughterboard: 26 단계, 이미지 3개 중 3개
      • Use a pair of tweezers or your fingers to remove the daughterboard.
      • Before reinstalling the daughterboard, make sure all cables that connect to it are out of the way.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Manuel Haeussermann
회원 가입일: 07/13/22
26,419 평판
안내서 72개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 48,411개를 작성함
1가이드 댓글
I have conducted small Board match main board and it shows " Board A" match failed. What is board A?
Kaushal Kharolia - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 38
전체 시간: 1,638
