주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
OnePlus 8 Light Sensor Replacement
필요한 것
  1. OnePlus 8 Light Sensor Replacement, Heat the rear glass: 1 단계, 이미지 1개 중 1개
    • Power off your phone and unplug any cables.
    • Heat an iOpener and apply it to the rear glass for two minutes.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and internal battery, so proceed with care.
    댓글 쓰기
  2. OnePlus 8 Light Sensor Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 1개 OnePlus 8 Light Sensor Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 2개 OnePlus 8 Light Sensor Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 3개
    • Apply a suction handle to the center of the bottom edge of the rear glass, as close to the edge as possible.
    • If your display is badly cracked, cover it with a layer of clear packing tape to help the suction cup adhere. Alternatively, you can pull using very strong tape instead of a suction cup. If all else fails, try supergluing the suction cup to the broken screen.
    • Pull up on the suction handle with strong, steady force to create a gap between the rear glass and frame.
    • Insert an opening pick into the gap.
    댓글 쓰기
  3. OnePlus 8 Light Sensor Replacement, Slice the bottom edge adhesive: 3 단계, 이미지 3개 중 1개 OnePlus 8 Light Sensor Replacement, Slice the bottom edge adhesive: 3 단계, 이미지 3개 중 2개 OnePlus 8 Light Sensor Replacement, Slice the bottom edge adhesive: 3 단계, 이미지 3개 중 3개
    • Slide the opening pick to the bottom right corner to slice the adhesive securing the rear glass.
    • Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
    댓글 쓰기
  4. OnePlus 8 Light Sensor Replacement: 4 단계, 이미지 3개 중 1개 OnePlus 8 Light Sensor Replacement: 4 단계, 이미지 3개 중 2개 OnePlus 8 Light Sensor Replacement: 4 단계, 이미지 3개 중 3개
    • Insert a second opening pick under the bottom edge of the rear glass, into the gap you just created.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
    댓글 쓰기
  5. OnePlus 8 Light Sensor Replacement, Slice the left edge adhesive: 5 단계, 이미지 3개 중 1개 OnePlus 8 Light Sensor Replacement, Slice the left edge adhesive: 5 단계, 이미지 3개 중 2개 OnePlus 8 Light Sensor Replacement, Slice the left edge adhesive: 5 단계, 이미지 3개 중 3개
    • If you have trouble slicing, reheat the iOpener and apply it to the edge for two minutes to soften the adhesive.
    • Insert a third opening pick under the bottom left corner of the rear glass.
    • Slide the opening pick up the left edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    댓글 쓰기
  6. OnePlus 8 Light Sensor Replacement, Slice the top edge adhesive: 6 단계, 이미지 3개 중 1개 OnePlus 8 Light Sensor Replacement, Slice the top edge adhesive: 6 단계, 이미지 3개 중 2개 OnePlus 8 Light Sensor Replacement, Slice the top edge adhesive: 6 단계, 이미지 3개 중 3개
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    댓글 쓰기
  7. OnePlus 8 Light Sensor Replacement, Slice the right edge adhesive: 7 단계, 이미지 3개 중 1개 OnePlus 8 Light Sensor Replacement, Slice the right edge adhesive: 7 단계, 이미지 3개 중 2개 OnePlus 8 Light Sensor Replacement, Slice the right edge adhesive: 7 단계, 이미지 3개 중 3개
    • Insert a fifth opening pick under the top right corner of the rear glass.
    • Slide the opening pick down the right edge to slice the remaining adhesive.
    댓글 쓰기
  8. OnePlus 8 Light Sensor Replacement, Remove the rear glass: 8 단계, 이미지 3개 중 1개 OnePlus 8 Light Sensor Replacement, Remove the rear glass: 8 단계, 이미지 3개 중 2개 OnePlus 8 Light Sensor Replacement, Remove the rear glass: 8 단계, 이미지 3개 중 3개
    • Remove the rear glass.
    • If the rear glass still feels stuck to the frame, slide an opening pick around the entire perimeter until the rear glass separates completely.
    • During reassembly:
    • Secure the rear glass with pre-cut adhesive or double-sided adhesive tape.
    • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
    댓글 쓰기
  9. OnePlus 8 Light Sensor Replacement, Unfasten the motherboard cover: 9 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • A white sticker may cover a screw on the right edge of the motherboard cover. Pierce through it with the tip of your screwdriver or use tweezers to remove it.
    • Use a Phillips screwdriver to remove the eleven 3.3 mm-long screws securing the motherboard cover.
    댓글 쓰기
  10. OnePlus 8 Light Sensor Replacement, Pry up the motherboard cover: 10 단계, 이미지 3개 중 1개 OnePlus 8 Light Sensor Replacement, Pry up the motherboard cover: 10 단계, 이미지 3개 중 2개 OnePlus 8 Light Sensor Replacement, Pry up the motherboard cover: 10 단계, 이미지 3개 중 3개
    • The motherboard cover is secured by tight clips.
    • Insert the flat end of a spudger under the center of the motherboard cover's bottom edge.
    • Twist the spudger to release the clips.
    • Lever the motherboard cover up until you can grip it with your fingers.
    댓글 쓰기
  11. OnePlus 8 Light Sensor Replacement, Remove the motherboard cover: 11 단계, 이미지 2개 중 1개 OnePlus 8 Light Sensor Replacement, Remove the motherboard cover: 11 단계, 이미지 2개 중 2개
    • Remove the motherboard cover.
    댓글 쓰기
  12. OnePlus 8 Light Sensor Replacement, Disconnect the battery cable: 12 단계, 이미지 2개 중 1개 OnePlus 8 Light Sensor Replacement, Disconnect the battery cable: 12 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket on the bottom left corner of the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    댓글 쓰기
  13. OnePlus 8 Light Sensor Replacement, Rear Camera: 13 단계, 이미지 2개 중 1개 OnePlus 8 Light Sensor Replacement, Rear Camera: 13 단계, 이미지 2개 중 2개
    • Disconnect the antenna cable connector on the right, using tweezers.
    • Disconnect the antenna cable connector on the left using tweezers.
    댓글 쓰기
  14. OnePlus 8 Light Sensor Replacement: 14 단계, 이미지 3개 중 1개 OnePlus 8 Light Sensor Replacement: 14 단계, 이미지 3개 중 2개 OnePlus 8 Light Sensor Replacement: 14 단계, 이미지 3개 중 3개
    • Use an opening tool to gently pry and disconnect the three camera press connectors.
    댓글 쓰기
  15. OnePlus 8 Light Sensor Replacement: 15 단계, 이미지 1개 중 1개
    • Remove the rear camera.
    댓글 쓰기
  16. OnePlus 8 Light Sensor Replacement, Motherboard: 16 단계, 이미지 2개 중 1개 OnePlus 8 Light Sensor Replacement, Motherboard: 16 단계, 이미지 2개 중 2개
    • Use an opening tool to pry up and disconnect the front camera press connector.
    • Remove the front camera.
    댓글 쓰기
  17. OnePlus 8 Light Sensor Replacement: 17 단계, 이미지 3개 중 1개 OnePlus 8 Light Sensor Replacement: 17 단계, 이미지 3개 중 2개 OnePlus 8 Light Sensor Replacement: 17 단계, 이미지 3개 중 3개
    • Use an opening tool to pry up and disconnect each of the three press connectors attached to the motherboard.
    댓글 쓰기
  18. OnePlus 8 Light Sensor Replacement: 18 단계, 이미지 1개 중 1개
    • Remove the motherboard by carefully pryinng it out with the opening tool, lifting the battery out to make removal easier.
    댓글 쓰기
  19. OnePlus 8 Light Sensor Replacement, Light Sensor: 19 단계, 이미지 1개 중 1개
    • Insert an opening tool into the gap between the light sensor and chassis.
    • Pry the light sensor up and out.
    댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Jose Reyes
회원 가입일: 09/19/24
73 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 31
전체 시간: 305
