주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
OnePlus 9 5G Screen Replacement
필요한 것
  1. OnePlus 9 5G Screen Replacement, Eject the SIM card tray: 1 단계, 이미지 3개 중 1개 OnePlus 9 5G Screen Replacement, Eject the SIM card tray: 1 단계, 이미지 3개 중 2개 OnePlus 9 5G Screen Replacement, Eject the SIM card tray: 1 단계, 이미지 3개 중 3개
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
    • Press firmly to eject the tray.
  2. OnePlus 9 5G Screen Replacement, Remove the SIM card tray: 2 단계, 이미지 2개 중 1개 OnePlus 9 5G Screen Replacement, Remove the SIM card tray: 2 단계, 이미지 2개 중 2개
    • Remove the SIM card tray from the phone.
    • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
    • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your phone's internal components.
  3. OnePlus 9 5G Screen Replacement, Loosen the rear glass: 3 단계, 이미지 1개 중 1개
    • Completely power off your phone before you begin.
    • Prepare an iOpener and apply it to the rear glass for at least three minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  4. OnePlus 9 5G Screen Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 1개 OnePlus 9 5G Screen Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 2개 OnePlus 9 5G Screen Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 3개
    • Apply a suction handle to the rear glass, as close to the bottom edge as possible.
    • If your rear glass is badly cracked, covering it with a layer of clear packing tape may allow the suction handle to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction handle to the broken rear glass.
    • Pull up on the suction handle with strong, steady force to create a gap between the glass and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive.
    • Insert an opening pick into the gap.
  5. OnePlus 9 5G Screen Replacement, Slice the bottom edge adhesive: 5 단계, 이미지 2개 중 1개 OnePlus 9 5G Screen Replacement, Slice the bottom edge adhesive: 5 단계, 이미지 2개 중 2개
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  6. OnePlus 9 5G Screen Replacement, Insert a second opening pick: 6 단계, 이미지 2개 중 1개 OnePlus 9 5G Screen Replacement, Insert a second opening pick: 6 단계, 이미지 2개 중 2개
    • Insert a second opening pick underneath the bottom edge of the rear glass.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  7. OnePlus 9 5G Screen Replacement, Slice the left edge adhesive: 7 단계, 이미지 3개 중 1개 OnePlus 9 5G Screen Replacement, Slice the left edge adhesive: 7 단계, 이미지 3개 중 2개 OnePlus 9 5G Screen Replacement, Slice the left edge adhesive: 7 단계, 이미지 3개 중 3개
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick underneath the bottom left corner of the rear glass.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  8. OnePlus 9 5G Screen Replacement, Slice the top edge adhesive: 8 단계, 이미지 2개 중 1개 OnePlus 9 5G Screen Replacement, Slice the top edge adhesive: 8 단계, 이미지 2개 중 2개
    • Insert a fourth opening pick underneath the top left corner of the rear glass.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  9. OnePlus 9 5G Screen Replacement, Slice the right edge adhesive: 9 단계, 이미지 2개 중 1개 OnePlus 9 5G Screen Replacement, Slice the right edge adhesive: 9 단계, 이미지 2개 중 2개
    • Insert a fifth and final opening pick underneath the top right corner of the rear glass.
    • Slide the opening pick along the right edge of the back cover to slice the remaining adhesive.
  10. OnePlus 9 5G Screen Replacement, Remove the rear glass: 10 단계, 이미지 2개 중 1개 OnePlus 9 5G Screen Replacement, Remove the rear glass: 10 단계, 이미지 2개 중 2개
    • Remove the rear glass.
    • If the rear glass is still stuck to the frame, slide an opening pick around the entire perimeter until the rear glass separates completely.
    • During reassembly secure the rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  11. OnePlus 9 5G Screen Replacement, Peel off the tape: 11 단계, 이미지 3개 중 1개 OnePlus 9 5G Screen Replacement, Peel off the tape: 11 단계, 이미지 3개 중 2개 OnePlus 9 5G Screen Replacement, Peel off the tape: 11 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to carefully peel the bottom right corner of the charging coil tape off of the daughterboard cover.
  12. OnePlus 9 5G Screen Replacement: 12 단계, 이미지 2개 중 1개 OnePlus 9 5G Screen Replacement: 12 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to carefully peel the bottom left corner of the charging coil tape off of the loudspeaker.
  13. OnePlus 9 5G Screen Replacement, Pry up the flash assembly: 13 단계, 이미지 2개 중 1개 OnePlus 9 5G Screen Replacement, Pry up the flash assembly: 13 단계, 이미지 2개 중 2개
    • The flash assembly is held in place by mild adhesive and covers a motherboard cover screw.
    • Carefully slide an opening pick underneath the bottom edge of the flash assembly.
    • Use your opening pick to pry up the flash assembly.
    • Don't try to remove the flash assembly all the way during this procedure. Its cable is adhered to the backside of the motherboard cover.
  14. OnePlus 9 5G Screen Replacement, Unfasten the motherboard cover: 14 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the ten 3.8 mm-long screws securing the motherboard cover.
    • One of the motherboard cover screws is covered by a white water ingress sticker. To unfasten the screw you can puncture the sticker with your screwdriver.
  15. OnePlus 9 5G Screen Replacement, Pry up the motherboard cover: 15 단계, 이미지 2개 중 1개 OnePlus 9 5G Screen Replacement, Pry up the motherboard cover: 15 단계, 이미지 2개 중 2개
    • The motherboard cover is further held in place by tight plastic clips.
    • Insert a spudger underneath the bottom right edge of the motherboard cover.
    • Pry upwards to loosen the motherboard cover and create a gap.
  16. OnePlus 9 5G Screen Replacement: 16 단계, 이미지 3개 중 1개 OnePlus 9 5G Screen Replacement: 16 단계, 이미지 3개 중 2개 OnePlus 9 5G Screen Replacement: 16 단계, 이미지 3개 중 3개
    • Insert an opening pick underneath the bottom right edge of the motherboard cover.
    • Slide the opening pick up along the right edge of the motherboard cover.
    • Twist the opening pick to release the plastic clips and pry up the motherboard cover.
  17. OnePlus 9 5G Screen Replacement, Remove the motherboard cover: 17 단계, 이미지 2개 중 1개 OnePlus 9 5G Screen Replacement, Remove the motherboard cover: 17 단계, 이미지 2개 중 2개
    • Use a pair of tweezers or your fingers to remove the motherboard cover.
    • The charging coil is attached to the motherboard cover and will lift up at the same time.
  18. OnePlus 9 5G Screen Replacement, Disconnect the battery cable: 18 단계, 이미지 2개 중 1개 OnePlus 9 5G Screen Replacement, Disconnect the battery cable: 18 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket on the bottom left corner of the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  19. OnePlus 9 5G Screen Replacement, Unfasten the daughterboard cover: 19 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the five 3.8 mm-long screws securing the daugtherboard cover.
    • One of the daughterboard cover screws is covered by a white water ingress sticker. To unfasten the screw you can puncture the sticker with your screwdriver.
  20. OnePlus 9 5G Screen Replacement, Pry up the daughterboard cover: 20 단계, 이미지 2개 중 1개 OnePlus 9 5G Screen Replacement, Pry up the daughterboard cover: 20 단계, 이미지 2개 중 2개
    • Insert the point of a spudger underneath the top right edge of the daughterboard cover.
    • Pry upwards to loosen the daughterboard cover.
  21. OnePlus 9 5G Screen Replacement, Remove the daughterboard cover: 21 단계, 이미지 2개 중 1개 OnePlus 9 5G Screen Replacement, Remove the daughterboard cover: 21 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers or your fingers to remove the daughterboard cover.
  22. OnePlus 9 5G Screen Replacement, Disconnect the interconnect cable: 22 단계, 이미지 2개 중 1개 OnePlus 9 5G Screen Replacement, Disconnect the interconnect cable: 22 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the interconnect cable from the motherboard by prying the connector straight up from its socket.
  23. OnePlus 9 5G Screen Replacement, Remove the metal bracket: 23 단계, 이미지 3개 중 1개 OnePlus 9 5G Screen Replacement, Remove the metal bracket: 23 단계, 이미지 3개 중 2개 OnePlus 9 5G Screen Replacement, Remove the metal bracket: 23 단계, 이미지 3개 중 3개
    • Slide one arm of a pair of tweezers underneath the metal bracket covering the interconnect cable.
    • Use your tweezers to lift and unhinge the metal bracket.
    • Remove the metal bracket.
  24. OnePlus 9 5G Screen Replacement, Disconnect the interconnect cable: 24 단계, 이미지 2개 중 1개 OnePlus 9 5G Screen Replacement, Disconnect the interconnect cable: 24 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the interconnect cable from the daughterboard by prying the connector straight up from its socket.
  25. OnePlus 9 5G Screen Replacement, Remove the interconnect cable: 25 단계, 이미지 1개 중 1개
    • Use a pair of tweezers or your fingers to remove the interconnect cable.
  26. OnePlus 9 5G Screen Replacement, Disconnect the antenna board and fingerprint cables: 26 단계, 이미지 3개 중 1개 OnePlus 9 5G Screen Replacement, Disconnect the antenna board and fingerprint cables: 26 단계, 이미지 3개 중 2개 OnePlus 9 5G Screen Replacement, Disconnect the antenna board and fingerprint cables: 26 단계, 이미지 3개 중 3개
    • Use a spudger to disconnect the antenna board cable and the fingerprints sensor from the daughterboard by prying the connectors straight up from their sockets.
  27. OnePlus 9 5G Screen Replacement, Disconnect the black coaxial cable: 27 단계, 이미지 3개 중 1개 OnePlus 9 5G Screen Replacement, Disconnect the black coaxial cable: 27 단계, 이미지 3개 중 2개 OnePlus 9 5G Screen Replacement, Disconnect the black coaxial cable: 27 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Slide one arm of a pair of tweezers under the black antenna cable until it‘s snug against the metal connector.
    • Disconnect the antenna cable by prying the connector straight up from the daughterboard.
  28. OnePlus 9 5G Screen Replacement, Disconnect the white coaxial cable: 28 단계, 이미지 3개 중 1개 OnePlus 9 5G Screen Replacement, Disconnect the white coaxial cable: 28 단계, 이미지 3개 중 2개 OnePlus 9 5G Screen Replacement, Disconnect the white coaxial cable: 28 단계, 이미지 3개 중 3개
    • Slide one arm of a pair of tweezers under the white antenna cable until it‘s snug against the metal connector.
  29. OnePlus 9 5G Screen Replacement, Unfasten the daughterboard: 29 단계, 이미지 1개 중 1개
    • Use a Phillips driver to remove the 2.8 mm-long screw securing the daughterboard.
  30. OnePlus 9 5G Screen Replacement, Pry up the daughterboard: 30 단계, 이미지 2개 중 1개 OnePlus 9 5G Screen Replacement, Pry up the daughterboard: 30 단계, 이미지 2개 중 2개
    • Insert the point of a spudger underneath the top right corner of the daughterboard.
    • Pry upwards to loosen the daughterboard.
  31. OnePlus 9 5G Screen Replacement, Remove the daughterboard: 31 단계, 이미지 2개 중 1개 OnePlus 9 5G Screen Replacement, Remove the daughterboard: 31 단계, 이미지 2개 중 2개
    • Use a pair of blunt nose tweezers or your fingers to remove the daughterboard.
    • Before reinserting the daughterboard, make sure all cables that connect to it are out of the way.
  32. OnePlus 9 5G Screen Replacement, Disconnect the display: 32 단계, 이미지 2개 중 1개 OnePlus 9 5G Screen Replacement, Disconnect the display: 32 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the display cable by prying the connector straight up from its socket on the bottom right corner.
  33. OnePlus 9 5G Screen Replacement, Loosen the display adhesive: 33 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the screen for 3 minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device. The edge should feel slightly too hot to touch.
  34. OnePlus 9 5G Screen Replacement, Insert an iFlex: 34 단계, 이미지 3개 중 1개 OnePlus 9 5G Screen Replacement, Insert an iFlex: 34 단계, 이미지 3개 중 2개 OnePlus 9 5G Screen Replacement, Insert an iFlex: 34 단계, 이미지 3개 중 3개
    • Apply a suction handle to the bottom edge of the screen.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Pull up on the suction handle with strong, steady force and insert an iFlex between the screen and frame.
    • Make sure to insert the iFlex underneath the screen and not the plastic frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the bottom edge and try again.
  35. OnePlus 9 5G Screen Replacement, Insert an opening pick: 35 단계, 이미지 2개 중 1개 OnePlus 9 5G Screen Replacement, Insert an opening pick: 35 단계, 이미지 2개 중 2개
    • Insert an opening pick between the iFlex and the screen.
    • Remove the iFlex.
  36. OnePlus 9 5G Screen Replacement, Slice the bottom edge adhesive: 36 단계, 이미지 2개 중 1개 OnePlus 9 5G Screen Replacement, Slice the bottom edge adhesive: 36 단계, 이미지 2개 중 2개
    • Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
  37. OnePlus 9 5G Screen Replacement: 37 단계, 이미지 2개 중 1개 OnePlus 9 5G Screen Replacement: 37 단계, 이미지 2개 중 2개
    • Insert a second opening pick at the bottom right corner and slide it to the bottom left corner of the screen to slice the adhesive.
  38. OnePlus 9 5G Screen Replacement, Slice the left edge adhesive: 38 단계, 이미지 3개 중 1개 OnePlus 9 5G Screen Replacement, Slice the left edge adhesive: 38 단계, 이미지 3개 중 2개 OnePlus 9 5G Screen Replacement, Slice the left edge adhesive: 38 단계, 이미지 3개 중 3개
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive.
    • When slicing near the front facing camera, only insert the opening pick 2.5 mm to avoid damaging it.
  39. OnePlus 9 5G Screen Replacement, Slice the top edge adhesive: 39 단계, 이미지 3개 중 1개 OnePlus 9 5G Screen Replacement, Slice the top edge adhesive: 39 단계, 이미지 3개 중 2개 OnePlus 9 5G Screen Replacement, Slice the top edge adhesive: 39 단계, 이미지 3개 중 3개
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1–2 minutes to reheat it.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
  40. OnePlus 9 5G Screen Replacement, Slice the right edge adhesive: 40 단계, 이미지 2개 중 1개 OnePlus 9 5G Screen Replacement, Slice the right edge adhesive: 40 단계, 이미지 2개 중 2개
    • Insert a fifth opening pick underneath the top right corner of the screen and slide it along the right edge of the phone to slice the remaining adhesive.
    • Don't try to remove the display all the way yet, the display cable is still threaded through the midframe.
  41. OnePlus 9 5G Screen Replacement, Free the display cable: 41 단계, 이미지 2개 중 1개 OnePlus 9 5G Screen Replacement, Free the display cable: 41 단계, 이미지 2개 중 2개
    • Flip the phone over.
    • Lift the bottom edge of the phone and carefully thread the display cable through its gap in the frame.
  42. OnePlus 9 5G Screen Replacement, Remove the screen: 42 단계, 이미지 1개 중 1개
    • Remove the screen.
    • During reassembly, follow this guide to install custom-cut adhesives for your device.
결론
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our OnePlus 9 5G answers community for help.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Dominik Schnabelrauch
회원 가입일: 11/23/16
257,386 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 25,583개를 작성함
1가이드 댓글
how closely can I follow this guide for a Oneplus 9 Pro?
Hunter Chen - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 72
지난 30일: 243
전체 시간: 13,528
