주요 콘텐츠로 건너뛰기
Opening Procedure (Prereq)
단지 전제 조건
이 가이드는 전제 조건 전용 가이드입니다! 이 가이드는 다른 절차의 일부이며 단독으로 사용할 수 없습니다.
  1. Opening Procedure (Prereq), Heat the left edge: 1 단계, 이미지 1개 중 1개
    • Be sure to power off your iPad before you begin your repair.
    • Heat an iOpener and apply it to the left edge of the iPad for two minutes.
  2. Opening Procedure (Prereq), Screen removal information: 2 단계, 이미지 3개 중 1개 Opening Procedure (Prereq), Screen removal information: 2 단계, 이미지 3개 중 2개 Opening Procedure (Prereq), Screen removal information: 2 단계, 이미지 3개 중 3개
    • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
    • Front camera
    • Antennas
    • Display cables
    • Ambient light sensors
  3. Opening Procedure (Prereq), Anti-Clamp instructions: 3 단계, 이미지 3개 중 1개 Opening Procedure (Prereq), Anti-Clamp instructions: 3 단계, 이미지 3개 중 2개 Opening Procedure (Prereq), Anti-Clamp instructions: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. Opening Procedure (Prereq): 4 단계, 이미지 3개 중 1개 Opening Procedure (Prereq): 4 단계, 이미지 3개 중 2개 Opening Procedure (Prereq): 4 단계, 이미지 3개 중 3개
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. Opening Procedure (Prereq): 5 단계, 이미지 2개 중 1개 Opening Procedure (Prereq): 5 단계, 이미지 2개 중 2개
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. Opening Procedure (Prereq), Insert an opening pick: 6 단계, 이미지 3개 중 1개 Opening Procedure (Prereq), Insert an opening pick: 6 단계, 이미지 3개 중 2개 Opening Procedure (Prereq), Insert an opening pick: 6 단계, 이미지 3개 중 3개
    • This step shows how to open the iPad using a suction handle.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
    • Insert an opening pick into the gap between the digitizer and the frame.
  7. Opening Procedure (Prereq), Separate the left adhesive: 7 단계, 이미지 3개 중 1개 Opening Procedure (Prereq), Separate the left adhesive: 7 단계, 이미지 3개 중 2개 Opening Procedure (Prereq), Separate the left adhesive: 7 단계, 이미지 3개 중 3개
    • Insert a second opening pick into the gap you just created.
    • Slide the pick towards the bottom-left corner of the iPad to separate the adhesive.
    • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
    • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
  8. Opening Procedure (Prereq): 8 단계, 이미지 3개 중 1개 Opening Procedure (Prereq): 8 단계, 이미지 3개 중 2개 Opening Procedure (Prereq): 8 단계, 이미지 3개 중 3개
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
  9. Opening Procedure (Prereq): 9 단계, 이미지 3개 중 1개 Opening Procedure (Prereq): 9 단계, 이미지 3개 중 2개 Opening Procedure (Prereq): 9 단계, 이미지 3개 중 3개
    • Slide the first opening pick towards the top-left corner of the iPad to separate the adhesive.
    • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
  10. Opening Procedure (Prereq), Heat the top edge: 10 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the top edge of the iPad for two minutes.
  11. Opening Procedure (Prereq), Separate the top left adhesive: 11 단계, 이미지 3개 중 1개 Opening Procedure (Prereq), Separate the top left adhesive: 11 단계, 이미지 3개 중 2개 Opening Procedure (Prereq), Separate the top left adhesive: 11 단계, 이미지 3개 중 3개
    • Rotate the pick around the top-left corner of the iPad to separate the adhesive.
  12. Opening Procedure (Prereq), Separate the top adhesive: 12 단계, 이미지 3개 중 1개 Opening Procedure (Prereq), Separate the top adhesive: 12 단계, 이미지 3개 중 2개 Opening Procedure (Prereq), Separate the top adhesive: 12 단계, 이미지 3개 중 3개
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the front camera.
    • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
  13. Opening Procedure (Prereq): 13 단계, 이미지 3개 중 1개 Opening Procedure (Prereq): 13 단계, 이미지 3개 중 2개 Opening Procedure (Prereq): 13 단계, 이미지 3개 중 3개
    • Pull the pick out until only the tip is between the digitizer and the frame.
    • Slide the pick above the front camera to separate the adhesive.
    • Leave the pick near the right side of the front camera before continuing.
  14. Opening Procedure (Prereq): 14 단계, 이미지 3개 중 1개 Opening Procedure (Prereq): 14 단계, 이미지 3개 중 2개 Opening Procedure (Prereq): 14 단계, 이미지 3개 중 3개
    • Re-insert the pick and slide it towards the top-right corner of the iPad to completely separate the top adhesive.
    • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
  15. Opening Procedure (Prereq), Heat the right edge: 15 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the right edge of the iPad for two minutes.
  16. Opening Procedure (Prereq), Separate the top right adhesive: 16 단계, 이미지 3개 중 1개 Opening Procedure (Prereq), Separate the top right adhesive: 16 단계, 이미지 3개 중 2개 Opening Procedure (Prereq), Separate the top right adhesive: 16 단계, 이미지 3개 중 3개
    • Rotate the pick around the top-right corner of the iPad to separate the adhesive.
  17. Opening Procedure (Prereq), Separate the right adhesive: 17 단계, 이미지 3개 중 1개 Opening Procedure (Prereq), Separate the right adhesive: 17 단계, 이미지 3개 중 2개 Opening Procedure (Prereq), Separate the right adhesive: 17 단계, 이미지 3개 중 3개
    • Insert a new opening pick and slide it to the middle of the iPad's right edge.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach 3 inches from the bottom of the iPad.
  18. Opening Procedure (Prereq), Heat the bottom edge: 18 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the bottom edge of the iPad for two minutes.
  19. Opening Procedure (Prereq), Separate the bottom left adhesive: 19 단계, 이미지 3개 중 1개 Opening Procedure (Prereq), Separate the bottom left adhesive: 19 단계, 이미지 3개 중 2개 Opening Procedure (Prereq), Separate the bottom left adhesive: 19 단계, 이미지 3개 중 3개
    • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
    • Don't fully rotate the pick around the corner, as you may damage the antenna.
    • The third image shows the bottom-left antenna underneath the digitizer.
    • Leave the pick in the corner before moving to the next step.
  20. Opening Procedure (Prereq), Separate the bottom adhesive: 20 단계, 이미지 3개 중 1개 Opening Procedure (Prereq), Separate the bottom adhesive: 20 단계, 이미지 3개 중 2개 Opening Procedure (Prereq), Separate the bottom adhesive: 20 단계, 이미지 3개 중 3개
    • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
    • Slide the pick over the antenna, stopping just before the home button.
    • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
    • Leave the pick to the left of the home button before continuing.
  21. Opening Procedure (Prereq): 21 단계, 이미지 3개 중 1개 Opening Procedure (Prereq): 21 단계, 이미지 3개 중 2개 Opening Procedure (Prereq): 21 단계, 이미지 3개 중 3개
    • Insert an opening pick into the gap you just created.
    • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
  22. Opening Procedure (Prereq): 22 단계, 이미지 3개 중 1개 Opening Procedure (Prereq): 22 단계, 이미지 3개 중 2개 Opening Procedure (Prereq): 22 단계, 이미지 3개 중 3개
    • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
    • Leave the pick to the right of the home button before continuing.
  23. Opening Procedure (Prereq), Heat the right edge: 23 단계, 이미지 1개 중 1개
  24. Opening Procedure (Prereq): 24 단계, 이미지 2개 중 1개 Opening Procedure (Prereq): 24 단계, 이미지 2개 중 2개
    • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
    • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
    • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
  25. Opening Procedure (Prereq): 25 단계, 이미지 2개 중 1개 Opening Procedure (Prereq): 25 단계, 이미지 2개 중 2개
    • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
    • Throughout the remaining steps, try not to touch the back side of the glass or the surface of the LCD with your fingers—any fingerprints can be tough to clean off.
  26. Opening Procedure (Prereq), Separate the right adhesive: 26 단계, 이미지 3개 중 1개 Opening Procedure (Prereq), Separate the right adhesive: 26 단계, 이미지 3개 중 2개 Opening Procedure (Prereq), Separate the right adhesive: 26 단계, 이미지 3개 중 3개
  27. Opening Procedure (Prereq): 27 단계, 이미지 2개 중 1개 Opening Procedure (Prereq): 27 단계, 이미지 2개 중 2개
    • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
    • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
    • Be mindful of the display cables when reassembling the iPad. Make sure they are folded properly underneath the LCD screen to prevent any damage.
결론
작성자
4다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
214,027 평판
안내서 1,041개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,752개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 156
