주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Petcube Play 2 Microphone Replacement
필요한 것
    1. Petcube Play 2 Microphone Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 Petcube Play 2 Microphone Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 Petcube Play 2 Microphone Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
      • Flip over the Petcube so the rubber bottom faces you.
      • Pull up the rubber layer with an iFixit opening pick to expose the screws underneath.
      댓글 쓰기
    2. Petcube Play 2 Microphone Replacement: 2 단계, 이미지 2개 중 1개 Petcube Play 2 Microphone Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the four 3.5mm screws from under the rubber cover using a Phillips #1 screwdriver.
      • The glue may cause slight resistance, but the screws should come out with minimal effort.
      댓글 쓰기
    3. Petcube Play 2 Microphone Replacement: 3 단계, 이미지 2개 중 1개 Petcube Play 2 Microphone Replacement: 3 단계, 이미지 2개 중 2개
      • Carefully pry off the glass front panel using an opening pick or a spudger.
      • Do not force the front panel off, as it may crack and break.
      댓글 쓰기
    4. Petcube Play 2 Microphone Replacement: 4 단계, 이미지 3개 중 1개 Petcube Play 2 Microphone Replacement: 4 단계, 이미지 3개 중 2개 Petcube Play 2 Microphone Replacement: 4 단계, 이미지 3개 중 3개
      • Slide off the two covers, starting with the top plastic cover.
      • Slide out the internal assembly from the aluminum casing.
      댓글 쓰기
    5. Petcube Play 2 Microphone Replacement: 5 단계, 이미지 3개 중 1개 Petcube Play 2 Microphone Replacement: 5 단계, 이미지 3개 중 2개 Petcube Play 2 Microphone Replacement: 5 단계, 이미지 3개 중 3개
      • Once the internal assembly is removed, a brass cylinder in one corner of the cube's front face will be visible. A screw will be attached to it.
      • Remove the screw with a Phillips #1 screwdriver.
      댓글 쓰기
    6. Petcube Play 2 Microphone Replacement: 6 단계, 이미지 3개 중 1개 Petcube Play 2 Microphone Replacement: 6 단계, 이미지 3개 중 2개 Petcube Play 2 Microphone Replacement: 6 단계, 이미지 3개 중 3개
      • Flip the cube onto its side to locate the pull tabs.
      • Using an opening tool, lift each of the five tabs to separate the two halves of the Petcube 2.
      댓글 쓰기
    7. Petcube Play 2 Microphone Replacement: 7 단계, 이미지 3개 중 1개 Petcube Play 2 Microphone Replacement: 7 단계, 이미지 3개 중 2개 Petcube Play 2 Microphone Replacement: 7 단계, 이미지 3개 중 3개
      • Gently disconnect the cable connectors to separate the two halves of the device.
      • Avoid pulling on the wires to prevent damage to the connectors.
      댓글 쓰기
    8. Petcube Play 2 Microphone Replacement: 8 단계, 이미지 3개 중 1개 Petcube Play 2 Microphone Replacement: 8 단계, 이미지 3개 중 2개 Petcube Play 2 Microphone Replacement: 8 단계, 이미지 3개 중 3개
      • Use a Phillips #1 screwdriver to remove the two 1mm screws.
      • Carefully release each of the tabs on the sides of the cube and remove the motherboard.
      • Be gentle with the tabs. They will break under too much pressure.
      댓글 쓰기
    1. Petcube Play 2 Microphone Replacement, Microphone: 9 단계, 이미지 3개 중 1개 Petcube Play 2 Microphone Replacement, Microphone: 9 단계, 이미지 3개 중 2개 Petcube Play 2 Microphone Replacement, Microphone: 9 단계, 이미지 3개 중 3개
      • Use a Phillips #1 screwdriver to remove the screws from the plates behind the motherboard, separating the two plates.
      댓글 쓰기
    2. Petcube Play 2 Microphone Replacement: 10 단계, 이미지 2개 중 1개 Petcube Play 2 Microphone Replacement: 10 단계, 이미지 2개 중 2개
      • Detach the PCB with the microphones from the plastic.
      • Using a soldering iron, desolder the microphones from the PCB.
      • Be careful! The soldering iron becomes hot! Avoid touching the device for too long, as this may damage the components.
      • To Avoid burning yourself or damaging the device, follow the IFixit soldering instructions
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Jacob Branco
회원 가입일: 03/18/24
291 평판
안내서 2개를 작성함
UMass Dartmouth, Team 1-5, Konn Spring 2024 UMass Dartmouth, Team 1-5, Konn Spring 2024 회원
UMASSD-KONN-S24S1G5
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 20
전체 시간: 362
