주요 콘텐츠로 건너뛰기
Philips Norelco 5801XL Battery Replacement
Ben Gibbs
Ben Gibbs4 다른 기여자
최종 수정일 July 15, 2024
10 - 25 분
조정
누락된 단계
Use this guide to replace the rechargeable battery in the Philips Norelco 5801XL. The steps should be followed exactly as listed in the guide. Some soldering skills are required. Be sure to handle with care. For help with soldering: click here.
필요한 것
부품
도구
더보기...
  1. Philips Norelco 5801XL Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Philips Norelco 5801XL Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Using a T8 torx screwdriver, remove both 2mm T8 screws.
  2. Philips Norelco 5801XL Battery Replacement: 2 단계, 이미지 2개 중 1개 Philips Norelco 5801XL Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Using a plastic opening tool, separate the front housing from the back housing.
    • Carefully pull the housing apart.
  3. Philips Norelco 5801XL Battery Replacement: 3 단계, 이미지 3개 중 1개 Philips Norelco 5801XL Battery Replacement: 3 단계, 이미지 3개 중 2개 Philips Norelco 5801XL Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the plastic bracket using a plastic opening tool.
    • Pry from the inside of the bracket towards the outside of the housing to remove it.
  4. Philips Norelco 5801XL Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the two T8 2mm Philips screws holding onto the bracket over the charge port.
    • Remove the bracket. It will pull straight out.
  5. Philips Norelco 5801XL Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Push in the charge port using the plastic opening tool.
  6. Philips Norelco 5801XL Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the circuit board upwards and fold it towards the head of the razor.
    • Do not break the contacts connecting the board to the motor.
  7. Philips Norelco 5801XL Battery Replacement: 7 단계, 이미지 3개 중 1개 Philips Norelco 5801XL Battery Replacement: 7 단계, 이미지 3개 중 2개 Philips Norelco 5801XL Battery Replacement: 7 단계, 이미지 3개 중 3개
    • Desolder the contacts where the battery connects to the circuit board.
    • Straighten the battery contacts and pull them through the opposite side of the circuit board.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Ben Gibbs
회원 가입일: 02/16/16
361 평판
안내서 3개를 작성함
IUPUI, Team 3-2, Harley Spring 2016 IUPUI, Team 3-2, Harley Spring 2016 회원
IUPUI-HARLEY-S16S3G2
4 회원들
안내서 6개를 작성함
댓글 3개
The replacement battery I bought had contact strips that were too long and too wide for the slots on the circuit board, so I had to trim off about half the length and 1.5 mm of the width on each strip, but after that alteration, it worked fine.
Tom Hess - 답글
What size is the Rechargeable Battery in the Norelco 5801XL .
Dave - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 22
전체 시간: 4,375
