주요 콘텐츠로 건너뛰기
Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement
August Post
August Post다른 한 명의 기여자
최종 수정일 July 15, 2024
20 분
조정
This guide will show how to take off a broken LED board, and replace it with a new one. You may need this if you notice the charging light on the Philips Norelco Bodygroom not lighting up while the product is on the charging stand. It is also necessary for this guide to show how to disassemble and reassemble the trimmer in order to get to the LED board. It is recommended to have the iFixit Pro Tech Toolkit since it will contain all tools necessary for this guide. Lastly, you will need to provide your own working LED board to replace the broken one.
필요한 것
도구
더보기...
  1. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement, LED Board: 1 단계, 이미지 2개 중 1개 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement, LED Board: 1 단계, 이미지 2개 중 2개
    • Place thumb behind trimming blade and push up to open.
  2. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 2 단계, 이미지 3개 중 1개 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 2 단계, 이미지 3개 중 2개 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 2 단계, 이미지 3개 중 3개
    • Remove two screws (M2 x 9.5) on metal plate with JIS 0 screwdriver bit.
    • Use spudger to pry off metal plate.
    • Slide up plastic housing to remove the trimmer.
  3. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 3 단계, 이미지 3개 중 1개 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 3 단계, 이미지 3개 중 2개 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 3 단계, 이미지 3개 중 3개
    • Slide chrome outer plastic towards removed trimmer.
    • Flip to the other side and repeat, sliding the chrome plastic towards removed trimmer.
  4. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 4 단계, 이미지 2개 중 1개 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 4 단계, 이미지 2개 중 2개
    • Remove two top screws (M2 x 6.9) with the JIS 00 screwdriver bit.
    • Remove two bottom screws (M2 x 6.9) with the same bit.
  5. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 5 단계, 이미지 3개 중 1개 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 5 단계, 이미지 3개 중 2개 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 5 단계, 이미지 3개 중 3개
    • Use spudger to pry off top of the battery cover. WARNING: fairly difficult, be aware significant amount of force required.
    • Use spudger to remove bottom of the battery cover, and remove it.
  6. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 6 단계, 이미지 2개 중 1개 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 6 단계, 이미지 2개 중 2개
    • Use a nylon spudger to pry out battery pack and the attached LED board.
  7. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 7 단계, 이미지 3개 중 1개 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 7 단계, 이미지 3개 중 2개 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 7 단계, 이미지 3개 중 3개
    • Unwrap electrical tape around the battery pack and LED board.
    • Desolder the LED board from the battery pack.
    • Solder the new LED board back to the connection to battery pack.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
August Post
회원 가입일: 11/07/17
415 평판
안내서 3개를 작성함
IUPUI, Team S2-G4, Harley Fall 2017 IUPUI, Team S2-G4, Harley Fall 2017 회원
IUPUI-HARLEY-F17S2G4
3 회원들
안내서 7개를 작성함
댓글 한 개
Can you point me in the right direction for finding a replacement board? I’m having trouble finding one. Thanks.
Alex - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 21
전체 시간: 606
