주요 콘텐츠로 건너뛰기
Philips Norelco OneBlade Servo Motor Replacement
Joshua Etchberger
Joshua Etchberger2 다른 기여자
최종 수정일 November 11, 2024
5 - 10 분
조정
더 나은 소개글
  1. Philips Norelco OneBlade Servo Motor Replacement, Servo Motor: 1 단계, 이미지 3개 중 1개 Philips Norelco OneBlade Servo Motor Replacement, Servo Motor: 1 단계, 이미지 3개 중 2개 Philips Norelco OneBlade Servo Motor Replacement, Servo Motor: 1 단계, 이미지 3개 중 3개
    • Ensure razor is off and razor blade has been removed.
  2. Philips Norelco OneBlade Servo Motor Replacement: 2 단계, 이미지 2개 중 1개 Philips Norelco OneBlade Servo Motor Replacement: 2 단계, 이미지 2개 중 2개
    • Locate crease in bottom third of razor.
    • Hold razor in both hands, and place thumbs near crease.
    • Slightly bend the razor near crease.
    • Pull casing apart.
    • Device may turn on upon removal. Turn off razor before continuing.
    The case won't pull off like you describe…am i missing something?
    Thomas Papadakos - 답글
    No the thing is literally hello together by something that defies the laws of physics. I have two that stopped charging at exactly the same time. New charges did not help so I tried pulling them apart like drained above and ended up breaking the stupid thing. I refuse to try again work the 2nd
    Phillip Collins - 답글
  3. Philips Norelco OneBlade Servo Motor Replacement: 3 단계, 이미지 3개 중 1개 Philips Norelco OneBlade Servo Motor Replacement: 3 단계, 이미지 3개 중 2개 Philips Norelco OneBlade Servo Motor Replacement: 3 단계, 이미지 3개 중 3개
    • Locate wires below motor on either side of circuit board.
    • Remove solder from each joint using solder removal kit.
    • Do not attempt to remove wires by force.
  4. Philips Norelco OneBlade Servo Motor Replacement: 4 단계, 이미지 1개 중 1개
    • Remove new motor from package and place in position.
    • Motor should sit above circuit board with connection prongs facing downward. Additionally, center extrusion on bottom of motor should sit in provided hole.
결론
Please dispose of servo motor properly. For recycling information, please contact your local waste management facilities or visit www.recycle.philips.com
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Joshua Etchberger
회원 가입일: 11/07/17
472 평판
안내서 3개를 작성함
IUPUI, Team S3-G3, Harley Fall 2017 IUPUI, Team S3-G3, Harley Fall 2017 회원
IUPUI-HARLEY-F17S3G3
3 회원들
안내서 7개를 작성함
댓글 12개
does removing the motor exposing the battery? In my unit I see some green thing underneath the motor, looks like a AA battery, can you confirm?
or is it from somewhere else? (I need to replace my battery)
Yarden Cohen - 답글
I just dismantled my shaver, and it has a 1.2v AA size NiMH battery (suppo hsy aa1200).
João Paulo Gomes -
I’m also curious about the battery. Any one have pictures of it or know what kind of battery it has inside?
James Almeida - 답글
João Paulo Gomes -
Thanks! This definitely helps.
James Almeida -
I see that too, but how did you get the battery out? I haven’t unsoldered the motor yet, but I don’t see how that would help get it out…
Jeff Blum -
What was the reason for replacing the engine?
What are the brushes installed in the engine?
Alex - 답글
I just torn apart mine to replace the battery. I was expecting a 18650 but it is just your standard 1.2v rechargeable battery. I replaced it with a lithium ion battery and everything is good as new. They did make it a bit more difficult by adding a lot of double sided tape to the battery. Next time I might try modding it with a 18650. We’ll see…
Boxiest Trustee - 답글
I am having great difficulty in pulling apart the casing. Is there any recommendation or tips in how to do it? I have tried following the manual and here.
Javier Ismael Ramírez Urízar - 답글
A single 1.2 volt cell....
Well what the hell does the %#*@ thing need 8 volts to charge for
Robert Lee Aka Cancel-Proof - 답글
Money grab, that's what.
money money -
What model of servo motor do you recommend buying? I can't seem to find an exact replacement for the model number on the existing motor.
Ammon P. - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 28
지난 30일: 97
전체 시간: 20,258
