PlayStation 5 Fan Replacement
Follow this guide to replace a faulty cooling fan in a PlayStation 5. You can also follow this guide to remove a dusty or dirty fan to clean it out.
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing the console.
필요한 것
수리 키트
이 키트는 이 안내서를 완료하는데 필요한 모든 부품과 도구를 포함하고 있습니다.
부품
도구
더보기...
동영상 개요
If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
이 단계에 사용된 도구:Tweezers$4.99
Use a pair of tweezers or your fingernail to remove the cap from the cubby.
Use your finger to press the cap into the screw hole.
If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
Lift the stand straight up to remove it.
Do you guys sell the stand
Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
Lift up the corner of the faceplate to unclip it from the case.
While lifting up the corner, slide the faceplate towards the bottom of the device.
Remove the right faceplate.
I recommend doing both covers at this time, to avoid hassle later. Skip to step 38, then come back here
Insert the flat end of a spudger underneath the grille and into the gap above the fan.
Lift up with the spudger to pry the grille away from the case.
Lift the grille away from the case to remove it.
During reassembling:
There is a little flat pin in each end, they need to go into the console
이 단계에 사용된 도구:Magnetic Project Mat$19.95
Use a TR8 Torx security driver to remove the four screws securing the fan shroud to the case:
Two 23.3 mm-long screws
One 11.4 mm-long screw
One 31 mm-long screw
My ps5 seems to have tiny black caps over each screw. My spudger can’t get them off I see no other way to move forward besides breaking the shroud
wrong side, take the cover off the other side
The 31 mm-long screw just wont budge! do I turn that one counter-clockwise or clockwise? someone please help!
Chris Love - 답글
counter clockwise to remove
I damaged the 23.3mm on the bottom right next to fan connector. Is there any replacements? Can't seem to find any 23.3mm t8 screw anywhere online
forsage.rh - 답글
I used a t8 for all of them and had no problem removing, except for that bottom right screw
Is there any replacement screws you can buy for the fan? I slightly damage 23.3mm screw.
My PS5 has TX8 (security Torx bit) screws on my fan shroud and all the case screws. A normal Torx driver won’t work you need the one with the hole in the middle of the bit driver.
Why does my ps5 have 3 different screws? 2 are the same then 2 other ones? Why?
Does anyone know the thread pitch of these screws? I just bought a used PS5 and the screws are missing. The fan has been glued in. Can't make this up.....
Ci sono viti di ricambio?
Dove posso trovarle?
Ho guardato dappertutto e non se ne trovano
Sind mit den Massen die dicke oder die Länge gemeint
Thickness I'm sure
9h works also or I HAD a mix up
Thickness I'm sure
Lift the fan shroud straight up to remove it.
Insert the flat end of a spudger beneath the black wire cover and into the gap above the fan wires.
Use the spudger to peel up the wire cover until you can grip it with your fingers.
Use your fingers to grip the edges of the fan cable connector, and pull up to disconnect it from the motherboard.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
다른 41명이 해당 안내서를 완성하였습니다.
댓글 7개
Did you find out?
Popes -
I just did exactly that for a customer (technically it was a 23 blade 2.15A fan) it works great, the fan connector leads are just barely long enough to fit in the channel in a CFI-1215A model though, so careful not to tug too hard after plugging the fan connector and seating the fan in place.
Would a fan going bad prevent the PS 5 from turning on?
