주요 콘텐츠로 건너뛰기
PlayStation Portal Joystick Grip (Left) Replacement
Arthur Shi
Arthur Shi
최종 수정일 March 11, 2025
20 분 - 1 시간
조정
This guide shows how to remove and replace a worn out left joystick grip (or thumbstick cover) on your PlayStation Portal.
This repair won't fix joystick drift. If you're encountering drift issues, you'll need to replace the joystick module instead.
필요한 것
도구
더보기...
  1. PlayStation Portal Joystick Grip (Left) Replacement, Power off your PlayStation Portal: 1 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement, Power off your PlayStation Portal: 1 단계, 이미지 2개 중 2개
    • Before you begin repairs, power off your PlayStation Portal and unplug any cables.
  2. PlayStation Portal Joystick Grip (Left) Replacement, Pry up the L1 bumper: 2 단계, 이미지 3개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement, Pry up the L1 bumper: 2 단계, 이미지 3개 중 2개 PlayStation Portal Joystick Grip (Left) Replacement, Pry up the L1 bumper: 2 단계, 이미지 3개 중 3개
    • Both bumpers are held in place with clips.
    • Rest a finger over the L1 bumper to prevent it from flying off when you pry.
    • Insert the flat end of a spudger between the top edge of the bumper and the white shell.
    • Pry up to unclip the bumper.
    • Slide the spudger along the seam to release any remaining clips.
  3. PlayStation Portal Joystick Grip (Left) Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the L1 bumper.
  4. PlayStation Portal Joystick Grip (Left) Replacement, Pry up the R1 bumper: 4 단계, 이미지 3개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement, Pry up the R1 bumper: 4 단계, 이미지 3개 중 2개 PlayStation Portal Joystick Grip (Left) Replacement, Pry up the R1 bumper: 4 단계, 이미지 3개 중 3개
    • Repeat the procedure to pry up and remove the R1 bumper.
  5. PlayStation Portal Joystick Grip (Left) Replacement, Reassembly information: 5 단계, 이미지 3개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement, Reassembly information: 5 단계, 이미지 3개 중 2개 PlayStation Portal Joystick Grip (Left) Replacement, Reassembly information: 5 단계, 이미지 3개 중 3개
    • To install a bumper during reassembly:
    • Align the bumper into its slot.
    • Use a finger to press the bumper down firmly until it clicks into place.
  6. PlayStation Portal Joystick Grip (Left) Replacement, Loosen the left joystick trim strip: 6 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement, Loosen the left joystick trim strip: 6 단계, 이미지 2개 중 2개
    • Insert the tip of an opening pick underneath the left joystick trim strip, where it wraps below the grip.
    • Twist the opening pick to release the bottom clip.
  7. PlayStation Portal Joystick Grip (Left) Replacement: 7 단계, 이미지 3개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement: 7 단계, 이미지 3개 중 2개 PlayStation Portal Joystick Grip (Left) Replacement: 7 단계, 이미지 3개 중 3개
    • Insert the tip of an opening pick underneath the outer edge of the trim strip.
    • Slide the opening pick along the edge to release the clips.
  8. PlayStation Portal Joystick Grip (Left) Replacement: 8 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement: 8 단계, 이미지 2개 중 2개
    • Insert the tip of an opening pick under the inner edge of the strip.
  9. PlayStation Portal Joystick Grip (Left) Replacement: 9 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement: 9 단계, 이미지 2개 중 2개
    • Grasp the bottom edge of the trim strip and slowly lift to release any remaining clips.
    • If the strip feels stuck, twist or shift the strip sideways to help release any stubborn clips.
  10. PlayStation Portal Joystick Grip (Left) Replacement, Remove the left joystick trim strip: 10 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement, Remove the left joystick trim strip: 10 단계, 이미지 2개 중 2개
    • Lift and remove the left joystick trim strip.
  11. PlayStation Portal Joystick Grip (Left) Replacement, Remove the right joystick trim strip: 11 단계, 이미지 3개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement, Remove the right joystick trim strip: 11 단계, 이미지 3개 중 2개 PlayStation Portal Joystick Grip (Left) Replacement, Remove the right joystick trim strip: 11 단계, 이미지 3개 중 3개
    • Repeat the procedure to unclip and remove the right joystick trim strip.
  12. PlayStation Portal Joystick Grip (Left) Replacement, Reassembly information: 12 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement, Reassembly information: 12 단계, 이미지 2개 중 2개
    • To reattach a trim strip during reassembly:
    • Use your fingers to align and clip the top edge in place.
    • Firmly press along the remaining edges to clip the strip in place.
  13. PlayStation Portal Joystick Grip (Left) Replacement, Remove the back shell screws: 13 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement, Remove the back shell screws: 13 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws at the bottom tips of each grip.
    • You may need to peel off some tamper-evident stickers to access the screws.
  14. PlayStation Portal Joystick Grip (Left) Replacement: 14 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement: 14 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the top corners of the shell.
  15. PlayStation Portal Joystick Grip (Left) Replacement, Back shell information: 15 단계, 이미지 1개 중 1개
    • The back shell is still secured with numerous clips. The next few steps will show how to unclip the shell while reducing the chance of damaging the clips.
  16. PlayStation Portal Joystick Grip (Left) Replacement, Unclip the back shell: 16 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement, Unclip the back shell: 16 단계, 이미지 2개 중 2개
    • Push the flat edge of a spudger into the back shell's left, inner seam.
    • This releases the clip in that area while flexing the shell slightly, creating a larger outer seam.
    • Keep the spudger inserted in the seam.
  17. PlayStation Portal Joystick Grip (Left) Replacement: 17 단계, 이미지 3개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement: 17 단계, 이미지 3개 중 2개 PlayStation Portal Joystick Grip (Left) Replacement: 17 단계, 이미지 3개 중 3개
    • Insert the tip of an opening pick into the shell's left, outer seam.
    • Slide the pick along the seam to release the clips securing the edge.
    • Keep a pick in the seam to prevent the shell from clipping back together.
  18. PlayStation Portal Joystick Grip (Left) Replacement: 18 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement: 18 단계, 이미지 2개 중 2개
    • Remove the spudger from the inner seam.
  19. PlayStation Portal Joystick Grip (Left) Replacement: 19 단계, 이미지 3개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement: 19 단계, 이미지 3개 중 2개 PlayStation Portal Joystick Grip (Left) Replacement: 19 단계, 이미지 3개 중 3개
    • Repeat the previous three steps on the right side of the Portal to release the clips along the right edge.
  20. PlayStation Portal Joystick Grip (Left) Replacement: 20 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement: 20 단계, 이미지 2개 중 2개
    • Carefully flip your Portal over.
    • Grasp the top edge of the back shell, near a corner.
    • Gently pull the top edge away until you feel the clips release in that corner.
  21. PlayStation Portal Joystick Grip (Left) Replacement: 21 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement: 21 단계, 이미지 2개 중 2개
    • Pull along the top edge to release all the top edge clips.
  22. PlayStation Portal Joystick Grip (Left) Replacement: 22 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement: 22 단계, 이미지 2개 중 2개
    • Grasp the bottom edge of the back shell, near the center.
    • Pull away with firm force to release the clips securing the bottom edge.
  23. PlayStation Portal Joystick Grip (Left) Replacement, Remove the back shell: 23 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement, Remove the back shell: 23 단계, 이미지 2개 중 2개
    • Remove the back shell.
  24. PlayStation Portal Joystick Grip (Left) Replacement, Reassembly information: 24 단계, 이미지 3개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement, Reassembly information: 24 단계, 이미지 3개 중 2개 PlayStation Portal Joystick Grip (Left) Replacement, Reassembly information: 24 단계, 이미지 3개 중 3개
    • To clip the back shell in place during reassembly:
    • Align the corners near the trigger buttons first.
    • Firmly press around the entire perimeter to clip the shell back in place.
  25. PlayStation Portal Joystick Grip (Left) Replacement, Loosen the left grip shell: 25 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement, Loosen the left grip shell: 25 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the left grip shell to the Portal.
    • From the back, these screws are on the right side of the Portal.
    • These screws can be tight. Brace the Portal with your hand and apply strong pressure to the screwdriver.
    • You can also try using a JIS #00 screwdriver to get a better grip on these screws.
  26. PlayStation Portal Joystick Grip (Left) Replacement: 26 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement: 26 단계, 이미지 2개 중 2개
    • Grasp the top edge of the grip shell and twist it slightly outwards (away from the screen) to release the inner clips.
  27. PlayStation Portal Joystick Grip (Left) Replacement, Remove the left grip shell: 27 단계, 이미지 3개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement, Remove the left grip shell: 27 단계, 이미지 3개 중 2개 PlayStation Portal Joystick Grip (Left) Replacement, Remove the left grip shell: 27 단계, 이미지 3개 중 3개
    • Insert the flat edge of a spudger underneath the inner edge of the grip shell, near the vibration motor.
    • Twist the spudger along the edge to unclip the bottom portion of the grip shell.
    • Remove the left grip shell.
  28. PlayStation Portal Joystick Grip (Left) Replacement, Remove the left joystick cover: 28 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the left joystick cover.
  29. PlayStation Portal Joystick Grip (Left) Replacement: 29 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement: 29 단계, 이미지 2개 중 2개
    • Lift and remove the left joystick cover.
  30. PlayStation Portal Joystick Grip (Left) Replacement, Remove the left joystick grip: 30 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Grip (Left) Replacement, Remove the left joystick grip: 30 단계, 이미지 2개 중 2개
    • Lift and remove the left grip from the joystick.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Arthur Shi
회원 가입일: 01/03/18
282,832 평판
안내서 587개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,470개를 작성함
댓글 한 개
Hi, where can I find the grips for the PS portal? I can't find them for purchase anywhere online.
Hrodebert - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 23
지난 30일: 71
전체 시간: 523
