주요 콘텐츠로 건너뛰기
PlayStation Portal Joystick Trim Strips Replacement
Arthur Shi
Arthur Shi
최종 수정일 March 18, 2025
5 - 15 분
조정
This guide shows how to remove and replace the joystick trim strips on your PlayStation Portal. These are the black plastic strips that surround each joystick.
필요한 것
도구
  1. PlayStation Portal Joystick Trim Strips Replacement, Power off your PlayStation Portal: 1 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Trim Strips Replacement, Power off your PlayStation Portal: 1 단계, 이미지 2개 중 2개
    • Before you begin repairs, power off your PlayStation Portal and unplug any cables.
  2. PlayStation Portal Joystick Trim Strips Replacement, Loosen the left joystick trim strip: 2 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Trim Strips Replacement, Loosen the left joystick trim strip: 2 단계, 이미지 2개 중 2개
    • Insert the tip of an opening pick underneath the left joystick trim strip, where it wraps below the grip.
    • Twist the opening pick to release the bottom clip.
  3. PlayStation Portal Joystick Trim Strips Replacement: 3 단계, 이미지 3개 중 1개 PlayStation Portal Joystick Trim Strips Replacement: 3 단계, 이미지 3개 중 2개 PlayStation Portal Joystick Trim Strips Replacement: 3 단계, 이미지 3개 중 3개
    • Insert the tip of an opening pick underneath the outer edge of the trim strip.
    • Slide the opening pick along the edge to release the clips.
  4. PlayStation Portal Joystick Trim Strips Replacement: 4 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Trim Strips Replacement: 4 단계, 이미지 2개 중 2개
    • Insert the tip of an opening pick under the inner edge of the strip.
  5. PlayStation Portal Joystick Trim Strips Replacement: 5 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Trim Strips Replacement: 5 단계, 이미지 2개 중 2개
    • Grasp the bottom edge of the trim strip and slowly lift to release any remaining clips.
    • If the strip feels stuck, twist or shift the strip sideways to help release any stubborn clips.
  6. PlayStation Portal Joystick Trim Strips Replacement, Remove the left joystick trim strip: 6 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Trim Strips Replacement, Remove the left joystick trim strip: 6 단계, 이미지 2개 중 2개
    • Lift and remove the left joystick trim strip.
  7. PlayStation Portal Joystick Trim Strips Replacement, Remove the right joystick trim strip: 7 단계, 이미지 3개 중 1개 PlayStation Portal Joystick Trim Strips Replacement, Remove the right joystick trim strip: 7 단계, 이미지 3개 중 2개 PlayStation Portal Joystick Trim Strips Replacement, Remove the right joystick trim strip: 7 단계, 이미지 3개 중 3개
    • Repeat the procedure to unclip and remove the right joystick trim strip.
  8. PlayStation Portal Joystick Trim Strips Replacement, Reassembly information: 8 단계, 이미지 2개 중 1개 PlayStation Portal Joystick Trim Strips Replacement, Reassembly information: 8 단계, 이미지 2개 중 2개
    • To reattach a trim strip during reassembly:
    • Use your fingers to align and clip the top edge in place.
    • Firmly press along the remaining edges to clip the strip in place.
결론
Arthur Shi
회원 가입일: 01/03/18
282,643 평판
안내서 587개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,454개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 35
전체 시간: 261
