소개
This guide shows how to remove and replace a vibration motor (aka rumble motor or haptic motor) for your PlayStation Portal.
This repair requires basic soldering skills and tools. You'll need to desolder and resolder two wires to the motor in order to replace it.
The Portal has two vibration motors—this guide shows the repair with the left motor. If you're replacing the right motor, the procedure is similar.
필요한 것
Rest a finger over the L1 bumper to prevent it from flying off when you pry.
Insert the flat end of a spudger between the top edge of the bumper and the white shell.
Pry up to unclip the bumper.
Slide the spudger along the seam to release any remaining clips.
Align the bumper into its slot.
Use a finger to press the bumper down firmly until it clicks into place.
Insert the tip of an opening pick underneath the left joystick trim strip, where it wraps below the grip.
Twist the opening pick to release the bottom clip.
Repeat the procedure to unclip and remove the right joystick trim strip.
Use your fingers to align and clip the top edge in place.
Firmly press along the remaining edges to clip the strip in place.
Use a Phillips screwdriver to remove the two 6.5 mm‑long screws at the bottom tips of each grip.
Push the flat edge of a spudger into the back shell's left, inner seam.
Keep the spudger inserted in the seam.
Align the corners near the trigger buttons first.
Firmly press around the entire perimeter to clip the shell back in place.
Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the left grip shell to the Portal.
Insert the flat edge of a spudger underneath the inner edge of the grip shell, near the vibration motor.
Twist the spudger along the edge to unclip the bottom portion of the grip shell.
Remove the left grip shell.
Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the left joystick cover.
Use the point of a spudger to flip up the black lock tab on the left joystick's ZIF connector.
Shift the joystick module so that the flex cable slides out of its socket.
Remove the left joystick.
Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the right grip shell to the Portal.
Remove the right grip shell.
Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the right joystick cover.
Use the point of a spudger to flip up the black lock tab on the right joystick's ZIF connector.
Remove the right joystick.
Use a Phillips screwdriver to remove the four 6.5 mm‑long screws (two on each side) securing the two joystick brackets to the Portal.
Heat an iOpener and apply it to the bottom edge of the screen for two minutes to soften the adhesive.
이 단계에 사용된 도구:Tesa 61395 Tape$2.99
Remove large chunks of adhesives with the flat edge of a spudger or tweezers.
Use high concentration isopropyl alcohol (>90%) to remove any remaining residue. Wipe in one direction with a lint-free cloth or coffee filter until all the adhesive residue is gone.
Apply strips of double-sided tape such as Tesa tape to the screen perimeter to reattach the screen.
Use a Phillips screwdriver to remove the eight 6.5 mm‑long screws securing the motherboard cover to the Portal.
Use the point of a spudger to pry up and disconnect the battery connector.
Before you begin repairs, power off your PlayStation Portal and unplug any cables.
Use the point of a spudger to gently lift the two vibration motor wires out of their groove.
Flip the Portal over such that its back side faces you.
The black wire should be soldered to the upper contact on the vibration motor.
The red wire should be soldered to the lower contact on the vibration motor.
Use your fingers to press against the back of the motor with strong, steady force until it loosens from the frame.
Remove any remaining adhesive residue from the frame and apply double-sided tape such as Tesa tape.
Transfer any foam padding from your old motor to your replacement part.
Press the motor back into its recess and apply firm pressure for a minute to allow the adhesive to bond.
Solder the two wires to the new vibration motor.
Use the point of a spudger to carefully tuck the motor wires back into the groove.
다른 한 분이 해당 안내서를 완성하였습니다.
