PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Battery Replacement
Replace a worn out battery for longer intervals between recharging.
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
다른 2명이 해당 안내서를 완성하였습니다.
첨부 문서
댓글 한 개
Where can I find new condition batteries for this. I can’t seem to find any compatable ones.
