주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Punkt MP02 Battery Replacement
필요한 것
  1. Punkt MP02 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Punkt MP02 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Use a SIM card eject tool to to eject and remove the SIM card tray on the side of the phone.
    댓글 쓰기
  2. Punkt MP02 Battery Replacement: 2 단계, 이미지 2개 중 1개 Punkt MP02 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • The back panel is held on by glue and multiple tabs.
    • Slide a Jimmy into the seam between the back panel and the chassis.
    • Slide the Jimmy around the perimeter to release the back panel, with care not to damage the retaining clips.
    • Clean any old adhesive with a spudger and isopropyl alcohol, then apply new adhesive to the back panel before reinstalling it.
    댓글 쓰기
  3. Punkt MP02 Battery Replacement: 3 단계, 이미지 3개 중 1개 Punkt MP02 Battery Replacement: 3 단계, 이미지 3개 중 2개 Punkt MP02 Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Use a Phillips screwdriver to remove the two adjacent 3 mm Phillips screws.
    댓글 쓰기
  4. Punkt MP02 Battery Replacement: 4 단계, 이미지 3개 중 1개 Punkt MP02 Battery Replacement: 4 단계, 이미지 3개 중 2개 Punkt MP02 Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Insert a Jimmy into the seam between the front and back case.
    • Slide the Jimmy around the perimeter while prying to separate the front and back case.
    댓글 쓰기
  5. Punkt MP02 Battery Replacement: 5 단계, 이미지 2개 중 1개 Punkt MP02 Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the battery press connector.
    • Make sure to pry under the connector itself and not on the board.
    댓글 쓰기
  6. Punkt MP02 Battery Replacement: 6 단계, 이미지 2개 중 1개 Punkt MP02 Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Gently pry the battery off with the spudger tool.
    • Take care not to bend, warp, or puncture the battery during removal.
    댓글 쓰기
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Elias Fischer
회원 가입일: 02/18/26
425 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 120
전체 시간: 302
