주요 콘텐츠로 건너뛰기
Razer BlackShark V2 USB Sound Card Audio Jack Replacement
Jalal Gibson
Jalal Gibson3 다른 기여자
최종 수정일 June 5, 2023
20 - 40 분
어려움
If choppy, interrupted, or no audio is being transferred between your device and your Razer BlackShark V2 headset while the USB sound card is in use or your headset won't plug into the sound card properly, your sound card’s audio jack may be damaged (to confirm diagnoses & solutions, see Razer BlackShark V2 Troubleshooting Page, "Audio Cutting Out" or “No Audio at All”). This guide will assist you in the replacement of this component. Be mindful to not adversely snap any plastic components or small wires when applying pressure.
필요한 것
도구
더보기...
  1. Razer BlackShark V2 USB Sound Card Audio Jack Replacement, USB Sound Card Audio Jack: 1 단계, 이미지 1개 중 1개
    • Microwave the iOpener for 30 seconds.
    • The iOpener can get very hot.
    • Wrap the iOpener around the sound card along the parting line and hold to help weaken the adhesive joining the halves.
  2. Razer BlackShark V2 USB Sound Card Audio Jack Replacement: 2 단계, 이미지 2개 중 1개 Razer BlackShark V2 USB Sound Card Audio Jack Replacement: 2 단계, 이미지 2개 중 2개
    • Separate the two halves of the plastic shell of the sound card along the parting line.
    • Using a sharp tool to saw away stubborn adhesive may be necessary.
    • Use standard caution when using sharp tools! Never cut, stab, or wedge towards your body or fingers.
  3. Razer BlackShark V2 USB Sound Card Audio Jack Replacement: 3 단계, 이미지 1개 중 1개
    • Desolder the audio jack.
결론
작성자
3다른 기여자 명과 함께
Jalal Gibson
회원 가입일: 03/08/23
277 평판
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 12
지난 30일: 32
전체 시간: 1,029
