주요 콘텐츠로 건너뛰기
Razer Blackwidow V3 Pro Battery Replacement
필요한 것
  1. Razer Blackwidow V3 Pro Battery Replacement, Turn off keyboard: 1 단계, 이미지 1/2 Razer Blackwidow V3 Pro Battery Replacement, Turn off keyboard: 1 단계, 이미지 2/2
    • Turn off your keyboard
    • Make sure that no lights on the keyboard are on
  2. Razer Blackwidow V3 Pro Battery Replacement, Pull all keycaps off: 2 단계, 이미지 1/3 Razer Blackwidow V3 Pro Battery Replacement, Pull all keycaps off: 2 단계, 이미지 2/3 Razer Blackwidow V3 Pro Battery Replacement, Pull all keycaps off: 2 단계, 이미지 3/3
    • Remove the keycaps using either a keycap puller or your hands
    • If you are not using a keycap puller, take caution to only pull the keycaps directly up or you may risk damage. Remove keycaps near the outskirts of the keyboard first, then work your way to the middle.
    • Repeat until all keycaps are off
  3. Razer Blackwidow V3 Pro Battery Replacement, Peeling the Rubber Feet: 3 단계, 이미지 1/2 Razer Blackwidow V3 Pro Battery Replacement, Peeling the Rubber Feet: 3 단계, 이미지 2/2
    • Peel the lower-right rubber feet off just enough to reveal the 9mm Phillips screw.
    • This image turns the keyboard backwards, which is why the rubber feet we are peeling off appears to be on top. If it helps, turn your keyboard backwards too.
    • Be careful as to not rip the rubber feet. If needed, apply an iOpener, heat gun, or hair dryer on the rubber pad to soften the adhesive underneath.
  4. Razer Blackwidow V3 Pro Battery Replacement, Unscrewing under the Rubber Feet: 4 단계, 이미지 1/1
    • Unscrew the 9 mm Phillips screw underneath.
  5. Razer Blackwidow V3 Pro Battery Replacement, Remove front screws: 5 단계, 이미지 1/2 Razer Blackwidow V3 Pro Battery Replacement, Remove front screws: 5 단계, 이미지 2/2
    • Remove the 15 7 mm Phillips screws
  6. Razer Blackwidow V3 Pro Battery Replacement, Open the keyboard: 6 단계, 이미지 1/3 Razer Blackwidow V3 Pro Battery Replacement, Open the keyboard: 6 단계, 이미지 2/3 Razer Blackwidow V3 Pro Battery Replacement, Open the keyboard: 6 단계, 이미지 3/3
    • Lift the top of the keyboard up and slightly to the front.
    • While pushing up, watch the LED on the front (circled red on the 2nd picture) and make sure it doesn't get damaged while removing the lid.
    • Do not remove the keyboard entirely, there are two connectors still in place.
  7. Razer Blackwidow V3 Pro Battery Replacement, ZIF connector removal: 7 단계, 이미지 1/3 Razer Blackwidow V3 Pro Battery Replacement, ZIF connector removal: 7 단계, 이미지 2/3 Razer Blackwidow V3 Pro Battery Replacement, ZIF connector removal: 7 단계, 이미지 3/3
    • Flip up the black locking flap on the ZIF connector using a fingernail or a spudger, then carefully pull out the ribbon cable.
    • During reassembly, try not to bend the ribbon cable, apart from the factory made bend.
  8. Razer Blackwidow V3 Pro Battery Replacement, Wire removal: 8 단계, 이미지 1/2 Razer Blackwidow V3 Pro Battery Replacement, Wire removal: 8 단계, 이미지 2/2
    • Carefully pull out the wires.
    • You may need to wiggle the wires in order to remove them.
    • During reassembly, make sure that you don't assemble these wires backwards, or you may risk damage.
    • Remove the top housing entirely.
  9. Razer Blackwidow V3 Pro Battery Replacement, Peel off casing: 9 단계, 이미지 1/3 Razer Blackwidow V3 Pro Battery Replacement, Peel off casing: 9 단계, 이미지 2/3 Razer Blackwidow V3 Pro Battery Replacement, Peel off casing: 9 단계, 이미지 3/3
    • Peel off the black plastic covering the battery.
    • Peel off the black plastic piece carefully to make sure the battery doesn't get punctured and release dangerous chemicals.
  10. Razer Blackwidow V3 Pro Battery Replacement, Battery Connector.: 10 단계, 이미지 1/3 Razer Blackwidow V3 Pro Battery Replacement, Battery Connector.: 10 단계, 이미지 2/3 Razer Blackwidow V3 Pro Battery Replacement, Battery Connector.: 10 단계, 이미지 3/3
    • Remove the battery connector from the motherboard.
    • You may need to wiggle the connector in order to remove it.
    • During reassembly, make sure to insert the connector back the right way, or you may risk damaging the connector.
  11. Razer Blackwidow V3 Pro Battery Replacement, Removing the wire: 11 단계, 이미지 1/3 Razer Blackwidow V3 Pro Battery Replacement, Removing the wire: 11 단계, 이미지 2/3 Razer Blackwidow V3 Pro Battery Replacement, Removing the wire: 11 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use your hands or tweezers to remove the wires from the mount.
  12. Razer Blackwidow V3 Pro Battery Replacement, Battery Information: 12 단계, 이미지 1/1
    • The battery is held on with adhesive in the middle, as highlighted. direct your iOpener / heating device, and your tools in this general area to remove the battery.
  13. Razer Blackwidow V3 Pro Battery Replacement, Heating instructions: 13 단계, 이미지 1/2 Razer Blackwidow V3 Pro Battery Replacement, Heating instructions: 13 단계, 이미지 2/2
    • Heat and place an iOpener or other heating device (Hair Dryer / Heat Gun) under the general location of the battery's adhesive.
    • Don't apply too much heat to the battery, use the iOpener for about a minute on the battery maximum
    • For your reference, the red box is the general location of where the adhesive of the battery is.
    • For your reference, the black box is where the iOpener is.
  14. Razer Blackwidow V3 Pro Battery Replacement, Adhesive cutting: 14 단계, 이미지 1/2 Razer Blackwidow V3 Pro Battery Replacement, Adhesive cutting: 14 단계, 이미지 2/2
    • Go slow, and reheat if the adhesive is still too sticky (Just don't overheat the battery). Do not puncture the battery, or you risk a dangerous situation. If you are using a heat gun or hair dryer, plan in case of a fire.
    • Use a spudger to cut the adhesive, or if you have a suction cup, you can pull the battery directly up without risking puncturing the battery.
    • Avoid bending the battery.
  15. Razer Blackwidow V3 Pro Battery Replacement, (iFixit opening tool only) Lifting the battery out: 15 단계, 이미지 1/2 Razer Blackwidow V3 Pro Battery Replacement, (iFixit opening tool only) Lifting the battery out: 15 단계, 이미지 2/2
    • Use an iFixit opening tool (or flat end of your spudger) to lift the battery up.
    • Prevent bending of the battery and only apply pressure periodically. Reheat if needed.
  16. Razer Blackwidow V3 Pro Battery Replacement, Remove the battery: 16 단계, 이미지 1/3 Razer Blackwidow V3 Pro Battery Replacement, Remove the battery: 16 단계, 이미지 2/3 Razer Blackwidow V3 Pro Battery Replacement, Remove the battery: 16 단계, 이미지 3/3
    • Remove the battery carefully.
결론
Recycle responsibly, it may be the law in your area.
Make sure to calibrate your battery.
op_
회원 가입일: 12/21/23
439 평판
안내서 3개 작성하였습니다
댓글 2개
I didn't attach a battery in the parts section for a reason. I found one site selling the exact same model number for the Razer BlackWidow V3 Pro battery, but it was from a site I've never seen before and zero reviews on trustpilot. I'll attach it here just in case, but buying it is at your own risk and you may not get what you ordered.
FT5936E2P Battery Replacement For Razer RZ03-0282 Wireless Keyboard (anvone.com)
op_ - 답글
I really don't know who is going to use this, but here's their battery supplier for who it becomes useful to (Although I don't take responsibility to if this source is reliable or not, it was just a quick Google search :))
op_ -
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 30
30일 전: 100
전체 시간: 427
