주요 콘텐츠로 건너뛰기
Razer Blade 15" (2018) CMOS Battery Replacement
Clay Eickemeyer
Clay Eickemeyer
최종 수정일 December 6, 2023
15 - 30 분
조정
Use this guide to replace the CMOS battery in your Razer Blade 15" (2018).
If your laptop shows a BIOS configuration screen every time it's powered on, the CMOS battery may have died. Replace the CMOS battery to retain certain boot settings on your laptop.
필요한 것
도구
더보기...
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. Razer Blade 15" (2018) CMOS Battery Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2개 중 1개 Razer Blade 15" (2018) CMOS Battery Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2개 중 2개
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Razer Blade 15" (2018) CMOS Battery Replacement, Unfasten the back cover: 2 단계, 이미지 1개 중 1개
    • Rotate your laptop so the screen hinge is farthest from you.
    • Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
  3. Razer Blade 15" (2018) CMOS Battery Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 1개 Razer Blade 15" (2018) CMOS Battery Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 2개 Razer Blade 15" (2018) CMOS Battery Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 3개
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If the cover feels loose, remove it at any time.
    • Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Razer Blade 15" (2018) CMOS Battery Replacement, Angle the opening pick: 4 단계, 이미지 3개 중 1개 Razer Blade 15" (2018) CMOS Battery Replacement, Angle the opening pick: 4 단계, 이미지 3개 중 2개 Razer Blade 15" (2018) CMOS Battery Replacement, Angle the opening pick: 4 단계, 이미지 3개 중 3개
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
    • Insert your pick up to 10 mm (0.4 in) deep.
  5. Razer Blade 15" (2018) CMOS Battery Replacement, Free the bottom right corner: 5 단계, 이미지 3개 중 1개 Razer Blade 15" (2018) CMOS Battery Replacement, Free the bottom right corner: 5 단계, 이미지 3개 중 2개 Razer Blade 15" (2018) CMOS Battery Replacement, Free the bottom right corner: 5 단계, 이미지 3개 중 3개
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  6. Razer Blade 15" (2018) CMOS Battery Replacement, Free the front edge: 6 단계, 이미지 3개 중 1개 Razer Blade 15" (2018) CMOS Battery Replacement, Free the front edge: 6 단계, 이미지 3개 중 2개 Razer Blade 15" (2018) CMOS Battery Replacement, Free the front edge: 6 단계, 이미지 3개 중 3개
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
  7. Razer Blade 15" (2018) CMOS Battery Replacement, Remove the back cover: 7 단계, 이미지 3개 중 1개 Razer Blade 15" (2018) CMOS Battery Replacement, Remove the back cover: 7 단계, 이미지 3개 중 2개 Razer Blade 15" (2018) CMOS Battery Replacement, Remove the back cover: 7 단계, 이미지 3개 중 3개
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
  8. Razer Blade 15" (2018) CMOS Battery Replacement, Soften the battery cable tape adhesive: 8 단계, 이미지 2개 중 1개 Razer Blade 15" (2018) CMOS Battery Replacement, Soften the battery cable tape adhesive: 8 단계, 이미지 2개 중 2개
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or create a fire hazard.
  9. Razer Blade 15" (2018) CMOS Battery Replacement, Peel up the battery cable tape: 9 단계, 이미지 3개 중 1개 Razer Blade 15" (2018) CMOS Battery Replacement, Peel up the battery cable tape: 9 단계, 이미지 3개 중 2개 Razer Blade 15" (2018) CMOS Battery Replacement, Peel up the battery cable tape: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel the battery cable tape away from the cable.
  10. Razer Blade 15" (2018) CMOS Battery Replacement, Disconnect the battery: 10 단계, 이미지 3개 중 1개 Razer Blade 15" (2018) CMOS Battery Replacement, Disconnect the battery: 10 단계, 이미지 3개 중 2개 Razer Blade 15" (2018) CMOS Battery Replacement, Disconnect the battery: 10 단계, 이미지 3개 중 3개
    • Use the point of a spudger to press on alternating sides of the battery connector and walk it out of its socket.
  11. Razer Blade 15" (2018) CMOS Battery Replacement, Disconnect the CMOS battery: 11 단계, 이미지 3개 중 1개 Razer Blade 15" (2018) CMOS Battery Replacement, Disconnect the CMOS battery: 11 단계, 이미지 3개 중 2개 Razer Blade 15" (2018) CMOS Battery Replacement, Disconnect the CMOS battery: 11 단계, 이미지 3개 중 3개
    • The CMOS battery is the flat, round battery with a twisted pair of wires connecting it to the motherboard.
    • Use the point of your spudger to press on alternating sides of the CMOS battery connector to "walk" it out of its socket and disconnect it.
  12. Razer Blade 15" (2018) CMOS Battery Replacement, Pry up the CMOS battery: 12 단계, 이미지 3개 중 1개 Razer Blade 15" (2018) CMOS Battery Replacement, Pry up the CMOS battery: 12 단계, 이미지 3개 중 2개 Razer Blade 15" (2018) CMOS Battery Replacement, Pry up the CMOS battery: 12 단계, 이미지 3개 중 3개
    • Slide an opening pick under the CMOS battery.
    • Use your pick to pry up the CMOS battery from the motherboard and separate the adhesive securing it.
    • If the battery feels stuck, apply a heated iOpener to the battery for 30 seconds to soften the adhesive.
  13. Razer Blade 15" (2018) CMOS Battery Replacement, Remove the CMOS battery: 13 단계, 이미지 2개 중 1개 Razer Blade 15" (2018) CMOS Battery Replacement, Remove the CMOS battery: 13 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $6.99
    • Remove the CMOS battery.
    • During reassembly, apply double-sided tape to the new battery and press it into place on the circle indicator.
결론
Clay Eickemeyer
회원 가입일: 09/19/22
81,373 평판
안내서 455개를 작성함
Guide Team Guide Team 회원
Staff
9 회원들
안내서 11,367개를 작성함
댓글 한 개
Does someone know precisely which battery I need to buy - before opening the computer?
Daniel Sanford - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 53
전체 시간: 1,738
