주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Remington MB4040 Thermal Switch Replacement
필요한 것
    1. Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: 1 단계, 이미지 3개 중 1개 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: 1 단계, 이미지 3개 중 2개 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: 1 단계, 이미지 3개 중 3개
      • Press the black button below the blade to remove the blade.
      댓글 쓰기
    2. Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: 2 단계, 이미지 2개 중 1개 Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: 2 단계, 이미지 2개 중 2개
      • Place the device so the back of the product is facing up.
      • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
      댓글 쓰기
    3. Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: 3 단계, 이미지 3개 중 1개 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: 3 단계, 이미지 3개 중 2개 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: 3 단계, 이미지 3개 중 3개
      • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
      • Remove the small clear plastic piece that covers the zoom wheel numbers.
      댓글 쓰기
    4. Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): 4 단계, 이미지 2개 중 1개 Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): 4 단계, 이미지 2개 중 2개
      • Remove the two 16.0 mm PH00 screws from the front cover.
      • Use the blue plastic opening tool to pry apart the two halves of the device.
      댓글 쓰기
    5. Remington MB4040 Thermal Switch Replacement, Blade Button Removal: 5 단계, 이미지 2개 중 1개 Remington MB4040 Thermal Switch Replacement, Blade Button Removal: 5 단계, 이미지 2개 중 2개
      • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
      • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
      댓글 쓰기
    1. Remington MB4040 Thermal Switch Replacement, Remove Motherboard: 6 단계, 이미지 2개 중 1개 Remington MB4040 Thermal Switch Replacement, Remove Motherboard: 6 단계, 이미지 2개 중 2개
      댓글 쓰기
    2. Remington MB4040 Thermal Switch Replacement, Remove Thermal Switch: 7 단계, 이미지 1개 중 1개
      • Separate the thermal switch from the battery by using a spudger to pry it from the adhesive.
      • Use a low temperature RTV to readhere the thermal switch to the battery.
      • Remove the soldering holding the thermal switch to the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Cameron Carnahan
회원 가입일: 01/20/15
1,112 평판
안내서 6개를 작성함
USF Tampa, Team 1-5, Blackwell Winter 2015 USF Tampa, Team 1-5, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S1G5
3 회원들
안내서 32개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 25
전체 시간: 3,361
