소개
Use this guide to replace the worn-out battery in your Samsung Galaxy Note8.
Before disassembling your Note8, discharge the battery below 25%. A charged battery can catch fire and/or explode if accidentally punctured.
If your battery is swollen, take appropriate precautions. Do not heat your phone. If needed, you can use a dropper or syringe to inject isopropyl alcohol (90+%) around the edges of the back cover to weaken the adhesive. Swollen batteries can be very dangerous, so wear eye protection and exercise due caution, or take it to a professional if you're not sure how to proceed.
Opening the Note8 will damage the waterproof sealing on the device. If you do not replace the adhesive, your phone will function normally, but will lose its water-protection.
This guide involves removing the rear glass cover; you will need replacement adhesive to reattach the back cover when you’re done.
필요한 것
Switch off your phone.
Prepare an iOpener for softening the adhesive on the back of the Note8.
Apply the iOpener on the back of the Note8 along the side with the power button.
Use a suction handle to lift the back cover and create an opening pick to get in the gap.
Start at the middle of the side and cut the adhesive while pulling up with the suction handle.
Move the pick towards the bottom corner and leave it there to keep the adhesive from resealing to the case.
Use another pick and move it to the top corner.
I used an X-acto knife with the flat blade to get it started. I tried using the suction cup - but it’s difficult to get good leverage. Once I got the cover started - I used the metal pry tool (sharpened with a dremel file) and a business card to work it open.
This is definitely the hardest part.
Once off I see all the glue on the curved part of the chassis NOTON THE BACK. Apply heat to curved edges.
Lyle Walsh - 답글
When the adhesive has been separated on all three sides properly you will be able to slowly lift the back cover.
Pay attention to the fingerprint sensor connector when flipping the back cover open. You might need to disconnect it as described in the next step.
I broke the back camera cover for the NUT 8 and then I bought a commercial cover and installed it but the quality of the picture became very bad and my question is, do you know where to get the original cover at a reasonable price?
don't skip disconnecting the sensor, even if isn't still glued to the case. it has to move away from the NFC/charging coil assembly in order to free the latter so it can be lifted away from the battery.
Remove the back cover.
How do you swap the fingerprint sensor
Lukus Carr - 답글
You can use a tweezer to swap the fingerprint sensor, you might be careful when doing the step 6, additionally, a tweezer will be helpful when reassemble the fingerprint sensor. please note that your new back cover needs to have the fingerprint adhesive on. most of the product did not have. i have get a LUVSS brand from amazon which came with all OEM adhesive and full set tools, even a B6000 glue, best option to go for replacing the note 8 back glass
Use an opening pick at the top edge to get between the NFC antenna and charging coil assembly and the case.
Lever the top of the assembly out of the case.
Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive beneath the battery. Reheat and reapply the iOpener as needed.
Alternatively or when the battery is blown up, you can apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for several minutes to help weaken the adhesive.
Isopropyl alcohol worked great but flooded the main board and took all night to dry out
Lyle Walsh - 답글
Use the flat end of a spudger to pry up the battery from the top right corner.
Use the spudger to pry up the battery until you can insert an opening pick to prevent the adhesive from resealing.
I really think this is much less risky if you just take out the motherboard. There is much less risk to heat the other components when you are loosening the battery adhesive and you can be more rough when getting the battery out. Especially (but not exclusively) if you are changing the screen anyway. Should be after step 29.
Additionally, I went at the battery from the side with a credit card and prying out the battery evenly across the length of the battery. I was even able to make a ‘ridge-peek’ from the card and screen and heat it from above while pushing down on the card and prying at eh same time. I got it out without any battery deformation. I would get one of those flat credit card shaped tools if I did it again because the credit card deformed and I had to keep flipping it.
Didn’t need to heat or use alcohol to get the battery out - just gently kept prying. I used the metal pry tool that came with the battery replacement tool kit. But very careful not to puncture the old battery.
Lift the battery out of the case.
Remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
do you mean when replacing display the battery should also be replaced?
Hi John,
Since you can replace the display without removing the battery, you do not need to replace the battery.
Great guide!
Quick note. If you are changing out the back cover or cant get touch ID reconnected Warm it up some on the back cover. It should pop right off with a spudger. Then reattach it inside the phone. Make sure the adhesive on back cover is sticky enough to hold it in place. Then set back cover on top!
jake765111 - 답글
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place for 5-10 seconds.
To reassemble your device, follow these instructions in reverse order, replacing the adhesive where needed.
If possible, turn on your phone and test your repair before closing and sealing up the phone.
For best results, when your repair is complete, calibrate your newly-installed battery.
다른 68명이 해당 안내서를 완성하였습니다.
댓글 10개
Awesome fix. Do you have anything for the front glass replacements by chance? I want to do both at the same time
Rick Moore - 답글
For those wondering how to apply the replacement adhesive, there is a video on the iFixit YouTube channel about installing adhesive on Samsung devices. Its a bit generic, but it points you in the right direction.
Hi Christopher,
I’ve edited the last step to include some adhesive guides! Hope that helps!
Thanks!! Very good detail. I was able to get the back cover off and replace the battery - the phone is working like a champ!
Would it be possible to augment the mAh? instead of 3300 mAh giving a little bit more power?
I think there is a 3rd party manufacturer who sells 3600mAh instead of 3300 so I guess yes.
How do you PUT IT BACK TOGETHER? especially the fingerprint scanner part?
Titan Rock - 답글
The fingerprint can be a tricky maneuver! Align the connector carefully over the socket, and use your finger or the flat end of a spudger to press it in place. It may take a few tries. Patience is key!
Does any one know how undo what I did after following above instructions to replace battery?
I see some dead pixel and cracked back panel :(
thank you Tobias
I used a heat gun to soften the glue - worked it around the edges, moving the heat gun quickly. As this is my first attempt, I’m still calibrating on this - but other guides mention getting the back cover hot enough so as it’s just too hot to touch. I also have a temp probe on my multi-meter, and I measured appx. 75 deg. C.
One of the other guides showed using a electronics hot plate set to 105 deg C for 60 sec.
Phil Brooks - 답글
