주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy S20+ Back Cover Replacement
필요한 것
  1. Samsung Galaxy S20+ Back Cover Replacement, Heat the bottom edge: 1 단계, 이미지 1개 중 1개
    • Unplug and power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    댓글 쓰기
  2. Samsung Galaxy S20+ Back Cover Replacement, Separate the bottom edge adhesive: 2 단계, 이미지 3개 중 1개 Samsung Galaxy S20+ Back Cover Replacement, Separate the bottom edge adhesive: 2 단계, 이미지 3개 중 2개 Samsung Galaxy S20+ Back Cover Replacement, Separate the bottom edge adhesive: 2 단계, 이미지 3개 중 3개
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken glass.
    • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert the point of an opening pick into the gap.
    • Due to tight tolerances, this may take multiple attempts of reheating with the iOpener and separating with the suction cup before you get it right.
    • If you are having trouble creating a gap, apply more heat to the edge and try again.
    • Do not apply excessive force with the pick, or you risk cracking the back cover glass.
    댓글 쓰기
  3. Samsung Galaxy S20+ Back Cover Replacement: 3 단계, 이미지 3개 중 1개 Samsung Galaxy S20+ Back Cover Replacement: 3 단계, 이미지 3개 중 2개 Samsung Galaxy S20+ Back Cover Replacement: 3 단계, 이미지 3개 중 3개
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Do not attempt to cut the adhesive near the corners of the phone where the glass is curved or you risk cracking the glass panel.
    • Leave your opening pick in the seam to prevent the adhesive from resealing.
    댓글 쓰기
  4. Samsung Galaxy S20+ Back Cover Replacement, Heat the left edge: 4 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
    댓글 쓰기
  5. Samsung Galaxy S20+ Back Cover Replacement, Separate the left edge adhesive: 5 단계, 이미지 3개 중 1개 Samsung Galaxy S20+ Back Cover Replacement, Separate the left edge adhesive: 5 단계, 이미지 3개 중 2개 Samsung Galaxy S20+ Back Cover Replacement, Separate the left edge adhesive: 5 단계, 이미지 3개 중 3개
    • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
    • As the glass on this edge is curved, you won't be able to insert this pick very far. As long as the very tip of the pick is underneath the glass's edge, you will be able to proceed.
    • Due to tight tolerances, this may take multiple attempts.
    • You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
    댓글 쓰기
  6. Samsung Galaxy S20+ Back Cover Replacement: 6 단계, 이미지 2개 중 1개 Samsung Galaxy S20+ Back Cover Replacement: 6 단계, 이미지 2개 중 2개
    • Once the pick is underneath the glass's edge, tilt it downward and insert it further to fully separate the back cover's adhesive.
    댓글 쓰기
  7. Samsung Galaxy S20+ Back Cover Replacement: 7 단계, 이미지 3개 중 1개 Samsung Galaxy S20+ Back Cover Replacement: 7 단계, 이미지 3개 중 2개 Samsung Galaxy S20+ Back Cover Replacement: 7 단계, 이미지 3개 중 3개
    • Slide the pick all along the left edge of the phone to separate the back cover's adhesive.
    • Take care when sliding across the ridge in the frame surrounding the volume and power buttons—the cutout in the glass may make it more prone to cracking.
    • Leave your pick under the left edge of the glass to prevent the adhesive from resealing.
    댓글 쓰기
  8. Samsung Galaxy S20+ Back Cover Replacement, Heat the right edge: 8 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the right edge of the back cover for two minutes.
    댓글 쓰기
  9. Samsung Galaxy S20+ Back Cover Replacement, Separate the right edge adhesive: 9 단계, 이미지 3개 중 1개 Samsung Galaxy S20+ Back Cover Replacement, Separate the right edge adhesive: 9 단계, 이미지 3개 중 2개 Samsung Galaxy S20+ Back Cover Replacement, Separate the right edge adhesive: 9 단계, 이미지 3개 중 3개
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
    • Like with the previous edge, you will need to tilt the opening pick downward to fully insert it underneath the back cover.
    댓글 쓰기
  10. Samsung Galaxy S20+ Back Cover Replacement: 10 단계, 이미지 3개 중 1개 Samsung Galaxy S20+ Back Cover Replacement: 10 단계, 이미지 3개 중 2개 Samsung Galaxy S20+ Back Cover Replacement: 10 단계, 이미지 3개 중 3개
    • Slide the pick all along the right edge of the phone to separate the back cover's adhesive.
    • Leave your pick under the right edge of the glass near the top of the device to prevent the adhesive from resealing.
    • As you do this, the back cover may release one or both of the other picks and allow them to fall free. If this occurs, set the pick(s) aside as the bottom edge shouldn't reseal from this point onward.
    댓글 쓰기
  11. Samsung Galaxy S20+ Back Cover Replacement, Heat the top edge: 11 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the top edge of the back cover for two minutes.
    댓글 쓰기
  12. Samsung Galaxy S20+ Back Cover Replacement, Separate the top edge adhesive: 12 단계, 이미지 3개 중 1개 Samsung Galaxy S20+ Back Cover Replacement, Separate the top edge adhesive: 12 단계, 이미지 3개 중 2개 Samsung Galaxy S20+ Back Cover Replacement, Separate the top edge adhesive: 12 단계, 이미지 3개 중 3개
    • The glass near the corners of the back cover is curved and very susceptible to cracking. Be gentle during this step to prevent damaging your back cover.
    • Gradually slide the pick from the right edge of the device around the top right corner.
    • Continue slicing along the top edge all the way around to the left edge to fully separate the back cover adhesive.
    • If the slicing becomes difficult at any point, stop and reapply heat before continuing.
    댓글 쓰기
  13. Samsung Galaxy S20+ Back Cover Replacement, Remove the back cover: 13 단계, 이미지 2개 중 1개 Samsung Galaxy S20+ Back Cover Replacement, Remove the back cover: 13 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
    댓글 쓰기
결론
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
취소: 해당 안내서를 완성하지 않았습니다.
다른 15명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Tarun Thiruma
회원 가입일: 11/20/19
40,423 평판
안내서 134개를 작성함
1가이드 댓글
Does the back glass also work for the s20+5g?
Doubs - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 38
지난 30일: 189
전체 시간: 26,513
