주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement
필요한 것
  1. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Eject the SIM tray: 1 단계, 이미지 2개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Eject the SIM tray: 1 단계, 이미지 2개 중 2개
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the hole on the SIM tray, located at the top edge of the phone next to the plastic antenna band.
    • If you inserted the tool into the other hole, don't worry—the microphone and the ingress gasket are mounted out of harm's way.
    • Press in firmly to eject the tray.
    댓글 쓰기
  2. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the SIM tray: 2 단계, 이미지 2개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the SIM tray: 2 단계, 이미지 2개 중 2개
    • Remove the SIM card tray.
    • The SIM card will fall out of the tray easily.
    • When you reinsert the SIM card, ensure that it is in the proper orientation relative to the tray.
    • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your phone's internal components.
    댓글 쓰기
  3. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Heat the bottom edge: 3 단계, 이미지 1개 중 1개
    • Unplug and power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    댓글 쓰기
  4. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the bottom edge adhesive: 4 단계, 이미지 3개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the bottom edge adhesive: 4 단계, 이미지 3개 중 2개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the bottom edge adhesive: 4 단계, 이미지 3개 중 3개
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken glass.
    • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert the point of an opening pick into the gap.
    • Due to tight tolerances, this may take multiple attempts of reheating with the iOpener and separating with the suction cup before you get it right.
    • If you are having trouble creating a gap, apply more heat to the edge and try again.
    • Do not apply excessive force with the pick, or you risk cracking the back cover glass.
    댓글 쓰기
  5. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: 5 단계, 이미지 3개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: 5 단계, 이미지 3개 중 2개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: 5 단계, 이미지 3개 중 3개
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Do not attempt to cut the adhesive near the corners of the phone where the glass is curved or you risk cracking the glass panel.
    • Leave your opening pick in the seam to prevent the adhesive from resealing.
    댓글 쓰기
  6. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Heat the left edge: 6 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
    댓글 쓰기
  7. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the left edge adhesive: 7 단계, 이미지 3개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the left edge adhesive: 7 단계, 이미지 3개 중 2개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the left edge adhesive: 7 단계, 이미지 3개 중 3개
    • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
    • As the glass on this edge is curved, you won't be able to insert this pick very far. As long as the very tip of the pick is underneath the glass's edge, you will be able to proceed.
    • Due to tight tolerances, this may take multiple attempts.
    • You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
    댓글 쓰기
  8. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: 8 단계, 이미지 2개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: 8 단계, 이미지 2개 중 2개
    • Once the pick is underneath the glass's edge, tilt it downward and insert it further to fully separate the back cover's adhesive.
    댓글 쓰기
  9. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: 9 단계, 이미지 3개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: 9 단계, 이미지 3개 중 2개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: 9 단계, 이미지 3개 중 3개
    • Slide the pick all along the left edge of the phone to separate the back cover's adhesive.
    • Take care when sliding across the ridge in the frame surrounding the volume and power buttons—the cutout in the glass may make it more prone to cracking.
    • Leave your pick under the left edge of the glass to prevent the adhesive from resealing.
    댓글 쓰기
  10. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Heat the right edge: 10 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the right edge of the back cover for two minutes.
    댓글 쓰기
  11. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the right edge adhesive: 11 단계, 이미지 3개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the right edge adhesive: 11 단계, 이미지 3개 중 2개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the right edge adhesive: 11 단계, 이미지 3개 중 3개
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
    • Like with the previous edge, you will need to tilt the opening pick downward to fully insert it underneath the back cover.
    댓글 쓰기
  12. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: 12 단계, 이미지 3개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: 12 단계, 이미지 3개 중 2개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: 12 단계, 이미지 3개 중 3개
    • Slide the pick all along the right edge of the phone to separate the back cover's adhesive.
    • Leave your pick under the right edge of the glass near the top of the device to prevent the adhesive from resealing.
    • As you do this, the back cover may release one or both of the other picks and allow them to fall free. If this occurs, set the pick(s) aside as the bottom edge shouldn't reseal from this point onward.
    댓글 쓰기
  13. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Heat the top edge: 13 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the top edge of the back cover for two minutes.
    댓글 쓰기
  14. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the top edge adhesive: 14 단계, 이미지 3개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the top edge adhesive: 14 단계, 이미지 3개 중 2개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the top edge adhesive: 14 단계, 이미지 3개 중 3개
    • The glass near the corners of the back cover is curved and very susceptible to cracking. Be gentle during this step to prevent damaging your back cover.
    • Gradually slide the pick from the right edge of the device around the top right corner.
    • Continue slicing along the top edge all the way around to the left edge to fully separate the back cover adhesive.
    • If the slicing becomes difficult at any point, stop and reapply heat before continuing.
    댓글 쓰기
  15. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the back cover: 15 단계, 이미지 2개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the back cover: 15 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
    댓글 쓰기
  16. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Unfasten the motherboard bracket: 16 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Use a Phillips #00 screwdriver to remove the six 4 mm-long screws securing the motherboard bracket.
    댓글 쓰기
  17. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Unclip the motherboard bracket: 17 단계, 이미지 3개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Unclip the motherboard bracket: 17 단계, 이미지 3개 중 2개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Unclip the motherboard bracket: 17 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the plastic midframe.
    • Do not completely remove the bracket yet, as its still attached to the wireless charging coil.
    댓글 쓰기
  18. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: 18 단계, 이미지 3개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: 18 단계, 이미지 3개 중 2개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: 18 단계, 이미지 3개 중 3개
    • Gently tilt up the motherboard bracket so the orange battery connector is accessible.
    댓글 쓰기
  19. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the battery: 19 단계, 이미지 2개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the battery: 19 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the battery connector.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    댓글 쓰기
  20. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the wireless charging coil: 20 단계, 이미지 2개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the wireless charging coil: 20 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the wireless charging coil connector.
    댓글 쓰기
  21. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the wireless charging coil: 21 단계, 이미지 3개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the wireless charging coil: 21 단계, 이미지 3개 중 2개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the wireless charging coil: 21 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to gently peel the wireless charging coil away from the device.
    • Remove the wireless charging coil.
    • During reassembly, first reconnect the charging coil and battery connectors and refasten the motherboard bracket screws to properly align everything into place, then firmly press the coil pad down to adhere it.
    댓글 쓰기
  22. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Unfasten the lower midframe: 22 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the five 4 mm-long screws securing the loudspeaker and lower midframe.
    댓글 쓰기
  23. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the loudspeaker: 23 단계, 이미지 3개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the loudspeaker: 23 단계, 이미지 3개 중 2개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the loudspeaker: 23 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Insert the point of a spudger or a pair of tweezers into the notch in the top left corner of the midframe and pry up to release the clips holding it in place.
    • Remove the loudspeaker and lower midframe.
    댓글 쓰기
  24. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the daughterboard: 24 단계, 이미지 3개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the daughterboard: 24 단계, 이미지 3개 중 2개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the daughterboard: 24 단계, 이미지 3개 중 3개
    • Use a spudger to pry up and disconnect the main and auxiliary flex cables from the daughterboard near the bottom of the device.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    댓글 쓰기
  25. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the main flex cables: 25 단계, 이미지 3개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the main flex cables: 25 단계, 이미지 3개 중 2개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the main flex cables: 25 단계, 이미지 3개 중 3개
    • Use a spudger to pry up and disconnect the main and auxiliary flex cables from the motherboard.
    댓글 쓰기
  26. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the main flex cables: 26 단계, 이미지 2개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the main flex cables: 26 단계, 이미지 2개 중 2개
    • Gently peel up and remove the main and auxiliary flex cables.
    댓글 쓰기
  27. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the left 5G antenna: 27 단계, 이미지 2개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the left 5G antenna: 27 단계, 이미지 2개 중 2개
    • Pry up and disconnect the left 5G antenna cable from the motherboard.
    댓글 쓰기
  28. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the main display cable: 28 단계, 이미지 2개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the main display cable: 28 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the main display flex cable from the motherboard.
    댓글 쓰기
  29. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Reposition the display and 5G cables: 29 단계, 이미지 3개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Reposition the display and 5G cables: 29 단계, 이미지 3개 중 2개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Reposition the display and 5G cables: 29 단계, 이미지 3개 중 3개
    • Gently peel up and bend the display and left 5G antenna flex cables out of the way of the motherboard and battery.
    댓글 쓰기
  30. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Unfasten the upper midframe: 30 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the three 4 mm-long screws securing the upper midframe.
    댓글 쓰기
  31. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the upper midframe: 31 단계, 이미지 3개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the upper midframe: 31 단계, 이미지 3개 중 2개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the upper midframe: 31 단계, 이미지 3개 중 3개
    • Insert the point of a spudger into the notch on the right side of the upper midframe and pry up to release the clips holding it into place.
    • Remove the upper midframe.
    댓글 쓰기
  32. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the right 5G antenna: 32 단계, 이미지 3개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the right 5G antenna: 32 단계, 이미지 3개 중 2개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the right 5G antenna: 32 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a spudger to pry up and disconnect the right 5G antenna flex cable from the motherboard.
    • Use a pair of tweezers to bend the cable out of the way of the motherboard.
    댓글 쓰기
  33. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the side button cable: 33 단계, 이미지 3개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the side button cable: 33 단계, 이미지 3개 중 2개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the side button cable: 33 단계, 이미지 3개 중 3개
    • Pry up and disconnect the side button flex cable from the motherboard.
    • Bend the cable out of the way of the motherboard.
    댓글 쓰기
  34. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the front facing camera: 34 단계, 이미지 3개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the front facing camera: 34 단계, 이미지 3개 중 2개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the front facing camera: 34 단계, 이미지 3개 중 3개
    • Pry up and disconnect the front facing camera flex cable from the motherboard.
    댓글 쓰기
  35. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the upper 5G antenna: 35 단계, 이미지 2개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the upper 5G antenna: 35 단계, 이미지 2개 중 2개
    • Pry up and disconnect the upper 5G antenna cable from the motherboard.
    댓글 쓰기
  36. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the upper 5G antenna: 36 단계, 이미지 3개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the upper 5G antenna: 36 단계, 이미지 3개 중 2개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the upper 5G antenna: 36 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to pry up the corner of the 5G millimeter wave antenna module.
    • The module is secured with a bit of adhesive, but should release easily.
    • Remove the 5G antenna module.
    • During reassembly, reconnect the 5G antenna connector first to properly align it into place, then firmly press the rest of the antenna module down to adhere it.
    댓글 쓰기
  37. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Unfasten the motherboard assembly: 37 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the two screws securing the motherboard and camera assembly.
    • One 4 mm-long screw
    • One 3.4 mm-long screw
    댓글 쓰기
  38. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the motherboard assembly: 38 단계, 이미지 3개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the motherboard assembly: 38 단계, 이미지 3개 중 2개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the motherboard assembly: 38 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger into the bottom left corner of the motherboard assembly and pry up to release it from the phone body.
    • Remove the motherboard assembly.
    댓글 쓰기
  39. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the ultra wide camera module: 39 단계, 이미지 3개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the ultra wide camera module: 39 단계, 이미지 3개 중 2개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the ultra wide camera module: 39 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to pry up and disconnect the ultrawide camera connector from the motherboard.
    • Remove the ultrawide camera module.
    • The module is lightly secured to the other cameras' frame via a small post, but you should be able to wiggle it free easily.
    댓글 쓰기
  40. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the remaining cameras: 40 단계, 이미지 3개 중 1개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the remaining cameras: 40 단계, 이미지 3개 중 2개 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the remaining cameras: 40 단계, 이미지 3개 중 3개
    • Use a spudger to pry up and disconnect the telephoto and wide-angle camera connector from the motherboard.
    • Pry up and disconnect the depth sensor.
    댓글 쓰기
  41. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the rear facing camera module: 41 단계, 이미지 1개 중 1개
    • Remove the remaining rear facing camera module.
    댓글 쓰기
결론
After you've completed the repair, follow this guide to test your repair.
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Tarun Thiruma
회원 가입일: 11/20/19
40,462 평판
안내서 134개를 작성함
1가이드 댓글
It is more complicated than I expected. Dang it Samsung. Thanks for making and sharing the guide! The tip about not pressing on the center of the press connectors/Lego connectors is important sounding!
I feel that removing the speaker module and disconnecting the ribbon cables from that bottom module may be unnecessary. Is that true?
In my mind it is only necessary to disconnect the ribbon cables from the motherboard to free the motherboard.
A X - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 22
지난 30일: 96
전체 시간: 7,987
