주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy S9 Fingerprint Sensor Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Samsung Galaxy S9 Fingerprint Sensor Replacement, Rear Glass Removal: 1 단계, 이미지 1개 중 1개
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
    • You might need to reheat and reapply the iOpener several times during the removal procedure to get the adhesive warm enough to cut. Follow the iOpener instructions to avoid overheating.
    • The adhesive of the Samsung Galaxy S9 is very strong. A hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
    댓글 쓰기
  2. Samsung Galaxy S9 Fingerprint Sensor Replacement: 2 단계, 이미지 1개 중 1개
    • In the following steps, you'll be cutting through the adhesive securing the back cover.
    • The adhesive in the inside of the back cover is laid out as seen in the image.
    • You'll be slicing through the adhesive in the areas shown:
    • Thick portions of adhesive
    • Thin areas of adhesive
    • Avoid prying or slicing in this area, to protect the fingerprint sensor flex cable.
    댓글 쓰기
  3. Samsung Galaxy S9 Fingerprint Sensor Replacement: 3 단계, 이미지 3개 중 1개 Samsung Galaxy S9 Fingerprint Sensor Replacement: 3 단계, 이미지 3개 중 2개 Samsung Galaxy S9 Fingerprint Sensor Replacement: 3 단계, 이미지 3개 중 3개
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the back cover.
    • Lift the back cover's bottom edge with your suction cup, opening a slight gap between the back cover and the frame.
    • This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
    • Insert an opening pick in the gap you created and slide it to the bottom right corner.
    • Insert a second opening pick and slide it to the bottom left corner.
    • Insert a third opening pick to prevent the adhesive from resealing during the rest of the removal procedure.
    댓글 쓰기
  4. Samsung Galaxy S9 Fingerprint Sensor Replacement: 4 단계, 이미지 2개 중 1개 Samsung Galaxy S9 Fingerprint Sensor Replacement: 4 단계, 이미지 2개 중 2개
    • While inserting only the tip of the opening pick, slide it from the bottom left corner along the side to the top.
    • Slide the pick around the top corner and leave it there to prevent the adhesive from resealing.
    댓글 쓰기
  5. Samsung Galaxy S9 Fingerprint Sensor Replacement: 5 단계, 이미지 3개 중 1개 Samsung Galaxy S9 Fingerprint Sensor Replacement: 5 단계, 이미지 3개 중 2개 Samsung Galaxy S9 Fingerprint Sensor Replacement: 5 단계, 이미지 3개 중 3개
    • Slide the opening pick from the bottom right corner along the side to the top.
    • Apply more heat if the adhesive becomes hard to cut. During the removal process, the back cover is under tension all the time and is likely to break if the adhesive isn't softened enough.
    • Slide the opening pick around the corner and cut the remaining adhesive at the top of the phone.
    • Don't open the phone all the way yet. The fragile fingerprint sensor cable still connects the back cover to the motherboard.
    댓글 쓰기
  6. Samsung Galaxy S9 Fingerprint Sensor Replacement: 6 단계, 이미지 2개 중 1개 Samsung Galaxy S9 Fingerprint Sensor Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully lift the side of the rear glass where the volume button is located.
    • Use the edge of a spudger to pry up and disconnect the fingerprint sensor flex cable.
    댓글 쓰기
  7. Samsung Galaxy S9 Fingerprint Sensor Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the rear glass.
    • When reassembling follow this guide to replace the adhesive and reinstall the rear glass.
    • In case you want to replace your rear glass follow this guide to transfer the rear camera bezel including the fingerprint.
    댓글 쓰기
  8. Samsung Galaxy S9 Fingerprint Sensor Replacement, Fingerprint Sensor: 8 단계, 이미지 1개 중 1개
    • Heat up the iOpener in the microwave for 30-60 seconds.
    • Place the iOpener on the back cover for 2-3 minutes to heat up the adhesive holding the fingerprint sensor.
    • The iOpener may still be warm from earlier steps. You may not need to microwave it again.
    댓글 쓰기
  9. Samsung Galaxy S9 Fingerprint Sensor Replacement: 9 단계, 이미지 3개 중 1개 Samsung Galaxy S9 Fingerprint Sensor Replacement: 9 단계, 이미지 3개 중 2개 Samsung Galaxy S9 Fingerprint Sensor Replacement: 9 단계, 이미지 3개 중 3개
    • Carefully slide the Jimmy under the fingerprint sensor.
    • Peel off the fingerprint sensor from the back cover.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jonne Vicario
회원 가입일: 01/24/19
537 평판
안내서 3개를 작성함
Cal Poly, Team S1-G6, White Winter 2019 Cal Poly, Team S1-G6, White Winter 2019 회원
CPSU-WHITE-W19S1G6
4 회원들
안내서 38개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 50
전체 시간: 2,308
