주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung P241 Front Panel Button replacement
필요한 것
  1. Samsung P241 Front Panel Button replacement, Top Case: 1 단계, 이미지 2개 중 1개 Samsung P241 Front Panel Button replacement, Top Case: 1 단계, 이미지 2개 중 2개
    • You will need to be near a power source for this guide.
    • With the back of the DVD player facing you, remove the three 1 cm black screws on the right, left, and top sides using a Phillips #1 screwdriver.
    댓글 쓰기
  2. Samsung P241 Front Panel Button replacement: 2 단계, 이미지 2개 중 1개 Samsung P241 Front Panel Button replacement: 2 단계, 이미지 2개 중 2개
    • Pull the top cover towards you until you can lift it up and off.
    댓글 쓰기
  3. Samsung P241 Front Panel Button replacement, Front Panel: 3 단계, 이미지 2개 중 1개 Samsung P241 Front Panel Button replacement, Front Panel: 3 단계, 이미지 2개 중 2개
    • With the front of the DVD player facing you, turn the power on and eject the disc tray.
    • Press down on the disc tray with your thumbs while also pressing up with your pointer finger on the left and right edges of the silver cover. The cover should easily pop up and off the disc tray.
    • Be careful not to crack or bend the disc tray by pulling too hard.
    댓글 쓰기
  4. Samsung P241 Front Panel Button replacement: 4 단계, 이미지 3개 중 1개 Samsung P241 Front Panel Button replacement: 4 단계, 이미지 3개 중 2개 Samsung P241 Front Panel Button replacement: 4 단계, 이미지 3개 중 3개
    • To remove the front panel, lift up the clips on the bottom, left and right sides of the DVD player.
    • Be sure to have all clips lifted up at the same time otherwise it will be difficult to get the panel off.
    • If you are having trouble removing the panel, try wedging an object underneath the two clips on the bottom to keep them from falling back into place.
    댓글 쓰기
  5. Samsung P241 Front Panel Button replacement: 5 단계, 이미지 1개 중 1개
    • Gently remove the front panel by pulling it forward.
    댓글 쓰기
  6. Samsung P241 Front Panel Button replacement: 6 단계, 이미지 1개 중 1개
    • Press the eject button again to make the disc tray slide back into place.
    • Turn off the DVD player and unplug it from the wall before proceeding to further steps.
    댓글 쓰기
  7. Samsung P241 Front Panel Button replacement, Front Panel Buttons: 7 단계, 이미지 2개 중 1개 Samsung P241 Front Panel Button replacement, Front Panel Buttons: 7 단계, 이미지 2개 중 2개
    • Holding the front panel so the Samsung logo is visible, rotate the panel to view the opposite side.
    댓글 쓰기
  8. Samsung P241 Front Panel Button replacement: 8 단계, 이미지 2개 중 1개 Samsung P241 Front Panel Button replacement: 8 단계, 이미지 2개 중 2개
    • Locate the button panel on the inside towards what is now the right of the front panel.
    댓글 쓰기
  9. Samsung P241 Front Panel Button replacement: 9 단계, 이미지 1개 중 1개
    • To unjam a button, use a finger or flathead screwdriver, and firmly press against the jammed portion of the button panel.
    • Press until the button slides back into it's designated button slot.
    댓글 쓰기
  10. Samsung P241 Front Panel Button replacement: 10 단계, 이미지 1개 중 1개
    • If the button panel is broken, use a flathead screwdriver to pry the button panel from the back of the front panel.
    • With strong plastic adhesive, glue the new button panel into place with each button in it's designated button slot.
    • Allow the adhesive time to properly dry before pressing buttons.
    댓글 쓰기
  11. Samsung P241 Front Panel Button replacement: 11 단계, 이미지 1개 중 1개
    • If the button panel is not the cause of the problem, the button sensors on the motherboard need to be replaced.
    • You can refer to this guide for directions on how to solder new sensors on your motherboard if you don't want to replace the entire motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Matt Russell
회원 가입일: 01/14/11
116 평판
안내서 1개를 작성함
Cal Poly, Team 14-7, Forte Winter 2011 Cal Poly, Team 14-7, Forte Winter 2011 회원
CPSU-FORTE-W11S14G7
5 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 22
전체 시간: 1,522
