주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker)
필요한 것
  1. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Unplug your refrigerator: 1 단계, 이미지 1개 중 1개
    • Unplug your refrigerator before you begin your repair.
    댓글 쓰기
  2. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Open the freezer drawer: 2 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Open the freezer drawer: 2 단계, 이미지 2개 중 2개
    • Slide the freezer drawer fully open.
    댓글 쓰기
  3. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer bins: 3 단계, 이미지 3개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer bins: 3 단계, 이미지 3개 중 2개 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer bins: 3 단계, 이미지 3개 중 3개
    • Lift and remove all the freezer bins from the drawer.
    • You may need to open the refrigerator doors in order to remove the large bin.
    댓글 쓰기
  4. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer door: 4 단계, 이미지 3개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer door: 4 단계, 이미지 3개 중 2개 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer door: 4 단계, 이미지 3개 중 3개
    • A plastic tab locks each drawer rail in place.
    • Use a flathead screwdriver or your fingers to press in the plastic tab near the inner end of the drawer rail.
    • As you press the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
    댓글 쓰기
  5. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): 5 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): 5 단계, 이미지 2개 중 2개
    • Repeat the rail unlock procedure on the other drawer rail.
    • Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
    • Remove the freezer drawer.
    • To install the freezer drawer:
    • Push the geared torsion bar until it rests at the very end of the rails.
    • Align the drawer rails to the refrigerator wall guides.
    • Close the freezer drawer until the rails lock back in place.
    • If you don't hear a click, visually check if the plastic tabs have locked in place. You may need to push the rails in a little further with your fingers to set the tabs.
    댓글 쓰기
  6. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Unfasten the icemaker assembly: 6 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Unfasten the icemaker assembly: 6 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the screws securing the icemaker assembly to the freezer ceiling.
    댓글 쓰기
  7. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Disconnect the icemaker assembly: 7 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Disconnect the icemaker assembly: 7 단계, 이미지 2개 중 2개
    • Grasp the front edge of the icemaker assembly and tilt it downwards.
    • Don't try to remove the icemaker yet, as it's still connected by a few wires.
    댓글 쓰기
  8. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): 8 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): 8 단계, 이미지 2개 중 2개
    • Use your fingers to guide the wire harness out of the icemaker assembly.
    댓글 쓰기
  9. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): 9 단계, 이미지 3개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): 9 단계, 이미지 3개 중 2개 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): 9 단계, 이미지 3개 중 3개
    • Squeeze the icemaker cable connector and pull to disconnect it.
    댓글 쓰기
  10. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): 10 단계, 이미지 1개 중 1개
    • Remove the icemaker assembly.
    댓글 쓰기
결론
Repair didn’t go as planned? Ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
344,141 평판
안내서 915개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 32,107개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 29
지난 30일: 132
전체 시간: 2,184
