주요 콘텐츠로 건너뛰기
Skateboard Grip Tape Replacement
Violet Nichols
Violet Nichols3 다른 기여자
최종 수정일 June 8, 2023
20 - 45 분
쉬움
Grip tape is an essential part of any skateboard. Grip tape provides the rider with an ample amount of grip on their skateboard, but grip tape wears out. This guide aims to teach a skateboarder with any amount of experience how to change the grip tape on their skateboard. Grip tape should be changed whenever your feet begin to slip on the board, or when tricks such as ollies or kickflips become more difficult due to lack of grip.
필요한 것
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. Skateboard Grip Tape Replacement, Grip Tape: 1 단계, 이미지 3개 중 1개 Skateboard Grip Tape Replacement, Grip Tape: 1 단계, 이미지 3개 중 2개 Skateboard Grip Tape Replacement, Grip Tape: 1 단계, 이미지 3개 중 3개
    • Remove the bolts from your trucks using the 3/8 inch side of a skate tool and the included Phillips head screwdriver.
    • 22.225mm Phillips head screw. (These should be standard for most skateboards)
  2. Skateboard Grip Tape Replacement: 2 단계, 이미지 1개 중 1개
    • Use a hairdryer (on its highest setting) about three inches from the board to warm the glue of your old grip tape.
    • Heat the grip tape in a horizontal line pattern, making sure that the glue is soft before you begin peeling.
  3. Skateboard Grip Tape Replacement: 3 단계, 이미지 2개 중 1개 Skateboard Grip Tape Replacement: 3 단계, 이미지 2개 중 2개
    • Once the glue is warm on one end, peel the old grip tape off of the skateboard deck.
    • Peel the grip tape from one end of the board to the other.
    • Continue steps 2 and 3 down the length of the skateboard.
    • Take your time and heat all parts of the grip tape. This will help you remove the old grip tape in one large piece.
    • Heating the glue of the old grip tape thoroughly will help you remove it in one large piece.
  4. Skateboard Grip Tape Replacement: 4 단계, 이미지 3개 중 1개 Skateboard Grip Tape Replacement: 4 단계, 이미지 3개 중 2개 Skateboard Grip Tape Replacement: 4 단계, 이미지 3개 중 3개
    • Before peeling the backing off of the new grip tape, line up the grip tape with the deck to make sure it is centered and the correct size.
    • Once you are satisfied by the centering of the grip tape, peel the backing off of the old grip tape.
    • Apply the grip tape from one end to the other.
    • Press out as much air as possible while applying the grip tape to avoid forming air bubbles under the grip tape.
  5. Skateboard Grip Tape Replacement: 5 단계, 이미지 1개 중 1개
    • Once the new grip tape has been applied to the deck, use your box cutter to poke holes in any air bubbles that may have formed.
    • After poking holes in the air bubbles, press down the grip tape to make it flat, removing any excess air.
    • Exercise caution when handling/using a knife, and always keep it pointed away from yourself and others.
  6. Skateboard Grip Tape Replacement: 6 단계, 이미지 2개 중 1개 Skateboard Grip Tape Replacement: 6 단계, 이미지 2개 중 2개
    • Using the screwdriver that came with your skate tool, file the edges of the grip tape down to the board.
    • Make sure that the outline of the deck is visible on the grip tape to create a guideline for cutting off excess grip tape.
  7. Skateboard Grip Tape Replacement: 7 단계, 이미지 1개 중 1개
    • Following the outline of the deck created by filing the grip tape, cut the grip tape at one end using your Exacto knife/box cutter.
    • Take your time and try to cut the grip tape in long, continuous motions.
    • Exercise caution when handling/using a box cutter, and always keep it pointed away from yourself and others.
  8. Skateboard Grip Tape Replacement: 8 단계, 이미지 1개 중 1개
    • Use the leftover grip tape like sandpaper to smooth out the edges of the grip tape around the skateboard.
    • This step will make the grip tape stick to the board better, and will also remove some imperfections left from cutting the grip tape.
  9. Skateboard Grip Tape Replacement: 9 단계, 이미지 1개 중 1개
    • Use your screwdriver (or a truck bolt) to poke holes in the grip tape for your trucks.
  10. Skateboard Grip Tape Replacement: 10 단계, 이미지 3개 중 1개 Skateboard Grip Tape Replacement: 10 단계, 이미지 3개 중 2개 Skateboard Grip Tape Replacement: 10 단계, 이미지 3개 중 3개
    • Line up your trucks with their corresponding holes on the back of the board.
    • Place bolts through the board and truck holes, lightly screwing on the nuts.
    • Use the screwdriver and the skate tool to tighten truck nuts and bolts onto board.
결론
After making sure trucks are secured properly, and your brand new grip tape is nice and grippy you are ready to ride!
작성자
3다른 기여자 명과 함께
Violet Nichols
회원 가입일: 02/21/22
184 평판
안내서 1개를 작성함
댓글 한 개
You can clean your grip tape on a skateboard or longboard with a portion of sanding belt cleaner or the entire block. Holding the sanding belt cleaner, begin section-by-section rubbing it on your grip tape from top to bottom in a straight line. But pay attention to the locations of the bolts. Gently wipe these areas down.
Mark Daniels - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 27
전체 시간: 1,448
