주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Skullcandy Hesh 3 Battery Replacement
필요한 것
    1. Skullcandy Hesh 3 Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Skullcandy Hesh 3 Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Skullcandy Hesh 3 Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • Start by removing the earmuffs on the speaker side with the charging port. Gently pull from any point of the ear cushion, while also holding on to the base of the speaker.
      • Use a Phillips #00 screwdriver to remove all four 4.0 mm screws securing the faceplate.
      • Remove the faceplate gently without pulling off the wires attached to the speaker and faceplate.
      댓글 쓰기
    2. Skullcandy Hesh 3 Battery Replacement: 2 단계, 이미지 3개 중 1개 Skullcandy Hesh 3 Battery Replacement: 2 단계, 이미지 3개 중 2개 Skullcandy Hesh 3 Battery Replacement: 2 단계, 이미지 3개 중 3개
      • Use a soldering iron to heat up the solder at the points where the red, yellow, and black wires connect until they detach from the board.
      • Lastly, lift the board gently from the ear cup to reveal the battery underneath.
      댓글 쓰기
    3. Skullcandy Hesh 3 Battery Replacement: 3 단계, 이미지 3개 중 1개 Skullcandy Hesh 3 Battery Replacement: 3 단계, 이미지 3개 중 2개 Skullcandy Hesh 3 Battery Replacement: 3 단계, 이미지 3개 중 3개
      • Remove the battery being held by adhesive rubber with a spudger or your hands.
      • The battery should come out with minimal force as the adhesive is not very strong.
      • When replacing with the new battery, position it in the same spot with the 3 wires sticking out from the upper left-hand corner.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Emma Lyman
회원 가입일: 01/17/23
402 평판
안내서 4개를 작성함
2가이드 댓글
Useful but doesn't mention battery type or where or if you can buy replacement battery.
John Layne - 답글 공유
I’ve been searching the exact screw type of these because I lost 5 of them, does anyone know any specifics past 4.0 mm?
Kouroshghane - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 26
지난 30일: 103
전체 시간: 2,632
