주요 콘텐츠로 건너뛰기
Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement
Tong Tang
Tong Tang4 다른 기여자
최종 수정일 September 4, 2019
10 분
조정
In order to reach the flash capacitor, you have to remove the front and back panel, the button board and the top cover of the device. Be very careful when you remove these parts.
필요한 것
도구
  1. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Slide the lock at the bottom of the camera to "Open".
    • The door to the battery pack is spring loaded.
  2. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the blue clip up and away from the battery.
  3. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the battery.
  4. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Front and Back Panel: 4 단계, 이미지 3개 중 1개 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Front and Back Panel: 4 단계, 이미지 3개 중 2개 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Front and Back Panel: 4 단계, 이미지 3개 중 3개
    • Remove the six 3.5mm Phillips #000 screws.
    • Rotate the lock away from the camera.
  5. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: 5 단계, 이미지 3개 중 1개 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: 5 단계, 이미지 3개 중 2개 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: 5 단계, 이미지 3개 중 3개
    • Pry the device open with the plastic opening tool.
    • There are two clips that help prevent the front panel from separating.
  6. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: 6 단계, 이미지 3개 중 1개 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: 6 단계, 이미지 3개 중 2개 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the two plastic spacers between the front and the back panels.
    • The spacers may fall out when removing the panels.
    • Carefully remove the back panel.
  7. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Button Board: 7 단계, 이미지 2개 중 1개 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Button Board: 7 단계, 이미지 2개 중 2개
    • Gently release the button board from the clips.
    • Be careful when lifting the button board; the ribbon cable will still be attached.
  8. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: 8 단계, 이미지 2개 중 1개 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: 8 단계, 이미지 2개 중 2개
    • Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
  9. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Flash Capacitor: 9 단계, 이미지 3개 중 1개 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Flash Capacitor: 9 단계, 이미지 3개 중 2개 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Flash Capacitor: 9 단계, 이미지 3개 중 3개
    • Caution: Be careful not to touch the capacitor wires as you work. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • Lift the capacitor from the assembly.
    • Disconnect the no-fuss ribbon cable by gently pulling it out of the flash board.
결론
작성자
4다른 기여자 명과 함께
Tong Tang
회원 가입일: 09/15/16
590 평판
안내서 4개를 작성함
USF Tampa, Team 17-1, Blackwell Fall 2016 USF Tampa, Team 17-1, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S17G1
4 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 24
전체 시간: 1,028
