주요 콘텐츠로 건너뛰기
Sony MDR-1000X Battery Replacement
필요한 것
  1. Sony MDR-1000X Battery Replacement, Pry up the ear cup cushion: 1 단계, 이미지 1/2 Sony MDR-1000X Battery Replacement, Pry up the ear cup cushion: 1 단계, 이미지 2/2
    • The ear cup cushions of the Sony MDR-1000X are held in place by small plastic clips.
    • Insert a spudger into the gap between the right ear cup cushion and the headphone frame.
    • Lever the spudger downwards to pry up the ear cup cushion.
    • You should hear a little clack noise when the plastic clips pop open.
    • During reassembly make sure all six plastic clips snap back into place.
  2. Sony MDR-1000X Battery Replacement, Remove the ear cup cushion: 2 단계, 이미지 1/2 Sony MDR-1000X Battery Replacement, Remove the ear cup cushion: 2 단계, 이미지 2/2
    • Remove the ear cup cushion.
  3. Sony MDR-1000X Battery Replacement, Remove the protective cloth: 3 단계, 이미지 1/3 Sony MDR-1000X Battery Replacement, Remove the protective cloth: 3 단계, 이미지 2/3 Sony MDR-1000X Battery Replacement, Remove the protective cloth: 3 단계, 이미지 3/3
    • The protective cloth in the inside of the ear cups is glued to small foam spacers. These foam spacers are glued to the headphone frame with small pieces of adhesive tape. During the following step make sure to remove the protective cloth including the foam spacers and not to rip the cloth off them.
    • Carefully remove the protective cloth in the inside of the ear cup including the foam spacers.
  4. Sony MDR-1000X Battery Replacement, Unfasten the ear cup screws: 4 단계, 이미지 1/1
    • Remove the four 8.3 mm-long Phillips #00 screws securing the ear cup cover.
  5. Sony MDR-1000X Battery Replacement, Pry up the ear cup cover: 5 단계, 이미지 1/3 Sony MDR-1000X Battery Replacement, Pry up the ear cup cover: 5 단계, 이미지 2/3 Sony MDR-1000X Battery Replacement, Pry up the ear cup cover: 5 단계, 이미지 3/3
    • The ear cup cover is held in place by small plastic clips just like the ear cup cushions.
    • Insert a spudger into the gap between the ear cup cover and the headphone frame.
    • Lever down the spudger to pry up the ear cup cover and pop open the plastic clips.
    • Do not try to remove the ear cup cover all the way. It is still connected to the motherboard by a flex cable.
    • Carefully open the ear cup cover.
  6. Sony MDR-1000X Battery Replacement, Move the microphone cable: 6 단계, 이미지 1/2 Sony MDR-1000X Battery Replacement, Move the microphone cable: 6 단계, 이미지 2/2
    • Use a pair of blunt nose tweezers to carefully lift the microphone cable out of its routing.
  7. Sony MDR-1000X Battery Replacement, Remove the microphone: 7 단계, 이미지 1/2 Sony MDR-1000X Battery Replacement, Remove the microphone: 7 단계, 이미지 2/2
    • Use a pair of blunt nose tweezers to lift the microphone out of its recess.
  8. Sony MDR-1000X Battery Replacement, Block the battery contact: 8 단계, 이미지 1/2 Sony MDR-1000X Battery Replacement, Block the battery contact: 8 단계, 이미지 2/2
    • Insert an opening pick in between the bottom edge of the battery and the battery contact plate.
  9. Sony MDR-1000X Battery Replacement, Pry up the battery: 9 단계, 이미지 1/3 Sony MDR-1000X Battery Replacement, Pry up the battery: 9 단계, 이미지 2/3 Sony MDR-1000X Battery Replacement, Pry up the battery: 9 단계, 이미지 3/3
    • Insert a second opening pick between the right edge of the battery and the battery frame.
    • Try not to deform or puncture the battery during the following removal process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged.
    • Lever down the opening pick to pry up the battery. This might require a little bit force due to the battery adhesive underneath.
  10. Sony MDR-1000X Battery Replacement, Remove the battery: 10 단계, 이미지 1/2 Sony MDR-1000X Battery Replacement, Remove the battery: 10 단계, 이미지 2/2
    • Remove the battery.
    • You can reuse the old battery adhesive during reassembly. In case you decide to use new adhesive remove the old one first and clean the relevant areas with high isopropyl alcohol (>90%).
결론
If possible, turn on your device and test your repair before resealing.
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%
다른 5명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
204,217 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,218개 작성하였습니다
댓글 6개
Ugh…. I broke one of the gold pins attached to the red/white/black wires to the battery…. Does anyone know if there’s a fix or solution for that save for soldering?
At least I figured out it was the battery that was the initial issue! But now…. UGH.
Thank you so much for this guide, Dominik!
Kaldea Maeve - 답글
Hi Kaldea, I’m not sure which part you actually broke off but in case you’re fit in soldering you should be able to solder the cable back onto the pin. In case you broke the side which is in contact with the battery you need to find a replacement part for it. You might be lucky in a well sorted electronic or model making store.
Dominik Schnabelrauch -
I broke the pin too, wonder did you eventually find a way to fix it?
kc c - 답글
Thanks for the instructions. Repair went well and worked. I did notice those pins are touchy.
Bob - 답글
Yes, BE CAREFUL! I too broke one of the gold pins - they're not even pins, they're kind of folded metal foil, and very brittle. It snapped and although I put it back in place, I'm guessing it did not make a connection because the battery did not charge. I can't solder and don't have the equipment :-( So now I need to buy new headphones. Still it was worth a try.
Mister Rory2U - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 43
30일 전: 233
전체 시간: 9,822
