Sony NEX-5R Front Case Replacement
We will be teaching you the proper way to disassemble your Sony NEX-5R so that you can replace your front case. This will be helpful to those that have damaged the front case and are looking to fix it by themselves.
Open the battery pack door by moving the slider to "OPEN".
Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 한 개
Can anybody tell me where I can purchase the replacement part used in this video - Regards
Chris
