주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia Z1s Battery Replacement
필요한 것
    1. Sony Xperia Z1s Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Insert the opening pick in the crease between the rear cover and the body of the phone.
      • Pry along the edge to lift and remove the back cover.
      댓글 쓰기
    2. Sony Xperia Z1s Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Using the T4 Torx screwdriver, remove five 5 mm screws from the panel above the battery.
      • Remove the panel by grabbing its bottom edge and lifting upwards.
      댓글 쓰기
    3. Sony Xperia Z1s Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Use the opening pick to pry off the battery flex cable.
      댓글 쓰기
    4. Sony Xperia Z1s Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Using the T4 Torx screwdriver, remove two 5 mm screws from the bottom corners of the battery.
      댓글 쓰기
    5. Sony Xperia Z1s Battery Replacement: 5 단계, 이미지 1개 중 1개
      • Firmly press the suction cup onto the battery.
      • Pull the battery out using the suction handle.
      댓글 쓰기
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Matthew Klengson
회원 가입일: 09/30/21
324 평판
안내서 2개를 작성함
Clemson, Team 4-4, Hunter Fall 2021 Clemson, Team 4-4, Hunter Fall 2021 회원
CLEM-HUNTER-F21S4G4
5 회원들
안내서 35개를 작성함
1가이드 댓글
Step 1 - The gap is too small to simply use the pick. The suction tool also did not provide a big enough gap to get the pick in. In order to get the pick in I had to heat up the back and use the suction cup in order to get the pick. Then moved the pick around the perimeter to pull of the back. The battery was attached to the back with two glue strips. I unpluged the battery ribbon cable and got the glue off using the two pull tabs that were attached to the glue.
The rest of the steps were non existent in my case. Hope this reply helps
MrKoszmaro - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 32
전체 시간: 687
