주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Steam Deck Heatsink Replacement
필요한 것
  1. Steam Deck Heatsink Replacement, Prepare your Steam Deck for disassembly: 1 단계, 이미지 3개 중 1개 Steam Deck Heatsink Replacement, Prepare your Steam Deck for disassembly: 1 단계, 이미지 3개 중 2개 Steam Deck Heatsink Replacement, Prepare your Steam Deck for disassembly: 1 단계, 이미지 3개 중 3개
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down into its case to protect the thumbsticks and prevent wobble.
    댓글 쓰기
  2. Steam Deck Heatsink Replacement, Remove the back cover screws: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    FixMat
    $36.95
    • Use a Phillips driver to remove the eight screws securing the back cover:
    • Four coarse thread 9.5 mm-long screws
    • Four fine thread 5.8 mm-long screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the snuggest into the screw head.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your Steam Deck.
    댓글 쓰기
  3. Steam Deck Heatsink Replacement, Unclip the back cover: 3 단계, 이미지 2개 중 1개 Steam Deck Heatsink Replacement, Unclip the back cover: 3 단계, 이미지 2개 중 2개
    • Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
    • If you're having trouble inserting your pick at the grip seam, try starting at either the top or bottom long edges first, then slide the pick towards the grip.
    • Pry up on the back cover to release it from the locking clips.
    댓글 쓰기
  4. Steam Deck Heatsink Replacement, Remove the back cover: 4 단계, 이미지 3개 중 1개 Steam Deck Heatsink Replacement, Remove the back cover: 4 단계, 이미지 3개 중 2개 Steam Deck Heatsink Replacement, Remove the back cover: 4 단계, 이미지 3개 중 3개
    • Once the clips are disconnected from one edge, the rest disconnect easily.
    • Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
    • Remove the back cover.
    댓글 쓰기
  5. Steam Deck Heatsink Replacement, Uncover the hidden shield screw: 5 단계, 이미지 2개 중 1개 Steam Deck Heatsink Replacement, Uncover the hidden shield screw: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • If you have a refreshed Steam Deck version with the black motherboard cover, skip this step.
    • Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
    • If possible, try not to rip or tear this tape so it can be reused. If necessary, you can fashion a replacement by cutting a piece of aluminum foil tape to fit.
    댓글 쓰기
  6. Steam Deck Heatsink Replacement, Remove the shield screws: 6 단계, 이미지 2개 중 1개 Steam Deck Heatsink Replacement, Remove the shield screws: 6 단계, 이미지 2개 중 2개
    • Use a Phillips driver to remove the three screws securing the board shield:
    • One 3.4 mm screw
    • Two 3.7 mm screws
    • Only the two 3.7 mm screws along the left edge are present in refreshed Steam Decks.
    댓글 쓰기
  7. Steam Deck Heatsink Replacement, Remove the shield: 7 단계, 이미지 3개 중 1개 Steam Deck Heatsink Replacement, Remove the shield: 7 단계, 이미지 3개 중 2개 Steam Deck Heatsink Replacement, Remove the shield: 7 단계, 이미지 3개 중 3개
    • Remove the board shield.
    • Depending on the age of your Steam Deck, this shield may stick to the thermal pads underneath.
    • During reassembly, ensure that the fan cable lays on the side of the board shield and isn't pinched underneath.
    댓글 쓰기
  8. Steam Deck Heatsink Replacement, Disconnect the battery: 8 단계, 이미지 3개 중 1개 Steam Deck Heatsink Replacement, Disconnect the battery: 8 단계, 이미지 3개 중 2개 Steam Deck Heatsink Replacement, Disconnect the battery: 8 단계, 이미지 3개 중 3개
    • Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
    • Alternatively, use the flat end of a spudger or a clean fingernail to gently push the connector out of its socket, then disconnect it completely by hand.
    댓글 쓰기
  9. Steam Deck Heatsink Replacement, Remove the heatsink sticker: 9 단계, 이미지 3개 중 1개 Steam Deck Heatsink Replacement, Remove the heatsink sticker: 9 단계, 이미지 3개 중 2개 Steam Deck Heatsink Replacement, Remove the heatsink sticker: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the sticker from the top edge of the fan.
    • If possible, try not to rip or tear this sticker so it can be reused. Use a little bit of heat if necessary to soften the adhesive.
    • If the sticker feels like it might tear, use tweezers to peel up one edge just until you can grip it with your fingers, then remove the rest by hand.
    댓글 쓰기
  10. Steam Deck Heatsink Replacement, Remove the heatsink screws: 10 단계, 이미지 2개 중 1개 Steam Deck Heatsink Replacement, Remove the heatsink screws: 10 단계, 이미지 2개 중 2개
    • For original Steam Decks: Use a Phillips driver to loosen and remove the two screws securing the heatsink to the motherboard:
    • One captive 3.5 mm screw
    • One 3.4 mm screw
    • No, your eyes don't deceive you! The third heatsink screw was removed earlier in the disassembly: it doubles as the hidden board shield screw.
    • For refreshed Steam Decks: Use a Phillips driver to remove the three screws securing the heatsink to the motherboard:
    • Two 2.9 mm screws
    • One 3.7 mm screw
    • During reassembly on both versions, tighten these screws in order (1, 2, 3) as stamped into the heatsink.
    댓글 쓰기
  11. Steam Deck Heatsink Replacement, Remove the heatsink: 11 단계, 이미지 3개 중 1개 Steam Deck Heatsink Replacement, Remove the heatsink: 11 단계, 이미지 3개 중 2개 Steam Deck Heatsink Replacement, Remove the heatsink: 11 단계, 이미지 3개 중 3개
    • Lift and remove the heatsink.
    • Before reinstalling the heatsink, follow this guide to clean the heatsink and APU and reapply thermal paste.
    댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Carsten Frauenheim
회원 가입일: 03/10/20
167,302 평판
안내서 439개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 28,236개를 작성함
7가이드 댓글
This was incredibly easy. I changed the thermal past for some MX-4 and saw a 3-5 degree decrease and quieter fan speeds!
Josh Schwab - 답글 공유
When will iFixIt sell the heatsink itself? I want another just in case.
Robert Smith - 답글 공유
Great guide I used Thermal Grizzly Kryonaut temps drop 8 C
Fan is super quiet
jaybush74 - 답글 공유
Does anyone know the full marking for the black screw marked with an orange circle. Since the head was damaged when unscrewing it, I would have to order the same one. What is the correct label? Thank you.
Pet Detective - 답글 공유
Is the heat sink going to be sold? Instructions to replace but no replacement to buy...
beavis5706 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 20
지난 7일: 189
지난 30일: 925
전체 시간: 43,253
