주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Steam Deck Motherboard Replacement
필요한 것
  1. Steam Deck Motherboard Replacement, Prepare your Steam Deck for disassembly: 1 단계, 이미지 3개 중 1개 Steam Deck Motherboard Replacement, Prepare your Steam Deck for disassembly: 1 단계, 이미지 3개 중 2개 Steam Deck Motherboard Replacement, Prepare your Steam Deck for disassembly: 1 단계, 이미지 3개 중 3개
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down into its case to protect the thumbsticks and prevent wobble.
    댓글 쓰기
  2. Steam Deck Motherboard Replacement, Remove the back cover screws: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    FixMat
    $36.95
    • Use a Phillips driver to remove the eight screws securing the back cover:
    • Four coarse thread 9.5 mm-long screws
    • Four fine thread 5.8 mm-long screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the snuggest into the screw head.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your Steam Deck.
    댓글 쓰기
  3. Steam Deck Motherboard Replacement, Unclip the back cover: 3 단계, 이미지 2개 중 1개 Steam Deck Motherboard Replacement, Unclip the back cover: 3 단계, 이미지 2개 중 2개
    • Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
    • If you're having trouble inserting your pick at the grip seam, try starting at either the top or bottom long edges first, then slide the pick towards the grip.
    • Pry up on the back cover to release it from the locking clips.
    댓글 쓰기
  4. Steam Deck Motherboard Replacement, Remove the back cover: 4 단계, 이미지 3개 중 1개 Steam Deck Motherboard Replacement, Remove the back cover: 4 단계, 이미지 3개 중 2개 Steam Deck Motherboard Replacement, Remove the back cover: 4 단계, 이미지 3개 중 3개
    • Once the clips are disconnected from one edge, the rest disconnect easily.
    • Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
    • Remove the back cover.
    댓글 쓰기
  5. Steam Deck Motherboard Replacement, Uncover the hidden shield screw: 5 단계, 이미지 2개 중 1개 Steam Deck Motherboard Replacement, Uncover the hidden shield screw: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • If you have a refreshed Steam Deck version with the black motherboard cover, skip this step.
    • Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
    • If possible, try not to rip or tear this tape so it can be reused. If necessary, you can fashion a replacement by cutting a piece of aluminum foil tape to fit.
    댓글 쓰기
  6. Steam Deck Motherboard Replacement, Remove the shield screws: 6 단계, 이미지 2개 중 1개 Steam Deck Motherboard Replacement, Remove the shield screws: 6 단계, 이미지 2개 중 2개
    • Use a Phillips driver to remove the three screws securing the board shield:
    • One 3.4 mm screw
    • Two 3.7 mm screws
    • Only the two 3.7 mm screws along the left edge are present in refreshed Steam Decks.
    댓글 쓰기
  7. Steam Deck Motherboard Replacement, Remove the shield: 7 단계, 이미지 3개 중 1개 Steam Deck Motherboard Replacement, Remove the shield: 7 단계, 이미지 3개 중 2개 Steam Deck Motherboard Replacement, Remove the shield: 7 단계, 이미지 3개 중 3개
    • Remove the board shield.
    • Depending on the age of your Steam Deck, this shield may stick to the thermal pads underneath.
    • During reassembly, ensure that the fan cable lays on the side of the board shield and isn't pinched underneath.
    댓글 쓰기
  8. Steam Deck Motherboard Replacement, Disconnect the battery: 8 단계, 이미지 3개 중 1개 Steam Deck Motherboard Replacement, Disconnect the battery: 8 단계, 이미지 3개 중 2개 Steam Deck Motherboard Replacement, Disconnect the battery: 8 단계, 이미지 3개 중 3개
    • Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
    • Alternatively, use the flat end of a spudger or a clean fingernail to gently push the connector out of its socket, then disconnect it completely by hand.
    댓글 쓰기
  9. Steam Deck Motherboard Replacement, Remove the SSD screw: 9 단계, 이미지 1개 중 1개
    • Use a Phillips driver to remove the 3.4 mm screw securing the SSD.
    댓글 쓰기
  10. Steam Deck Motherboard Replacement, Remove the SSD: 10 단계, 이미지 2개 중 1개 Steam Deck Motherboard Replacement, Remove the SSD: 10 단계, 이미지 2개 중 2개
    • With the SSD screw removed, the SSD will pop up at a shallow angle.
    • Grip the end of the SSD and pull it away from its M.2 board connector to remove it.
    • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD screw.
    댓글 쓰기
  11. Steam Deck Motherboard Replacement, Remove the heatsink sticker: 11 단계, 이미지 3개 중 1개 Steam Deck Motherboard Replacement, Remove the heatsink sticker: 11 단계, 이미지 3개 중 2개 Steam Deck Motherboard Replacement, Remove the heatsink sticker: 11 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the sticker from the top edge of the fan.
    • If possible, try not to rip or tear this sticker so it can be reused. Use a little bit of heat if necessary to soften the adhesive.
    • If the sticker feels like it might tear, use tweezers to peel up one edge just until you can grip it with your fingers, then remove the rest by hand.
    댓글 쓰기
  12. Steam Deck Motherboard Replacement, Remove the heatsink screws: 12 단계, 이미지 2개 중 1개 Steam Deck Motherboard Replacement, Remove the heatsink screws: 12 단계, 이미지 2개 중 2개
    • For original Steam Decks: Use a Phillips driver to loosen and remove the two screws securing the heatsink to the motherboard:
    • One captive 3.5 mm screw
    • One 3.4 mm screw
    • No, your eyes don't deceive you! The third heatsink screw was removed earlier in the disassembly: it doubles as the hidden board shield screw.
    • For refreshed Steam Decks: Use a Phillips driver to remove the three screws securing the heatsink to the motherboard:
    • Two 2.9 mm screws
    • One 3.7 mm screw
    • During reassembly on both versions, tighten these screws in order (1, 2, 3) as stamped into the heatsink.
    댓글 쓰기
  13. Steam Deck Motherboard Replacement, Remove the heatsink: 13 단계, 이미지 3개 중 1개 Steam Deck Motherboard Replacement, Remove the heatsink: 13 단계, 이미지 3개 중 2개 Steam Deck Motherboard Replacement, Remove the heatsink: 13 단계, 이미지 3개 중 3개
    • Lift and remove the heatsink.
    • Before reinstalling the heatsink, follow this guide to clean the heatsink and APU and reapply thermal paste.
    댓글 쓰기
  14. Steam Deck Motherboard Replacement, Disconnect the fan: 14 단계, 이미지 2개 중 1개 Steam Deck Motherboard Replacement, Disconnect the fan: 14 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to grip the edges of the fan connector and pull up to disconnect it from the motherboard.
    • Pull the fan cable by its connector, not the wires themselves.
    댓글 쓰기
  15. Steam Deck Motherboard Replacement, Remove the Wi-Fi shield tape: 15 단계, 이미지 3개 중 1개 Steam Deck Motherboard Replacement, Remove the Wi-Fi shield tape: 15 단계, 이미지 3개 중 2개 Steam Deck Motherboard Replacement, Remove the Wi-Fi shield tape: 15 단계, 이미지 3개 중 3개
    • Use a pair of tweezers to peel up and remove the Wi-Fi shield tape.
    댓글 쓰기
  16. Steam Deck Motherboard Replacement, Disconnect the speakers: 16 단계, 이미지 2개 중 1개 Steam Deck Motherboard Replacement, Disconnect the speakers: 16 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to grip the edges of the speaker connector and pull up to disconnect it from the motherboard.
    • Pull the speaker cable by its connector, not the wires themselves.
    댓글 쓰기
  17. Steam Deck Motherboard Replacement, Disconnect the Wi-Fi: 17 단계, 이미지 3개 중 1개 Steam Deck Motherboard Replacement, Disconnect the Wi-Fi: 17 단계, 이미지 3개 중 2개 Steam Deck Motherboard Replacement, Disconnect the Wi-Fi: 17 단계, 이미지 3개 중 3개
    • The Wi-Fi module is located next to the SSD on refreshed Steam Decks.
    • Use a pair of tweezers to grip the antenna connector close to its base.
    • Pull straight up to disconnect the cable.
    • Repeat for the second antenna cable.
    • During reassembly, ensure that both antenna cables are reconnected at their appropriate connectors. The labels on the cables match the markings on the Wi-Fi module.
    • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
    댓글 쓰기
  18. Steam Deck Motherboard Replacement, Disconnect the display: 18 단계, 이미지 3개 중 1개 Steam Deck Motherboard Replacement, Disconnect the display: 18 단계, 이미지 3개 중 2개 Steam Deck Motherboard Replacement, Disconnect the display: 18 단계, 이미지 3개 중 3개
    • Use the pointed end of a spudger to lift up the small locking flap on the display cable's ZIF connector.
    • Use a pair of tweezers to slide the cable out of its connector.
    • Grip the cable by the pull tab, not by the cable itself.
    댓글 쓰기
  19. Steam Deck Motherboard Replacement, Disconnect the audio cable: 19 단계, 이미지 2개 중 1개 Steam Deck Motherboard Replacement, Disconnect the audio cable: 19 단계, 이미지 2개 중 2개
    • Refreshed Steam Decks don't have this audio cable. If you have a refreshed version, skip the next three steps.
    • Use the pointed end of a spudger to lift up the small locking flap on the audio cable's ZIF connector.
    댓글 쓰기
  20. Steam Deck Motherboard Replacement: 20 단계, 이미지 2개 중 1개 Steam Deck Motherboard Replacement: 20 단계, 이미지 2개 중 2개
    • Grip the cable by its pull tab, not by the cable itself.
    댓글 쓰기
  21. Steam Deck Motherboard Replacement: 21 단계, 이미지 3개 중 1개 Steam Deck Motherboard Replacement: 21 단계, 이미지 3개 중 2개 Steam Deck Motherboard Replacement: 21 단계, 이미지 3개 중 3개
    • Carefully peel the audio cable off of the battery.
    • The audio cable is secured to the battery with some light adhesive.
    • If the adhesive is stubborn, don't force the cable. Lightly heat the audio cable using an iOpener or a hair dryer to soften the adhesive.
    댓글 쓰기
  22. Steam Deck Motherboard Replacement, Disconnect the button board: 22 단계, 이미지 3개 중 1개 Steam Deck Motherboard Replacement, Disconnect the button board: 22 단계, 이미지 3개 중 2개 Steam Deck Motherboard Replacement, Disconnect the button board: 22 단계, 이미지 3개 중 3개
    • Use the pointed end of a spudger to lift up the small locking flap on the button board cable's ZIF connector.
    • Grip the cable by the blue pull tab, not by the cable itself.
    댓글 쓰기
  23. Steam Deck Motherboard Replacement, Remove the motherboard screws: 23 단계, 이미지 1개 중 1개
    • Use a Phillips driver to remove the three 3.7 mm screws securing the motherboard.
    댓글 쓰기
  24. Steam Deck Motherboard Replacement, Remove the motherboard: 24 단계, 이미지 3개 중 1개 Steam Deck Motherboard Replacement, Remove the motherboard: 24 단계, 이미지 3개 중 2개 Steam Deck Motherboard Replacement, Remove the motherboard: 24 단계, 이미지 3개 중 3개
    • Remove the motherboard.
    • The audio and button board cables attach to the underside of the motherboard with ZIF connectors.
    댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Carsten Frauenheim
회원 가입일: 03/10/20
167,292 평판
안내서 439개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 28,226개를 작성함
18가이드 댓글
When will I be able to buy the motherboard?
Jing - 답글 공유
I would love the answer to this question as well. This is necessary!
SpectralFox - 답글 공유
What is the actual size of the screws (M1.6, M2 , M2.2) as this information would be helpful if someone was to lose a screw while carrying out a repair or re paste.
Luis Elias castro - 답글 공유
Why Can't I buy this accessory?
ziyang - 답글 공유
Could we change dram or apu on the motherboard or upgrade thé motherboard ? Cause it s just zen2 and rdn2 .we need better performance and power !!!!
lapartdesanges50 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 50
지난 7일: 321
지난 30일: 1,811
전체 시간: 98,800
