SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement
If the headphone jack is damaged or the headset is not longer outputting sound, you might need to replace the 3.5mm audio jack. Follow this guide to safely access and remove the audio jack.
Lift the edge of the cushion and slightly pull out.
Work your way around the cushion until it comes off.
Repeat for the other cushion.
다른 5명이 해당 안내서를 완성하였습니다.
1가이드 댓글
hey @juangonzal87030 I am unable to take out circuit board out of my Arctic Wireless Pro even even when all the screws are taken out. I am unable to understand what am I missing over here. Can you help
