주요 콘텐츠로 건너뛰기
SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement
Juan Gonzalez
Juan Gonzalez4 다른 기여자
최종 수정일 June 29, 2022
25 - 35 분
어려움
If the headphone jack is damaged or the headset is not longer outputting sound, you might need to replace the 3.5mm audio jack. Follow this guide to safely access and remove the audio jack.
필요한 것
도구
  1. SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement, 3.5mm Headphone Jack: 1 단계, 이미지 2개 중 1개 SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement, 3.5mm Headphone Jack: 1 단계, 이미지 2개 중 2개
    • Lift the edge of the cushion and slightly pull out.
    • Work your way around the cushion until it comes off.
    • Repeat for the other cushion.
  2. SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the three 5mm screws with a Phillips #0 driver head on the headphone with the microphone.
  3. SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the speaker off the headset to expose the circuit board.
    • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
  4. SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the three 5mm screws using a Phillips #0 driver head.
  5. SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the circuit board out of the plastic housing.
    • Press in on the volume wheel while pulling on the circuit board to help maneuver the circuit board out of the housing.
  6. SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement: 6 단계, 이미지 2개 중 1개 SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement: 6 단계, 이미지 2개 중 2개
    • Desolder the three connecting audio jack leads from the circuit board.
    • For help desoldering connections, follow this useful guide on 연결부 납땜 및 납제거 방법.
    • Use caution when soldering. The heated tip may cause damage to the board or burn you.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Juan Gonzalez
회원 가입일: 01/24/19
422 평판
안내서 2개를 작성함
Cal Poly, Team S18-G1, White Winter 2019 Cal Poly, Team S18-G1, White Winter 2019 회원
CPSU-WHITE-W19S18G1
4 회원들
안내서 21개를 작성함
댓글 한 개
hey @juangonzal87030 I am unable to take out circuit board out of my Arctic Wireless Pro even even when all the screws are taken out. I am unable to understand what am I missing over here. Can you help
Ashutosh Kumar Singh - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 31
지난 30일: 70
전체 시간: 9,259
