주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Tagital T7X Screen/ Digitizer Replacement
필요한 것
  1. Tagital T7X Screen/ Digitizer Replacement, Case: 1 단계, 이미지 3개 중 1개 Tagital T7X Screen/ Digitizer Replacement, Case: 1 단계, 이미지 3개 중 2개 Tagital T7X Screen/ Digitizer Replacement, Case: 1 단계, 이미지 3개 중 3개
    • Place the Tagital T7X on a sturdy surface.
    • Insert the plastic opening tool into the crack and pry open the tablet. Move the tool along the edge, while continuing to pry up the casing.
    댓글 쓰기
  2. Tagital T7X Screen/ Digitizer Replacement, Battery: 2 단계, 이미지 2개 중 1개 Tagital T7X Screen/ Digitizer Replacement, Battery: 2 단계, 이미지 2개 중 2개
    • Follow the attached wires to the positive and negative connections.
    댓글 쓰기
  3. Tagital T7X Screen/ Digitizer Replacement: 3 단계, 이미지 3개 중 1개 Tagital T7X Screen/ Digitizer Replacement: 3 단계, 이미지 3개 중 2개 Tagital T7X Screen/ Digitizer Replacement: 3 단계, 이미지 3개 중 3개
    • The soldering iron can destroy components on the motherboard. Only touch the soldering iron to the solder already on the board.
    • Touch the tip of the soldering iron to the solder connecting the negative wire.
    • Pull back on the wire with the iron in place, removing it from the hot solder.
    • The solder will be melted almost instantly. There is no need to hold the iron on the solder for more than a second or two. Visit iFixit's soldering guide for more info.
    • Repeat this step for the positive wire.
    댓글 쓰기
  4. Tagital T7X Screen/ Digitizer Replacement: 4 단계, 이미지 3개 중 1개 Tagital T7X Screen/ Digitizer Replacement: 4 단계, 이미지 3개 중 2개 Tagital T7X Screen/ Digitizer Replacement: 4 단계, 이미지 3개 중 3개
    • Use the nylon spudger to pry the battery from the back of the screen. Work your way around the edges, similar to opening the casing.
    • The adhesive used to hold the battery down is very strong. Don't be afraid to use some force.
    댓글 쓰기
  5. Tagital T7X Screen/ Digitizer Replacement, Speaker: 5 단계, 이미지 3개 중 1개 Tagital T7X Screen/ Digitizer Replacement, Speaker: 5 단계, 이미지 3개 중 2개 Tagital T7X Screen/ Digitizer Replacement, Speaker: 5 단계, 이미지 3개 중 3개
    • Remove the ribbon cable on the top left corner of the mother board.
    • Gently lift the black tape up to see the ribbon cable socket.
    댓글 쓰기
  6. Tagital T7X Screen/ Digitizer Replacement: 6 단계, 이미지 3개 중 1개 Tagital T7X Screen/ Digitizer Replacement: 6 단계, 이미지 3개 중 2개 Tagital T7X Screen/ Digitizer Replacement: 6 단계, 이미지 3개 중 3개
    • Push both side buttons away from the socket by using a spudger.
    댓글 쓰기
  7. Tagital T7X Screen/ Digitizer Replacement: 7 단계, 이미지 2개 중 1개 Tagital T7X Screen/ Digitizer Replacement: 7 단계, 이미지 2개 중 2개
    • Gently pull the ribbon cable away from the socket.
    • Don't be afraid to use some force for this step.
    댓글 쓰기
  8. Tagital T7X Screen/ Digitizer Replacement: 8 단계, 이미지 2개 중 1개 Tagital T7X Screen/ Digitizer Replacement: 8 단계, 이미지 2개 중 2개
    • Touch the tip of the soldering iron to the solder connecting the positive (red) wire.
    • Repeat this step for the negative wire.
    • The solder will be melted almost instantly. There is no need to hold the iron on the solder for than a second or two. Visit IFixit's soldering guide for more info.
    댓글 쓰기
  9. Tagital T7X Screen/ Digitizer Replacement: 9 단계, 이미지 2개 중 1개 Tagital T7X Screen/ Digitizer Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the speaker from the motherboard.
    댓글 쓰기
  10. Tagital T7X Screen/ Digitizer Replacement, Camera: 10 단계, 이미지 3개 중 1개 Tagital T7X Screen/ Digitizer Replacement, Camera: 10 단계, 이미지 3개 중 2개 Tagital T7X Screen/ Digitizer Replacement, Camera: 10 단계, 이미지 3개 중 3개
    • Use a spudger to hold the cameras in place.
    • Gently pull the black tape away using your finger.
    댓글 쓰기
  11. Tagital T7X Screen/ Digitizer Replacement: 11 단계, 이미지 3개 중 1개 Tagital T7X Screen/ Digitizer Replacement: 11 단계, 이미지 3개 중 2개 Tagital T7X Screen/ Digitizer Replacement: 11 단계, 이미지 3개 중 3개
    • Remove the ribbon cable from the motherboard.
    • Use a spudger to lift the two tabs, freeing the ribbon cable from the socket.
    댓글 쓰기
  12. Tagital T7X Screen/ Digitizer Replacement: 12 단계, 이미지 3개 중 1개 Tagital T7X Screen/ Digitizer Replacement: 12 단계, 이미지 3개 중 2개 Tagital T7X Screen/ Digitizer Replacement: 12 단계, 이미지 3개 중 3개
    • Gently pull the ribbon cable away from the motherboard.
    • Don't be afraid to use some force to pull the ribbon cable.
    댓글 쓰기
  13. Tagital T7X Screen/ Digitizer Replacement, Motherboard: 13 단계, 이미지 2개 중 1개 Tagital T7X Screen/ Digitizer Replacement, Motherboard: 13 단계, 이미지 2개 중 2개
    • Next we will disconnect the digitizer ribbon cable from the motherboard.
    • Using the black spudger, gently push the tabs on each side of the socket to free the ribbon cable.
    댓글 쓰기
  14. Tagital T7X Screen/ Digitizer Replacement: 14 단계, 이미지 2개 중 1개 Tagital T7X Screen/ Digitizer Replacement: 14 단계, 이미지 2개 중 2개
    • Gently pull on the ribbon cable, separating it from the socket.
    댓글 쓰기
  15. Tagital T7X Screen/ Digitizer Replacement: 15 단계, 이미지 3개 중 1개 Tagital T7X Screen/ Digitizer Replacement: 15 단계, 이미지 3개 중 2개 Tagital T7X Screen/ Digitizer Replacement: 15 단계, 이미지 3개 중 3개
    • Next, we will unscrew the three PH#0 screws anchoring the motherboard into the case.
    • You will need the Phillips Screw #0 to remove the screws of the motherboard.
    • Using the screwdriver, with the PH#0 attachment, carefully unscrew the screws of the motherboard in order to remove it from the device.
    댓글 쓰기
  16. Tagital T7X Screen/ Digitizer Replacement, Screen/ Digitizer: 16 단계, 이미지 3개 중 1개 Tagital T7X Screen/ Digitizer Replacement, Screen/ Digitizer: 16 단계, 이미지 3개 중 2개 Tagital T7X Screen/ Digitizer Replacement, Screen/ Digitizer: 16 단계, 이미지 3개 중 3개
    • Insert a plastic opening tool where the screen connects with the front face of the case.
    • Use a spudger to keep the screen from falling back into the casing.
    • The screen will slide out once the connection has been nudged on three sides.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Garven Dabady
회원 가입일: 02/10/16
370 평판
안내서 2개를 작성함
USF Tampa, Team 2-1, Sullivan Spring 2016 USF Tampa, Team 2-1, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S2G1
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 25
전체 시간: 1,001
