주요 콘텐츠로 건너뛰기
Tefal Actifry Disassembly
Declan Green
Declan Green2 다른 기여자
최종 수정일 April 19, 2021
예상시간 없음
매우 쉬움
커뮤니티-기여 안내서
We are going to remove the bottom casing of the Tefal Actifry to replace the motor that turns the chips when cooking.
  1. Tefal Actifry Disassembly, Tefal Actifry Disassembly: 1 단계, 이미지 3개 중 1개 Tefal Actifry Disassembly, Tefal Actifry Disassembly: 1 단계, 이미지 3개 중 2개 Tefal Actifry Disassembly, Tefal Actifry Disassembly: 1 단계, 이미지 3개 중 3개
    • This is the Tefal Actifry as it would sit when being used. You will need to turn it upside down to see the three security screws that need to be removed. I have circled them in red here. The next photo shows a closeup of one of the screws.
  2. Tefal Actifry Disassembly: 2 단계, 이미지 3개 중 1개 Tefal Actifry Disassembly: 2 단계, 이미지 3개 중 2개 Tefal Actifry Disassembly: 2 단계, 이미지 3개 중 3개
    • Next remove the three screws and the little fan cover at top end of the unit. I gently prised it off with a butter knife. This allows the bottom plastic cover of the Actifty to come off, from the fan end first, then it slips over the lid release buttons and off.
  3. Tefal Actifry Disassembly: 3 단계, 이미지 3개 중 1개 Tefal Actifry Disassembly: 3 단계, 이미지 3개 중 2개 Tefal Actifry Disassembly: 3 단계, 이미지 3개 중 3개
    • The motor is now exposed with the bottom cover removed. There are two security screws, the same size as the ones on the outside cover that need removed. There are two wires that need removed from the old motor and inserted into the new motor. The new can be secured in place and tightened with the screws.
  4. Tefal Actifry Disassembly: 4 단계, 이미지 2개 중 1개 Tefal Actifry Disassembly: 4 단계, 이미지 2개 중 2개
    • When the wires are inserted snugly into the new motor and all is secure the bottom can be put back on the Actifry. Remember to slip it on in reverse of how you removed it. I had a little trouble getting it over the buttons, but it will with a little manipulation.
  5. Tefal Actifry Disassembly: 5 단계, 이미지 2개 중 1개 Tefal Actifry Disassembly: 5 단계, 이미지 2개 중 2개
    • I took my old motor apart to see why it wouldn't work. I discovered a circular magnet in the bottom, underneath the cogs etc. Upon closer inspection I seen it was cracked and a little pull and it came apart. It made it's way to the bin.
결론
다른 35명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Declan Green
회원 가입일: 05/02/14
1,083 평판
안내서 1개를 작성함
댓글 35개
Thank you for the great guide. I'd like to mention a few things I discovered disassembling my actifry while following your instructions:
* the screws on my unit were regular torx - ie not security torx which have the pin in the middle that require bits with a corresponding hollow hole.
* the fan cover is made of very brittle plastic and is easy to break when trying to pry off.
* the fan cover is held by 3 tabs at the 9, 3, and 12'o clock positions. It is easiest to pry from the the tabs at 9 and 3'o clock positions.
ifabri - 답글
Thank you!! I am not at all DIY minded. I ordered a part for £12 on amazon, founder a screwdriver in my husband's toolbox, and fixed my actifry in under 5 minutes. Fab guide thank you!
Angharad - 답글
Hi I've just fitted a new motor but now not getting hot. Do you think I need to replace element too? Also my friend has an actifry with same problem but can't find a motor for the model AL806240. Any ideas where she can get one. The wires seem to sit differently than mine. Thank you
Jean Hennedy - 답글
This is what is happening to mine. I have replaced the motor and now the actifry is not heating… did you find the solution? Thanks
l.z.macintyre -
Thanks, saved time figuring out exactly how to do it - though you need a couple of more pictures in the guide. I had to deform the case a bit in order to clear over the fan otherwise it cannot slip over the fan - people be careful not to stress the fan assembly: you should slide the case without touching the fan.
In my case, the security screws *just* got unscrewed by a not-security screwdriver bit so I just replaced them with normal philips ones on reassembly.
MiKa - 답글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 76
지난 30일: 417
전체 시간: 121,594
