주요 콘텐츠로 건너뛰기
Toshiba Satellite C660 Keyboard Replacement
ZFix
ZFix3 다른 기여자
최종 수정일 April 23, 2023
5 - 10 분
매우 쉬움
커뮤니티-기여 안내서
Keyboard replacement for Toshiba Satellite C660 - Video tutorial:
필요한 것
도구
더보기...
동영상 개요
  1. Toshiba Satellite C660 Keyboard Replacement, Keyboard replacement: 1 단계, 이미지 2개 중 1개 Toshiba Satellite C660 Keyboard Replacement, Keyboard replacement: 1 단계, 이미지 2개 중 2개
    • Remove the charger and the battery.
  2. Toshiba Satellite C660 Keyboard Replacement: 2 단계, 이미지 3개 중 1개 Toshiba Satellite C660 Keyboard Replacement: 2 단계, 이미지 3개 중 2개 Toshiba Satellite C660 Keyboard Replacement: 2 단계, 이미지 3개 중 3개
    • After removing the narrow plastic lid, you will see 4x Phillips screw.
  3. Toshiba Satellite C660 Keyboard Replacement: 3 단계, 이미지 3개 중 1개 Toshiba Satellite C660 Keyboard Replacement: 3 단계, 이미지 3개 중 2개 Toshiba Satellite C660 Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • Pick up the keyboard and disconnect the flex cable.
  4. Toshiba Satellite C660 Keyboard Replacement: 4 단계, 이미지 3개 중 1개 Toshiba Satellite C660 Keyboard Replacement: 4 단계, 이미지 3개 중 2개 Toshiba Satellite C660 Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    • Now connect the new Keyboard. It was very easy. :-)
결론
다른 12명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
194,093 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,699개를 작성함
댓글 5개
Hi there, Thank you very much.. please help me .. i broke that white plastic draw beneath the keyboard cable while was pushing it away to take the cable off .. what to do please?
Reef - 답글
You can put a piece of plaster tape to attach the tablecloth with the plug. Take a piece of chatertone (electric tape) to avoid short circuiting.
Hyperion - 답글
Abdelhamid Fathy Amer - 답글
Great stuff, I actually fixed my ancient and loved laptop, why is it loved? I hate Win 10 and have a new ASUS which is ace and super fast, but it is still Win 10 that I cannot get to grips with, but cannot restore the ASUS with Win 7. Thanks very much indeed
Don UK - 답글
I notice these instructions don't require removing HD & memory, which would seem to confirm it's not necessary to do so for a Toshiba Satelite L300, which is virtually the same as a C660 apart from not having a separate number pad.
Incidentally these instructions can also be for replacing a C650 keyboard as I have just done so successfuly thanks for the very clear instructions, so full marks!
John Smith - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 49
전체 시간: 11,519
