주요 콘텐츠로 건너뛰기
Toshiba Satellite E45-B4200 Heat Sink Replacement
Raymond Makynen
Raymond Makynen3 다른 기여자
최종 수정일 June 12, 2023
15 - 35 분
조정
The Toshiba Satellite E45-B4200, has a replaceable heat sink. Running a system with a faulty heatsink can quickly destroy the processor and melt the motherboard. This could make the whole system useless. As with the fan, replacing the heatsink is a much less expensive fix than replacing an entire system. If you are having a heating and cooling issue, make sure it isn't any other issue that you can find on the the Toshiba Satellite E45-B4200 Troubleshooting page.
Before beginning this repair, be sure to turn off the laptop, unplug the power cord, and remove the external battery. This device didn't have an external battery so we weren't able to demonstrate that step. In addition, the fan was broken off the heat sink so it will likely look different than your device.
필요한 것
도구
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #0 Screwdriver
더보기...
  1. Toshiba Satellite E45-B4200 Heat Sink Replacement, Back Case: 1 단계, 이미지 3개 중 1개 Toshiba Satellite E45-B4200 Heat Sink Replacement, Back Case: 1 단계, 이미지 3개 중 2개 Toshiba Satellite E45-B4200 Heat Sink Replacement, Back Case: 1 단계, 이미지 3개 중 3개
    • Make sure to turn off the device, remove the battery, and unplug the laptop from the charger prior to the disassembly.
    • Use a Phillips #0 screwdriver to remove fourteen 3.75 mm screws from the back cover.
    • Use a spudger or opening tool to gently separate the back cover from the top of the device. Work your way around the perimeter of the laptop and undo the clips with the spudger.
    • Remove the back case.
  2. Toshiba Satellite E45-B4200 Heat Sink Replacement, Heat Sink: 2 단계, 이미지 1개 중 1개
    • Locate the heat sink system in the middle of the motherboard, resembling a copper strip.
  3. Toshiba Satellite E45-B4200 Heat Sink Replacement: 3 단계, 이미지 1개 중 1개
    • Using a #0 Phillips screwdriver, unscrew the heat sink attached to the processor.
    • This is located at the center of the motherboard.
  4. Toshiba Satellite E45-B4200 Heat Sink Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the heat sink system off the processor.
    • Apply fresh thermal paste to the CPU before placing a new heatsink in the device.
결론
작성자
3다른 기여자 명과 함께
Raymond Makynen
회원 가입일: 03/20/23
289 평판
안내서 3개를 작성함
UMass Dartmouth, Team 5-2, Ramos Spring 2023 UMass Dartmouth, Team 5-2, Ramos Spring 2023 회원
UMASSD-RAMOS-S23S5G2
3 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 171
