Wahl Lithium Ion Trimmer Slide switch Replacement
This guide will teach you how to replace the power switch on your razor instead of going and buying a new razor all together. This switch has a plastic mechanism that is connected to the slider from the inside. The plastic switch is in between the battery and motor that controls power. This switch could get jammed or broken off.
다른 한 분이 해당 안내서를 완성하였습니다.
