주요 콘텐츠로 건너뛰기
Wheel Replacement on Patagonia Freewheeler/Freightliner Luggage
Brittany McCrigler
Brittany McCrigler6 다른 기여자
최종 수정일 March 26, 2025
5 분
매우 쉬움
추천 가이드
Patagonia
Wheels on roller luggage can wear down over time or even detach completely. When this happens, the best solution is a full wheel replacement.
This guide will demonstrate how to assess wheel damage and replace the wheels and axles of a Patagonia Freewheeler or Freightliner Wheeled Duffel.
Replacement parts are currently unavailable. To get your luggage fixed, take it in to a local Patagonia retail store for repair evaluation or send it in to Patagonia through their mail-in repair service.
Related Tutorials
필요한 것
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. Wheel Replacement on Patagonia Freewheeler/Freightliner Luggage, Assess the damage: 1 단계, 이미지 3개 중 1개 Wheel Replacement on Patagonia Freewheeler/Freightliner Luggage, Assess the damage: 1 단계, 이미지 3개 중 2개 Wheel Replacement on Patagonia Freewheeler/Freightliner Luggage, Assess the damage: 1 단계, 이미지 3개 중 3개
    • Assess both wheels on the luggage:
    • Damaged Tread - If the rubber on the wheel has a flat spot or the tread is missing completely (reference image #3), the wheel must be replaced.
    • Damaged Axle - A slow‑moving or awkwardly angled wheel is often a sign of a bent or damaged axle.
    • Missing Wheel - If both the wheel and axle are missing, skip to Step 3.
    • As you remove parts, determine what is damaged and whether any parts (wheel or axle) are reusable.
  2. Wheel Replacement on Patagonia Freewheeler/Freightliner Luggage, Remove the wheel: 2 단계, 이미지 3개 중 1개 Wheel Replacement on Patagonia Freewheeler/Freightliner Luggage, Remove the wheel: 2 단계, 이미지 3개 중 2개 Wheel Replacement on Patagonia Freewheeler/Freightliner Luggage, Remove the wheel: 2 단계, 이미지 3개 중 3개
    • Use a 4 mm hex key to unscrew and remove the axle to free the damaged wheel from the wheel housing.
    • Righty tighty, lefty loosey!
    • Lift up the corner of the bag or tilt it onto its side to remove the wheel.
    • Responsibly discard any unusable pieces.
  3. Wheel Replacement on Patagonia Freewheeler/Freightliner Luggage, Replace the wheel: 3 단계, 이미지 3개 중 1개 Wheel Replacement on Patagonia Freewheeler/Freightliner Luggage, Replace the wheel: 3 단계, 이미지 3개 중 2개 Wheel Replacement on Patagonia Freewheeler/Freightliner Luggage, Replace the wheel: 3 단계, 이미지 3개 중 3개
    • Line up the replacement wheel with the bolt hole in the plastic wheel housing.
    • Insert the replacement axle and secure it using a 4 mm hex key.
    • Gently hand-tighten the axle to avoid overtightening it.
    • Check the function of the wheel by spinning the wheel or rolling the luggage on the floor.
    • The appropriate tightness allows the wheel to spin freely for a few seconds. You may need to tighten or loosen the axle.
결승점
다른 5명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Brittany McCrigler
회원 가입일: 03/05/12
89,748 평판
안내서 142개를 작성함
iFixit iFixit 회원
Staff
119 회원들
안내서 19,481개를 작성함
댓글 2개
What do you do when the nut inside the wheel housing comes loose? I can hear it rolling around in the housing. The bolt has nothing to screw back into. Is there any way to take the housing off? It looks to be held on by rivets. I'm guessing that's not a good sign.
Derek Emanuel - 답글
Helpful but where do you get the replacement wheel from. My brand new Black Hole 100L bag showed up in Lisbon Portugal with one wheel missing. Need to get another wheel and screw. Can I order that from Patagonia and have them ship to a friend that is coming here? Is that best route to take? Thanks
Craig Klinger - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 26
지난 30일: 101
전체 시간: 11,813
