주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wiko View Screen Replacement
필요한 것
      • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
      • Fully power off your phone and unplug any cables.
      • Ground yourself the best you can to avoid damaging any little component.
      • If you have one, you can use the iFixit Anti-Static Wrist Strap.
      댓글 쓰기
    1. Wiko View Screen Replacement, Remove the back cover: 2 단계, 이미지 2개 중 1개 Wiko View Screen Replacement, Remove the back cover: 2 단계, 이미지 2개 중 2개
      • Locate the small gap in the bottom-right corner to separate the back cover from the phone's frame.
      • Pull slowly until you can lift the corner enough to grab the back cover with your fingers. You can use an opening pick for help.
      • Pull the back cover along all the sides to completely separate from the rest of the phone.
      • The back cover can tolerate a little bending but don't bend too much otherwise it will crack.
      댓글 쓰기
    2. Wiko View Screen Replacement, Remove the battery: 3 단계, 이미지 3개 중 1개 Wiko View Screen Replacement, Remove the battery: 3 단계, 이미지 3개 중 2개 Wiko View Screen Replacement, Remove the battery: 3 단계, 이미지 3개 중 3개
      • Once the back cover is completely removed, you can remove the battery by lifting it from the bottom-left corner.
      • There is another small gap for help.
      • You won't need the help of any tool for this.
      • From now on, be very careful not to damage the tiny metal springs. The next steps will remove any protection for them; they are thin and very easy to break.
      • If you break one of them, you need to do precision soldering (or just tape it back in place with electrical tape for a quicker but very cheap solution).
      댓글 쓰기
    3. Wiko View Screen Replacement, Remove the top plastic cover: 4 단계, 이미지 3개 중 1개 Wiko View Screen Replacement, Remove the top plastic cover: 4 단계, 이미지 3개 중 2개 Wiko View Screen Replacement, Remove the top plastic cover: 4 단계, 이미지 3개 중 3개
      • Remove every SIM or SD card from the slots.
      • Unscrew all the six screws from the top plastic cover.
      • Start to lift gently the cover using opening picks from its bottom-right corner.
      • Only insert the pick up to 3.5 mm to avoid damaging the internals.
      • Keep pushing the opening pick along all the external sides of the plastic cover.
      • You need to open all the plastic clips hidden under the cover itself. You can notice a soft "pop" when opening successfully one of them.
      • When all the clips are opened, you can lift the cover completely with caution.
      댓글 쓰기
    4. Wiko View Screen Replacement, Unplug power buttons: 5 단계, 이미지 1개 중 1개
      댓글 쓰기
    5. Wiko View Screen Replacement, Unplug display and bottom circuit: 6 단계, 이미지 1개 중 1개
      • Unplug the display-touch digitizer and bottom circuit connectors with the help of a spudger.
      • They are both press connectors.
      댓글 쓰기
    6. Wiko View Screen Replacement, Remove the bottom plastic cover: 7 단계, 이미지 3개 중 1개 Wiko View Screen Replacement, Remove the bottom plastic cover: 7 단계, 이미지 3개 중 2개 Wiko View Screen Replacement, Remove the bottom plastic cover: 7 단계, 이미지 3개 중 3개
      • Unscrew all four screws.
      • Like in the Step 4, use an opening pick to lift and remove carefully the cover from the bottom-left corner.
      • We are not going to remove the bottom motherboard in this guide.
      댓글 쓰기
    7. Wiko View Screen Replacement, Remove the motherboard: 8 단계, 이미지 3개 중 1개 Wiko View Screen Replacement, Remove the motherboard: 8 단계, 이미지 3개 중 2개 Wiko View Screen Replacement, Remove the motherboard: 8 단계, 이미지 3개 중 3개
      • Unscrew the two screws that hold the motherboard.
      • Do not apply force to remove the motherboard, otherwise you will cut the antenna cable.
      • Gently lift the motherboard passing the cable under the plastic frame and go to the next step.
      댓글 쓰기
    8. Wiko View Screen Replacement, Remove the antenna cable: 9 단계, 이미지 2개 중 1개 Wiko View Screen Replacement, Remove the antenna cable: 9 단계, 이미지 2개 중 2개
      • Unplug the antenna cable from both ends.
      • It has a coaxial connector.
      • Remember to reconnect the antenna cable before remounting the motherboard.
      댓글 쓰기
    9. Wiko View Screen Replacement, Remove the sticker: 10 단계, 이미지 2개 중 1개 Wiko View Screen Replacement, Remove the sticker: 10 단계, 이미지 2개 중 2개
      • With the help of a tweezer, remove slowly the back sticker.
      • Take note of the codes written in case it breaks.
      • After the substitution, you can put it back where was.
      댓글 쓰기
    10. Wiko View Screen Replacement, Unplug the motherboard's link cable: 11 단계, 이미지 2개 중 1개 Wiko View Screen Replacement, Unplug the motherboard's link cable: 11 단계, 이미지 2개 중 2개
      • Unplug the cable that links the two motherboards.
      • Do not completely remove the cable from the metal case.
      댓글 쓰기
    11. Wiko View Screen Replacement, Remove the display cable: 12 단계, 이미지 3개 중 1개 Wiko View Screen Replacement, Remove the display cable: 12 단계, 이미지 3개 중 2개 Wiko View Screen Replacement, Remove the display cable: 12 단계, 이미지 3개 중 3개
      • First, unplug the cable from the bottom motherboard.
      • It's a "no-fuss" ribble cable connector.
      • Then slowly pull the bigger cable.
      • The cable is glued to the metal case.
      • Be sure to lift the cable for all its length, so the adhesive won't keep it in place and break it in the following steps.
      • Do not completely remove the cable - it is linked to the display under the metal case.
      • Remove the grey adhesive.
      댓글 쓰기
    12. Wiko View Screen Replacement, Remove the display: 13 단계, 이미지 3개 중 1개 Wiko View Screen Replacement, Remove the display: 13 단계, 이미지 3개 중 2개 Wiko View Screen Replacement, Remove the display: 13 단계, 이미지 3개 중 3개
      • Heat an iOpener and apply it to the right edge of the screen for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone - the display is susceptible to heat damage.
      • Apply a suction cup to the screen, as close to the center of the right edge as possible, and pull up with strong, steady force to create a gap between the bezel and the frame.
      • Insert an opening pick into the gap.
      • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again. You can also use a Jimmy instead (being very careful not to scratch the metal frame). If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere.
      • Release all the clips and unglue the screen.
      • Pull the cable through the frame's opening.
      댓글 쓰기
    13. Wiko View Screen Replacement, Remove adhesives: 14 단계, 이미지 1개 중 1개
      • Remove the adhesive backings from the new part
      • Remove the protective adhesive in front of the screen only when the reparation is complete.
      댓글 쓰기
    14. Wiko View Screen Replacement, Transfer the remaining components: 15 단계, 이미지 3개 중 1개 Wiko View Screen Replacement, Transfer the remaining components: 15 단계, 이미지 3개 중 2개 Wiko View Screen Replacement, Transfer the remaining components: 15 단계, 이미지 3개 중 3개
      • Compare your new replacement part to the original part - you may need to transfer the remaining components.
      • For example:
      • The ear capsule grid.
      • The lens of the internal flash.
      댓글 쓰기
    15. Wiko View Screen Replacement, Add the new adhesive: 16 단계, 이미지 3개 중 1개 Wiko View Screen Replacement, Add the new adhesive: 16 단계, 이미지 3개 중 2개 Wiko View Screen Replacement, Add the new adhesive: 16 단계, 이미지 3개 중 3개
      • Fill all the screen's borders with the double-sided adhesive.
      • You can use the precision tweezer and spudger to help you position and compress the tape in place.
      댓글 쓰기
    16. Wiko View Screen Replacement, Place the new display cable: 17 단계, 이미지 2개 중 1개 Wiko View Screen Replacement, Place the new display cable: 17 단계, 이미지 2개 중 2개
      • Insert the new display cable in the metal case opening.
      댓글 쓰기
    17. Wiko View Screen Replacement, Install the new display: 18 단계, 이미지 1개 중 1개
      • Remove all the protective layers from the placed tape.
      • Push the display into the frame.
      • Let the glue dry.
      댓글 쓰기
    18. Wiko View Screen Replacement, Place the new display cable: 19 단계, 이미지 3개 중 1개 Wiko View Screen Replacement, Place the new display cable: 19 단계, 이미지 3개 중 2개 Wiko View Screen Replacement, Place the new display cable: 19 단계, 이미지 3개 중 3개
      • Remove the protective layer from the main cable's adhesive.
      • Place the main cable parallel to the orange one.
      댓글 쓰기
결론
You can take the opportunity to clean in-depth your device.
Before completely closing your device, make some tests for the display and touch.
Leave your device under a book or some soft weight for a couple of hours to let the screen adhesive stick well.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Emanuele Artusi
회원 가입일: 10/23/24
1,124 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 37
전체 시간: 423
