주요 콘텐츠로 건너뛰기
Xiaomi Mi Watch 2021 Battery Replacement
필요한 것
  1. Xiaomi Mi Watch 2021 Battery Replacement, Unfasten the screws: 1 단계, 이미지 1/1
    • Opening the Mi Watch will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your watch without replacing the seals.
    • Before starting the disassembly, turn off your watch.
    • Remove the four 3.2 mm-long T3 Torx screws on the back of the watch.
    • A T3 screwdriver has a tight fit on these screws and might require a bit more downward pressure to unfasten the screws. A T2 fits as well but poses the risk to strip the screw heads.
  2. Xiaomi Mi Watch 2021 Battery Replacement, Create a small gap: 2 단계, 이미지 1/3 Xiaomi Mi Watch 2021 Battery Replacement, Create a small gap: 2 단계, 이미지 2/3 Xiaomi Mi Watch 2021 Battery Replacement, Create a small gap: 2 단계, 이미지 3/3
    • Insert the flat end of a spudger into the loudspeaker opening at the top edge of the rear case assembly.
    • Push the spudger upwards to create a small gap between the rear case assembly and the watch housing.
  3. Xiaomi Mi Watch 2021 Battery Replacement, Pry up the rear case: 3 단계, 이미지 1/2 Xiaomi Mi Watch 2021 Battery Replacement, Pry up the rear case: 3 단계, 이미지 2/2
    • Insert your spudger into the gap and pry up the rear case assembly.
    • Only work with the edge of your spudger and do not insert it deeper than 3 mm.
    • Steady the rear case assembly with a finger to prevent it from suddenly popping open and damaging the flex cable.
    • Don’t try to remove the rear case assembly all the way yet. It is still connected to the motherboard with a thin flex cable.
  4. Xiaomi Mi Watch 2021 Battery Replacement, Open the watch assembly: 4 단계, 이미지 1/2 Xiaomi Mi Watch 2021 Battery Replacement, Open the watch assembly: 4 단계, 이미지 2/2
    • Carefully swing open the rear case assembly by folding the rear case to the side with the watch buttons.
    • Avoid straining the flex cable during this procedure.
  5. Xiaomi Mi Watch 2021 Battery Replacement, Unfasten the screw: 5 단계, 이미지 1/1
    • While it's possible to remove the battery without disconnecting the rear case assembly first (jump straight to step 8), there's a substantial risk of damaging components. We highly recommend removing the rear case assembly.
    • Remove the 2.7 mm-long Phillips screw securing the metal bracket.
  6. Xiaomi Mi Watch 2021 Battery Replacement, Remove the metal bracket: 6 단계, 이미지 1/2 Xiaomi Mi Watch 2021 Battery Replacement, Remove the metal bracket: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
  7. Xiaomi Mi Watch 2021 Battery Replacement, Disconnect the rear case assembly: 7 단계, 이미지 1/2 Xiaomi Mi Watch 2021 Battery Replacement, Disconnect the rear case assembly: 7 단계, 이미지 2/2
    • Use the flat end of a spudger to pry up and disconnect the rear case assembly connector from the motherboard.
  8. Xiaomi Mi Watch 2021 Battery Replacement, Disconnect the battery: 8 단계, 이미지 1/2 Xiaomi Mi Watch 2021 Battery Replacement, Disconnect the battery: 8 단계, 이미지 2/2
    • Use the flat end of a spudger to pry up and disconnect the battery connector.
  9. Xiaomi Mi Watch 2021 Battery Replacement, Pry up the battery: 9 단계, 이미지 1/3 Xiaomi Mi Watch 2021 Battery Replacement, Pry up the battery: 9 단계, 이미지 2/3 Xiaomi Mi Watch 2021 Battery Replacement, Pry up the battery: 9 단계, 이미지 3/3
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Insert an opening pick underneath the left edge of the battery.
    • Tilt down your opening pick to pry up the battery.
  10. Xiaomi Mi Watch 2021 Battery Replacement, Remove the battery: 10 단계, 이미지 1/2 Xiaomi Mi Watch 2021 Battery Replacement, Remove the battery: 10 단계, 이미지 2/2
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
결론
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 1 more hour. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
다른 5명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
211,821 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,085개 작성하였습니다
댓글 2개
Hi,
I have the s1 active and the battery connector is broken so it can't charge the watch.
Can you please suggest some store to buy online the battery connector and the battery to replacement?
leftkoyl - 답글
hi,
where can i purchase the metal bezel/case replacement for S1 active? thanks
Fizul Khairi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 84
30일 전: 340
전체 시간: 7,085
