소개
Use this guide to replace a cracked or broken screen on your Xiaomi Redmi Note 8T.
If the frame is deformed, it's important to replace it to make sure the new screen will mount correctly and won’t suffer damage from uneven pressure.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
Note: This guide instructs you to replace only the screen while leaving the original frame and motherboard in place. However, some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure. Make sure you have the correct part before starting this guide.
You’ll need replacement adhesive to reattach components when reassembling the device.
필요한 것
Before you begin, switch off your phone.
Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
9 단계 Xiaomi Redmi Note 8T Motherboard Cover Removal
주의: 9-11 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Remove the eleven Phillips #00 screws (3.9 mm length).
12 단계 Xiaomi Redmi Note 8T Battery Disconnect
주의: 12 단계는 진행 중으로 표시된 안내서에서 제공되었습니다.
Use a spudger to pry up and disconnect the battery flex cable.
Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
Once the screen is warm to the touch, apply a suction handle to the bottom edge of the phone.
Lift the screen with the suction handle to create a small gap between the cover and the frame.
Insert an iFlex between the midframe and the screen to create a bigger gap. Leave the iFlex in the gap to prevent the screen from resealing.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
다른 14명이 해당 안내서를 완성하였습니다.
댓글 6개
Hervorande Anleitung !
Bonjour, c'est grâce à ce tuto que je suis fier de vous dire avoir réussi à changer mon écran seul sans payer un réparateur.
Pour enlever l ‘écran je n ai pas réussi à soulever l’écran avec une ventouse en chauffant avec un sèche cheveux ( alors que ça a bien fonctionné pour la vitre arrière).
J ai improvisé alors j ai du élargir une fissure avec un petit tournevis pour soulever l’écran du châssis et ainsi insérer le mediator comme prévu
Merci pour ce tuto…
After heating to take apart back glass and screen, both buttons power and volume are loose and dont stay on their place. they fall, even if i put them back. any idea why this happens?
ok i found why. buttons have a black thin plastic “lock" check it under microscope mine had “twisted
ifixthem -
