주요 콘텐츠로 건너뛰기
Xiaomi Redmi Note 9 Screen Replacement
필요한 것
  1. Xiaomi Redmi Note 9 Screen Replacement, Eject the SIM card tray: 1 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 9 Screen Replacement, Eject the SIM card tray: 1 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 9 Screen Replacement, Eject the SIM card tray: 1 단계, 이미지 3개 중 3개
    • Insert a SIM card eject tool, a SIM eject bit, or a straightened paper clip into the hole on the SIM tray located at the left edge of the phone.
    • Press directly into the hole to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Xiaomi Redmi Note 9 Screen Replacement, Heat the back cover: 2 단계, 이미지 1개 중 1개
    • The back cover of the Redmi Note 9 is held in place by plastic clips and adhesive. It might require some force to release the plastic clips.
    • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Xiaomi Redmi Note 9 Screen Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 9 Screen Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 9 Screen Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 3개
    • Secure a suction handle to the bottom edge of the screen, as close to the edge as possible.
    • If the screen is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the phone assembly with the suction handle to create a small gap between the assembly and the back cover.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick in a steep angle into the gap you created. This might require some force.
    • Slide the opening pick to the bottom right corner to slice the adhesive and release the plastic clips holding the back cover in place.
  4. Xiaomi Redmi Note 9 Screen Replacement, Release the plastic clips and slice the adhesive: 4 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 9 Screen Replacement, Release the plastic clips and slice the adhesive: 4 단계, 이미지 2개 중 2개
    • Insert a second opening pick in a steep angle at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to release the plastic clips and to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  5. Xiaomi Redmi Note 9 Screen Replacement, Release the plastic clips and slice the adhesive: 5 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 9 Screen Replacement, Release the plastic clips and slice the adhesive: 5 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 9 Screen Replacement, Release the plastic clips and slice the adhesive: 5 단계, 이미지 3개 중 3개
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick in a steep angle at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to release the plastic clips and slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. Xiaomi Redmi Note 9 Screen Replacement: 6 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 9 Screen Replacement: 6 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 9 Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Insert a fourth opening pick in a steep angle at the bottom right corner of your phone.
    • Slide the opening pick along the right edge of your phone to release the plastic clips and slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    • Do not try to separate the phone assembly from the back cover all the way yet, the fingerprint cable is still connected to the motherboard.
  7. Xiaomi Redmi Note 9 Screen Replacement, Open the phone assembly: 7 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 9 Screen Replacement, Open the phone assembly: 7 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 9 Screen Replacement, Open the phone assembly: 7 단계, 이미지 3개 중 3개
    • Flip your Redmi Note 9 over.
    • Avoid straining the fingerprint flex cable during the following procedure.
    • Carefully fold the back cover to the right side of the phone assembly like you would open a book from the back.
    • Slide the back cover underneath the phone assembly so that the phone assembly overlaps about one third of the back cover and the fingerprint cable is not strained.
  8. Xiaomi Redmi Note 9 Screen Replacement, Unfasten the motherboard cover screws: 8 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the eleven 3.9 mm-long screws securing the motherboard cover.
  9. Xiaomi Redmi Note 9 Screen Replacement, Pry up the motherboard cover: 9 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 9 Screen Replacement, Pry up the motherboard cover: 9 단계, 이미지 2개 중 2개
    • Insert the tip of an opening pick underneath the bottom left edge of the motherboard cover.
    • Pry up the motherboard cover.
  10. Xiaomi Redmi Note 9 Screen Replacement, Remove the motherboard cover: 10 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 9 Screen Replacement, Remove the motherboard cover: 10 단계, 이미지 2개 중 2개
    • Remove the motherboard cover.
  11. Xiaomi Redmi Note 9 Screen Replacement, Disconnect the fingerprint cable: 11 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 9 Screen Replacement, Disconnect the fingerprint cable: 11 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 9 Screen Replacement, Disconnect the fingerprint cable: 11 단계, 이미지 3개 중 3개
    • Use a spudger to disconnect the fingerprint cable by prying the connector straight up from its socket.
    • Separate the phone assembly from the back cover.
  12. Xiaomi Redmi Note 9 Screen Replacement, Disconnect the battery cable: 12 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 9 Screen Replacement, Disconnect the battery cable: 12 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  13. Xiaomi Redmi Note 9 Screen Replacement, Disconnect the display cable: 13 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 9 Screen Replacement, Disconnect the display cable: 13 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the display cable by prying the connector straight up from its socket.
  14. Xiaomi Redmi Note 9 Screen Replacement, Unfasten the loudspeaker screws: 14 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the seven 3.9 mm-long screws securing the loudspeaker assembly.
  15. Xiaomi Redmi Note 9 Screen Replacement, Remove the loudspeaker assembly: 15 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 9 Screen Replacement, Remove the loudspeaker assembly: 15 단계, 이미지 2개 중 2개
    • Remove the loudspeaker assembly.
  16. Xiaomi Redmi Note 9 Screen Replacement, Loosen the display adhesive: 16 단계, 이미지 1개 중 1개
    • Apply a heated iOpener or a heat gun to the screen to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
    • The protective adhesive of the Redmi Note 9 is very strong and it's hard to get underneath the display panel in the beginning. It is likely that you have to reapply the iOpener more than once.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  17. Xiaomi Redmi Note 9 Screen Replacement, Insert an iFlex: 17 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 9 Screen Replacement, Insert an iFlex: 17 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 9 Screen Replacement, Insert an iFlex: 17 단계, 이미지 3개 중 3개
    • Once the screen is warm to touch, apply a suction cup to the bottom edge of the screen.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an iFlex in the gap between the midframe and the screen.
  18. Xiaomi Redmi Note 9 Screen Replacement, Insert an opening pick: 18 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 9 Screen Replacement, Insert an opening pick: 18 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 9 Screen Replacement, Insert an opening pick: 18 단계, 이미지 3개 중 3개
    • Insert an opening pick above the iFlex.
    • Slide the opening pick to the bottom left corner of the screen to slice its adhesive. Leave the opening pick in place to prevent the adhesive from resealing.
    • Remove the iFlex.
  19. Xiaomi Redmi Note 9 Screen Replacement, Slice the adhesive: 19 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 9 Screen Replacement, Slice the adhesive: 19 단계, 이미지 2개 중 2개
    • Insert a second opening pick and slide it to the bottom right corner of the screen to cut the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  20. Xiaomi Redmi Note 9 Screen Replacement: 20 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 9 Screen Replacement: 20 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 9 Screen Replacement: 20 단계, 이미지 3개 중 3개
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun to for 1-2 minutes to reheat it.
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive. Leave it in the top left corner to prevent the adhesive from resealing.
    • When you slice near the front facing camera, insert only the tip of the opening pick (about 3 to 4 mm) to avoid damaging or smearing the camera.
  21. Xiaomi Redmi Note 9 Screen Replacement: 21 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 9 Screen Replacement: 21 단계, 이미지 2개 중 2개
    • When you slice near the front facing camera, insert only the tip of the opening pick to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner of the screen to prevent the adhesive from resealing.
  22. Xiaomi Redmi Note 9 Screen Replacement: 22 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 9 Screen Replacement: 22 단계, 이미지 2개 중 2개
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive.
    • Do not try to remove the display all the way yet, the display cable is still threaded through the frame.
  23. Xiaomi Redmi Note 9 Screen Replacement, Remove the screen: 23 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 9 Screen Replacement, Remove the screen: 23 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 9 Screen Replacement, Remove the screen: 23 단계, 이미지 3개 중 3개
    • Thread the display flex cable through the gap in the midframe and remove the screen.
    • Compare your new replacement part to the original part—you may need to transfer remaining components from your old screen to your replacement part.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, follow this guide in case you're using a pre-cut adhesive card.
결론
If possible, turn on your device and test your repair before installing new adhesive and resealing.
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
다른 17명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
247,335 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,743개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 15
지난 7일: 78
지난 30일: 385
전체 시간: 20,633
