주요 콘텐츠로 건너뛰기
Zeki Droid Tablet Battery Replacement
Kyla
Kyla3 다른 기여자
최종 수정일 January 14, 2020
40 분 - 1 시간
쉬움
액션 샷
단계 다듬기
This guide will help you to disassemble your tablet and replace your battery. This procedure should take no more then forty minutes to complete. The process will include using a soldering tool and sharp objects.
필요한 것
도구
더보기...
  1. Zeki Droid Tablet Battery Replacement, Back Casing: 1 단계, 이미지 1개 중 1개
    • Remove the back casing by slowly popping each tab out with a plastic opening tool.
  2. Zeki Droid Tablet Battery Replacement: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the tapes one by one from the connecting wires with tweezers.
  3. Zeki Droid Tablet Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the black clips from both sides of the casing with a plastic opening tool.
    • The clips should pop off separate from the speakers.
  4. Zeki Droid Tablet Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the speakers from the back casing.
    • Do not tug on the speakers because they are connected to fragile wires.
  5. Zeki Droid Tablet Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the speakers away from the back casing carefullly.
  6. Zeki Droid Tablet Battery Replacement, Battery: 6 단계, 이미지 1개 중 1개
    • To remove the battery use an iFixit opening tool to pry the battery apart from the sticky glue.
    • Do not bend the battery.
  7. Zeki Droid Tablet Battery Replacement: 7 단계, 이미지 1개 중 1개
    • To completely disconnect the battery, locate the two metal tabs connected to the small circuit board.
    • Using a soldering tool, you will desolder the tabs from the circuit board.
    • Please refer to the 연결부 납땜 및 납제거 방법
    • If your replacement battery already has the small circuit board attached, you can desolder the red and black wires connected to the mother board instead of the metal tabs.
  8. Zeki Droid Tablet Battery Replacement: 8 단계, 이미지 1개 중 1개
    • To insert the new battery, you will need to solder the two new metal tabs back onto the small circuit board.
    • Please refer to 연결부 납땜 및 납제거 방법
    • If you have the battery with the circuit board connected, then you can solder the red and black wires back to the mother board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kyla
회원 가입일: 03/11/15
156 평판
안내서 2개를 작성함
Colorado Springs, Team 2-6, Panko Spring 2015 Colorado Springs, Team 2-6, Panko Spring 2015 회원
UCCS-PANKO-S15S2G6
3 회원들
안내서 10개를 작성함
댓글 3개
will this be the same for a tbqc 1065b?
mark campbell - 답글
how do i replace the screen mine has cracks?
mark campbell - 답글
This was my daughter's ...but the yeIIow pack the battery in is BLOWN TIGHT BULGING LIKE A BALLOON. DO I dare try to pry it off...not sure if it will exoIode. Yikes!!! She was murdered so I want to save it
CIaudia Bringe - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 12
전체 시간: 5,573
