주요 콘텐츠로 건너뛰기
Zeki Droid Tablet Front Screen Replacement
Kyla
Kyla7 다른 기여자
최종 수정일 May 7, 2024
1 - 2 시간
조정
액션 샷
단계 다듬기
더 나은 이미지가 필요함
Use this guide to replace the screen on the Zeki Droid TBDC1093B.
Follow these instructions to disassemble the Zeki Droid and gain access to the broken screen. To prevent injury, I recommend following this guide to reinforce the broken glass.
필요한 것
도구
더보기...
  1. Zeki Droid Tablet Front Screen Replacement, Back Casing: 1 단계, 이미지 1개 중 1개
    • Remove the back casing by slowly popping each tab out with a plastic opening tool.
  2. Zeki Droid Tablet Front Screen Replacement: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the tapes one by one from the connecting wires with tweezers.
  3. Zeki Droid Tablet Front Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the black clips from both sides of the casing with a plastic opening tool.
    • The clips should pop off separate from the speakers.
  4. Zeki Droid Tablet Front Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the speakers from the back casing.
    • Do not tug on the speakers because they are connected to fragile wires.
  5. Zeki Droid Tablet Front Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the speakers away from the back casing carefullly.
  6. Zeki Droid Tablet Front Screen Replacement, Front Screen: 6 단계, 이미지 1개 중 1개
    • Detach the motherboard from the framing by removing the four screws using a Phillips #000 screwdriver.
  7. Zeki Droid Tablet Front Screen Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Lift the camera and flash components from their fittings using tweezers.
  8. Zeki Droid Tablet Front Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Lift the metal framing to reach the components at the front of the device.
    • Do not pull the framing completely off. There is a ZIF connecter holding it in place.
  9. Zeki Droid Tablet Front Screen Replacement: 9 단계, 이미지 2개 중 1개 Zeki Droid Tablet Front Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Push the screen forward to remove.
결론
작성자
7다른 기여자 명과 함께
Kyla
회원 가입일: 03/11/15
156 평판
안내서 2개를 작성함
Colorado Springs, Team 2-6, Panko Spring 2015 Colorado Springs, Team 2-6, Panko Spring 2015 회원
UCCS-PANKO-S15S2G6
3 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 346
