주요 콘텐츠로 건너뛰기
Zeki TBQG884B Rear Case Replacement
David Wyman
David Wyman14 다른 기여자
최종 수정일 January 4, 2024
10 - 15 분
조정
This guide will assist you in replacing the rear cover of your Zeki TBQG884B tablet, or as a prerequisite for repairs on any of the device's other internal components. It is important to remember before beginning this guide that the device is extremely delicate and to complete each step of this guide very carefully.
필요한 것
도구
  1. Zeki TBQG884B Rear Case Replacement, Rear Case: 1 단계, 이미지 2개 중 1개 Zeki TBQG884B Rear Case Replacement, Rear Case: 1 단계, 이미지 2개 중 2개
    • Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
  2. Zeki TBQG884B Rear Case Replacement: 2 단계, 이미지 1개 중 1개
    • Place the tablet down so that the screen is facing away from you.
    • Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
    • Gently work your way around the perimeter of the tablet's edge.
  3. Zeki TBQG884B Rear Case Replacement: 3 단계, 이미지 2개 중 1개 Zeki TBQG884B Rear Case Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the back cover
    • Remove any tape on the speaker and detach the speaker from the back plate.
    • The speaker is connected to the motherboard by two soldered wires. Don't break them when you remove the speaker.
결론
작성자
14다른 기여자 명과 함께
David Wyman
회원 가입일: 09/16/15
346 평판
안내서 3개를 작성함
IUPUI, Team 1-3, Harley Fall 2015 IUPUI, Team 1-3, Harley Fall 2015 회원
IUPUI-HARLEY-F15S1G3
5 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 383
