iBook G4 12" 1.33 GHz Lower Case Replacement
예상시간 없음
조정
Replacing the plastic bottom case.
Lay your iBook upside down on a flat surface.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Use a spudger or small flathead screwdriver to remove the three rubber feet from the lower case.
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
