주요 콘텐츠로 건너뛰기
iMac G5 17" Model A1058 Power Supply Replacement
Walter Galan
Walter Galan10 다른 기여자
최종 수정일 June 5, 2024
10 - 20 분
조정
Keep those electrons flowing by replacing your broken power supply!
필요한 것
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
동영상 개요
  1. iMac G5 17" Model A1058 Power Supply Replacement, Rear Panel: 1 단계, 이미지 1개 중 1개
    • Lay the iMac display-side down on a flat surface.
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. iMac G5 17" Model A1058 Power Supply Replacement: 2 단계, 이미지 3개 중 1개 iMac G5 17" Model A1058 Power Supply Replacement: 2 단계, 이미지 3개 중 2개 iMac G5 17" Model A1058 Power Supply Replacement: 2 단계, 이미지 3개 중 3개
    • Lift the rear panel slightly from the bottom edge of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
  3. iMac G5 17" Model A1058 Power Supply Replacement, Power Supply: 3 단계, 이미지 2개 중 1개 iMac G5 17" Model A1058 Power Supply Replacement, Power Supply: 3 단계, 이미지 2개 중 2개
    • Rotate the center Phillips screw on the bottom of the iMac clockwise until the rear panel clamp contacts the edge of the case.
    • On our specific machine, the threaded portion of the clamp broke off the clamp body causing the center screw to turn without moving the bracket. If your machine is broken like ours, skip to the next step.
  4. iMac G5 17" Model A1058 Power Supply Replacement: 4 단계, 이미지 3개 중 1개 iMac G5 17" Model A1058 Power Supply Replacement: 4 단계, 이미지 3개 중 2개 iMac G5 17" Model A1058 Power Supply Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Heavy-Duty Spudger
    • While depressing the connector lock, insert the flat end of a heavy duty spudger into the gap between the power supply connector and its socket.
    • Twist the heavy duty spudger to slightly separate the connector from its socket.
    • It will be necessary to work from alternate sides until the connector is free.
    • Your power supply may have an ambient light sensor cable attached from the power supply to the logic board. If so, carefully use a spudger to push out the cable towards you using the sides of the cable alternatively to help you slide it out.
  5. iMac G5 17" Model A1058 Power Supply Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the power supply connector straight away from its socket on the logic board.
    • This step is very simple if you remove the power supply first.
  6. iMac G5 17" Model A1058 Power Supply Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the three Phillips screws securing the power supply to the chassis.
    • All three screws are captive in the power supply.
    • To aid in removal, it may be helpful to lift the center screw slightly away from the midplane.
  7. iMac G5 17" Model A1058 Power Supply Replacement: 7 단계, 이미지 2개 중 1개 iMac G5 17" Model A1058 Power Supply Replacement: 7 단계, 이미지 2개 중 2개
    • There are several capacitors mounted to the logic board in close proximity to the power supply. Try not to disturb them, as they are delicate and may break off the board.
    • Grab the power supply from each side and rotate its top edge toward yourself until it clears the logic board.
    • Lift the power supply out of the midplane.
    • The power supply requires a large amount of force to remove. You may need to slightly bend the edge of the front case toward yourself for enough clearance to remove the power supply.
결론
다른 35명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Walter Galan
701,295 평판
안내서 1,203개를 작성함
댓글 한 개
very clear instructions... will replace my ps and then repair the faulty one.
do you have an idea what components usually fail or is it a mix of things?
Thanks
r@boarman.net
Irene1545 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 24
전체 시간: 33,995
